Time to Work on the Farmall Super C - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 62 Old 04-15-2019, 01:59 AM Thread Starter
cjet69's Avatar
Our Farmall Super C started running bad last spring It had a bad miss in it. We decided to park it until we had time to get to it. That time is here. I got it towed to the shop this evening and pushed it inside. Tomorrow I will start looking for the problem.
Name:	100_1347 (Medium).JPG
ID:	2371995   Click image for larger version
Name:	100_1349 (Medium).JPG
ID:	2371997   Click image for larger version
Name:	100_1350 (Medium).JPG
John Deere: 322, 318, 316, 214, #1-GT225, #2-GT225, LX255, 165, 111H, 111, SX95, SX75, RX73, F525, STX38
John Deere Gator 6x4 #1
John Deere Gator 6x4 #2
Sears: SS14, GT18, 16/6
Craftsman: 18.5 46, LT4000
Cub Cadet: 1450, 124, 1220
Simplicity: 725, 3415H
Homelite: CT-10
MTD: 990
Montgomery Ward: 14 variable speed
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #2 of 62 Old 04-15-2019, 07:47 AM
Smalljob's Avatar
Re: Time to Work on the Farmall Super C
Subscribed. Looking ditto your project.
Bill
1988 332 with 49 blower , 54 blade and 3 pt hitch
X500 w/48 deck and 44 blower
1023E H120 loader, B260 BH, 54D deck
Moved on to new home
1962 IH Cub Cadet Original
1963 110 Round Fender... Restored
1963 IH Cub Cadet 100, plow, deck, weigh box, 3 point hitch
1965 110 Round Fender with Model 38 deck..Restored
1966 110H Round Fender with Model 42 Blade..Restored
1967 112 Round Fender with Model 36 blower
1967 112 Round Fender with Johnson Model 10 Loader
1971 120 with 48 deck and 49 blower and OTC cab
1973 140H3 with 41 deck
1987 318 with 46 deck, 54 blade, 49 blower, 3pt hitch
1987 332 with 46 deck
Smalljob is online now
post #3 of 62 Old 04-15-2019, 09:51 AM
ex spelling bee champ
Ingersoll444's Avatar
Not sure I ever seen a wide front C. Nice. Good luck with the project. My stepdad had a nice superC with a flail mower on it that we used to mow the junk yard with..
Paul
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #4 of 62 Old 04-15-2019, 02:01 PM Thread Starter
cjet69's Avatar
Got out to the shop and pulled the hood, plugs, and valve cover. It didn't take long to find the problem. It has a stuck valve and a bent pushrod. Tried tapping on the valve and it won't move so its time to pull the head.
Name:	100_1356 (Medium).JPG
ID:	2372075   Click image for larger version
Name:	100_1357 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #5 of 62 Old 04-15-2019, 02:09 PM Thread Starter
cjet69's Avatar
It had the narrow front when we got it. Dad put a Farmall round tube wide front under it and ran it for years, but the extension tubes would get worn where the adjustment pin and clamp fastened allowing the tubes to rotate. We fixed that problem by adapting this Massey Fergusen front end to it and haven't had any problems since we installed it.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #6 of 62 Old 04-15-2019, 05:13 PM
I really like my Super C with the tri sickle front end. Can turn on a dime.
Forest Gump is offline
post #7 of 62 Old 04-15-2019, 09:23 PM Thread Starter
cjet69's Avatar
Pulled the head to get a look inside. The #3 intake is stuck and #4 intake is sticky. All of the other valves are good. Still not sure what the problem is.
Name:	100_1359 (Medium).JPG
ID:	2372111   Click image for larger version
Name:	100_1360 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #8 of 62 Old 04-16-2019, 09:09 AM
Are you running ethanol gas?
I've heard rumors of unleaded gas causing such. Had that happen on my old Ford truck engine. Had to install different make of valve guides which worked out great. Other option was to use a gas additive in the unleaded gas.
Leaded gas kept the stems and guides lubed better.
Running on Propane will also cause such.
Let us know what you or a machine shop determines?
post #9 of 62 Old 04-16-2019, 12:12 PM
Kish JD 318/420/430
RussKish's Avatar
From the way it looks to me, I would say head gasket leaking some coolant and maybe a bad oil ring(s) on 3/4. But wait for engine shop opinion, show them you pics. Wonder how the cam looks like.
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #10 of 62 Old 04-16-2019, 12:31 PM
Agree.
Kinda looks like it was burning some oil and maybe little water. (but usually that will keep a valve guide lubed some what.
post #11 of 62 Old 04-16-2019, 01:33 PM Thread Starter
cjet69's Avatar
Usually when a head gasket leaks into a cylinder you will find a little antifreeze in your oil when you change it. As far as I know none of us ever found antifreeze in the oil. I was kinda thinking that with 2 intakes next to each other if there might be a crack/pinhole in that intake port. I'll get it torn down and cleaned up for inspection.
We do most of our own machine work and only ship out for things like valve seats or crank grinds.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #12 of 62 Old 04-16-2019, 01:40 PM
Kish JD 318/420/430
RussKish's Avatar
I had a gaskets go on my 1997 Chevy S10 Blazer, only sign was a sightly crystallized build up on a couple of plugs. Nothing in the oil that we could notice, just tripping of the o2 sensors and some missing under load.
Russ
RussKish is offline
post #13 of 62 Old 04-16-2019, 04:47 PM Thread Starter
cjet69's Avatar
I soaked the stuck valve with some carb cleaner followed by some ATF/Acetone mix and let it soak overnight. After removing the valve springs I was able to tap the stuck valve out using a brass drift and ball peen. Once the valve started moving it came out without much effort. I found some black buildup on the stem that was slightly sticky feeling. It came right off with some carb cleaner and slides easily in the guide now. I don't find much wear or any galling on the stem or guide. So far no definitive answer on what cause it. On to the cleaning process.
Name:	100_1363 (Medium).JPG
ID:	2372265   Click image for larger version
Name:	100_1367 (Medium).JPG
ID:	2372267   Click image for larger version
Name:	100_1369 (Medium).JPG
ID:	2372269   Click image for larger version
Name:	100_1370 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #14 of 62 Old 04-16-2019, 05:14 PM
Kish JD 318/420/430
RussKish's Avatar
I wonder what the oil pan looks like, is it filled with years of sludge?
Russ
RussKish is offline
post #15 of 62 Old 04-16-2019, 05:31 PM
Senior MTF Pollster
Austen's Avatar
Cool project!
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
”What joy for those whose strength comes from the Lord." - Psalm 84:5
Austen is online now
First time JD buyer Celeste.wade.home Introductions 2 06-25-2018 07:32 AM
splitting my 1953 Farmall Super A hydro-trac IH Farmall 2 01-18-2013 11:36 AM
Farmall super A-140 duplex hopper tractorman90 IH Farmall 5 12-29-2012 10:08 PM
Late season seat time Talntedmrgreen Simplicity/Allis Chalmers Forum 13 12-12-2012 11:14 AM
