Cracked 9N axle housing - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 04-11-2019, 02:44 PM Thread Starter
Unhappy Cracked 9N axle housing
Right axle housing cracked where the backhoe U-bolt attaches. I've had this tractor for over 25 years and of course now that I'm thinking of selling it this happens. Thoughts on welding it? Other option is to replace the axle housing, huge pain in the butt, or selling it as is and taking the loss. Tractor runs fine and everything works, what do you think a 9N with loader and backhoe is worth with the broken axle tube vs fixed?
1990? Wheel Horse/Work Horse, Converted to Electric
1964 Jacobsen Chief with Danco Loader, Converted to Electric
1970's Attex 6X6, Converted to Electric
I sense a theme here....
JRP3 is offline
post #2 of 16 Old 04-12-2019, 01:35 PM
work hard and love life
farmer dan's Avatar
Re: Cracked 9N axle housing
Put your self in the buyers shoes, if you see a weld red flags are going to start jumping up. If you are going to sell it my advice would be to replace the housing. If you want to keep it use a rod that has a little nickle in it (for cast steel) and cross your fingers. I have had good luck welding cast steel with a mig and .035 mild steel wire.
USMC/DAV
farmer dan is offline
post #3 of 16 Old 04-12-2019, 08:06 PM
Radnack's Avatar
Id try welding it. Not much to lose there. Most of my 8Ns that ive seen have some welds somewhere. As long as they don't leak they don't bother me. Although im not as picky as many people are.
Radnack is offline
post #4 of 16 Old 04-12-2019, 08:44 PM
MARK (LI)'s Avatar
Although I think that a good welder could take care of it, there are a lot of Ns out there that are available cheap with blown engines and such ...from which you could salvage the part..and have more parts left over...i am not sure if the later Ns will fit it...but I see 9s on CL and facebook marketplace all the time..here is one in Ct
https://nwct.craigslist.org/grd/d/wo...860223158.html
MARK (LI) is offline
post #5 of 16 Old 04-13-2019, 04:06 PM Thread Starter
I can get a replacement housing for around $150 delivered, the issue is the work involved in replacing it. Backhoe has to come off, at least enough to move the tractor about 3 inches away from it, have to unbolt the loader from the axle as well, though I think I can just jack that up half an inch and leave it in place. Then strip everything out of the old axle tube and set it up in the new one.
Just wondering what the unit is worth as is if someone else wanted to buy it and fix it, compared to what I'd get after I replaced the housing.
JRP3 is offline
post #6 of 16 Old 04-13-2019, 06:58 PM
JohnW's Avatar
Even with a loader and backhoe I would not give anymore than scrap price for it with the axle housing broken.
Logic is most useful. If only more humans would learn it and embrace it.
JohnW is offline
post #7 of 16 Old 04-16-2019, 10:11 PM Thread Starter
I wouldn't either, now, but in my younger years when I had more time than money I would certainly have given more than scrap value to get a working loader and backhoe that needed some work. Heck when I bought this 25 or so years ago I had to put the backhoe together and mount it and the loader on the tractor, which I bought separately.
JRP3 is offline
post #8 of 16 Old 04-17-2019, 07:53 PM
This is kind of a sign of overloading the machine. I know it is done, we all have done things with a machine which is way over normal capacity. It is also an indication of how tough these little Ns are. How many other machines at 75 years old would be alive after the abuse many have seen.
I work my 8N, but try to respect its age.
be0354 is offline
post #9 of 16 Old 04-17-2019, 09:19 PM Thread Starter
I'm fairly sure there was either a flaw in the casting or damage to it at some point in it's life. There is a "dent" in the casting where the crack is, but not where the U-bolt touched it, and it had been painted over. That said, this backhoe unit was originally designed for an 8N which probably has heavier walled axle tubes. I know they upgraded the 2N tube thickness twice in it's production, so this early 9N probably had the thinnest tube wall of them all.
JRP3 is offline
post #10 of 16 Old 04-19-2019, 12:08 AM
no2498's Avatar
? have/did you find the piece that drooped inside yet
john
no2498 is offline
post #11 of 16 Old 04-19-2019, 10:15 AM Thread Starter
I think I have all the pieces, pulled out 4. I've just about convinced myself to go ahead and replace the axle housing.
JRP3 is offline
post #12 of 16 Old 04-20-2019, 10:44 PM
no2498's Avatar
ya you have to do it in case you missed a piece
it's the only safe way to go
no matter if you keep it or sell it you know you did the right thing
john
no2498 is offline
post #13 of 16 Old 04-21-2019, 09:17 AM Thread Starter
Pulled it into the garage last night to start the process. yay.
JRP3 is offline
post #14 of 16 Old 04-22-2019, 10:48 PM
no2498's Avatar
happy tooling
john
no2498 is offline
post #15 of 16 Old 04-26-2019, 01:13 PM Thread Starter
Sure Seal removal method I saw on youtube, use a ratchet strap and sheet metal screws to pull the seal out. Didn't work on it's own, had to also hit the side of the seal with a screwdriver to help pop it loose while the strap tensioned it.
JRP3 is offline
How to replace 100-200 series transmission seals (Peerless 2300) lt230s John Deere Forum 6 01-24-2019 05:42 PM
L118 Spindle Housing Removal/Replace tzwizard John Deere Forum 6 12-16-2017 08:26 PM
Lawn Tractors, 90's - 2000 Vintage, Front Axle Change andyjw Backyard Round Table - L & G Tractor Related Topics 11 03-11-2013 11:30 AM
x7 Weights & Measures for Tractors/Attachments Diesel Powered John Deere FAQ and Stickies Section 14 02-23-2013 03:20 PM
Agco needs a diaper .... PBR ME Simplicity/Allis Chalmers Forum 16 12-26-2012 03:40 AM
