Ford 9n with interesting shifter. Any ideas? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 05-17-2019, 09:26 PM Thread Starter
Picked this 9n up today.
Has a shifter on the left side of the bell housing.
The hydraulic fluid is super clean with no water, The shifter boot has silicone around the top of it.
Tires are bad.
No cracks in the block.
Got this for 200 dollars today.
Not sure what the shifter is for, possibly a up step or Sherman transmission? IDK
ID:	2377009   Click image for larger version
ID:	2377011   Click image for larger version
ID:	2377013   Click image for larger version
ID:	2377017   Click image for larger version
ID:	2377019   Click image for larger version
bobbington is offline
post #2 of 8 Old 05-18-2019, 07:28 AM
close enuff works for me
deereboy55's Avatar
Re: Ford 9n with interesting shifter. Any ideas?
The extra shifter is for a ,step up ,or step down auxiliary trans. You will have to drive it and use it to find out . The extra transmission is worth about what you paid for the whole tractor.
deereboy55 is offline
post #3 of 8 Old 05-18-2019, 07:31 AM
Nouveau Redneck's Avatar
Nice tractor. That looks like the shifter for a a Sherman Combination auxiliary transmission (step-down, straight & step-up)
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #4 of 8 Old 05-18-2019, 07:35 AM
ex spelling bee champ
Ingersoll444's Avatar
Ya its a aux trans. Its hard to say what one you have till you use it. Step up, step down, or combo. Normaly the combo has a smaller dog leg shifter, but that looks home made, so its had to tell.
Paul
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #5 of 8 Old 05-18-2019, 09:58 AM Thread Starter
Thank you for that information.
Gonna try to turn her over by hand and if she turns i'll change the oil and filter and start getting some clean fuel flowing and see about getting her to crank.
The guy who sold it to me said it would run and that his father just left it to sit.
Seemed like to good of a deal to pass by even if the motor is locked.
Down here in the Dallas area if you stumble upon a good deal you have to act fast otherwise it will be gone.
post #6 of 8 Old 05-18-2019, 09:10 PM Thread Starter
This afternoon I was able work on the little tractor today, Put a fresh battery in and noticed that the starter would not kick onto the flywheel, was only running the motor, So I pulled the starter and right away the dang bushings all fell out. I was like O great here is another problem. hehehehehe
Pulled the gutts out of the starter housing and applied a little amount of penetrating oil to the starter gear slide and then used a very mild emory cloth on the brass contacts. They were a bit weathered looking, but I was able to get them fairly cleaned up.
Used some small zip ties to hold the brush springs in place and reassembled the starter, Cleaned all of the terminals really good in order to get some good current flow to really kick that starter gear onto the flywheel.
Pulled the plugs and put a few ounces of 30 wt mixed with a little transmission fluid into the cylinders to help free up the pistons and hit the starter button with the plugs out.
She turned over like a breeze in fact turned over so well I was able to raise the 3 point just from the starter spinning the motor over.
Put one of the plugs on the spark plug wire and no spark, pulled the coil and cap and tried to clean the points contact but but I kind of half assed that.
By this time I had discovered that the tractor was not a 9n after all but instead it is a 8n with a 4 speed transmission.
Such a good find.
I'll get back out there and those points cleaned up and see if she will pop off.
ID:	2377171   Click image for larger version
ID:	2377173   Click image for larger version
ID:	2377175   Click image for larger version
post #7 of 8 Old 05-19-2019, 08:14 AM
Such a good find.
Ya shes a 8N for sure... A tip on cleaning the points. You may know, but a lot dont.. When you clean them up, after you clean them just grab a ohm meter and check for continuity.. Once you have continuity with the closed points your good.. Saves a lot of time putting the dist back together and checking for spark to see if you cleaned them enough.
Paul
post #8 of 8 Old 05-19-2019, 12:37 PM
Or just look at the amp meter for needle movement as the points open and close.
tom
geezer88 is offline
FORD 3000 advise od maintainance Mandelinka Ford/New Holland Tractors 3 04-25-2019 07:51 AM
What shade of white does ford use ? Deutz guy88 Ford/Post 1990 New Holland 6 11-02-2018 08:15 PM
Ford Focus shifter problem.... glenn27 Car Talk 4 05-20-2018 08:59 AM
Ford tractor model ID document Nouveau Redneck Ford/New Holland Tractors 2 01-13-2013 07:20 PM
