8N will not stay running? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 02-26-2013, 09:47 PM Thread Starter
First off I want to say Hi to all on this forum.
Now for the question I need help with.
I have owned this 1951 Ford 8N for the past 15 plus year.
When I first got it I rebuilt the engine and painted along with some other repairs, it has always ran and started great. Now the problem, last week when I went to start it, it started (actually fired is more like it) and then quite. I tried several times again with the same results, fired but would not continue running. Then the starter stopped engaging and only clicking at the solenoid. Replace the solenoid and then it turned over and fired but still would not stay running. So I figured it was time to do some maintenance the poor girl. Rebuilt the carburetor and replace the points and coil. At this point I assumed that my problem would have been solved. Tried to start it again and the same results. Fired but would not stay running. Then I notice that if I held the starter button down it will run fine, when I let up on the button it stops running.
I can’t figure this one out. I would not think the starter button would be the problem, but who knows. Any idea guys, I need help bad.
Thank you
Keith
cowboy1 is offline
post #2 of 5 Old 02-26-2013, 09:56 PM
Old Stonebreaker
Re: 8N will not stay running?
Has it been converted to 12v? If so I'm guessing you have a wire from the solenoid engagement wire straight to the coil which bypasses the resistor and the resistor is either burnt out or has lost it's feed connection.
JMHO,
Mike
mla2ofus is offline
post #3 of 5 Old 02-26-2013, 11:13 PM Thread Starter
It was converted to 12 volts about 12 years ago. Has worked fine all this time. Nothing has been done other than changing the solenoid, which only has 3 wires, and the problem started before I replaced the solenoid.
Any ideas and I will check. Is it possible that there is a safety in the start button that could have failed?
cowboy1 is offline
post #4 of 5 Old 02-27-2013, 09:38 PM
JohnW's Avatar
My money is on a bad ignition switch, bypass the key switch with a wire and see if that does not make it run.
JohnW is offline
post #5 of 5 Old 02-28-2013, 12:07 AM
Old Stonebreaker
Are there two wires connected to the coil + post?
Mike
mla2ofus is offline
