Time to Work on the Farmall Super C - Page 4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #46 of 63 Old 05-30-2019, 11:28 PM Thread Starter
cjet69's Avatar
Re: Time to Work on the Farmall Super C
Originally Posted by mopar65pa View Post
Cool!
But I will tell you my OCD would not let me put that thing back together with a shiny head and carb and the bottom end being cruddy.
I would like to paint the whole thing, but with hay season coming up quick we needed to get it back in action.
John Deere: 322, 318, 316, 214, #1-GT225, #2-GT225, LX255, 165, 111H, 111, SX95, SX75, RX73, F525, STX38
John Deere Gator 6x4 #1
John Deere Gator 6x4 #2
Sears: SS14, GT18, 16/6
Craftsman: 18.5 46, LT4000
Cub Cadet: 1450, 124, 1220
Simplicity: 725, 3415H
Homelite: CT-10
MTD: 990
Montgomery Ward: 14 variable speed
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #47 of 63 Old 05-30-2019, 11:29 PM Thread Starter
cjet69's Avatar
Got it running this afternoon. Pulled it out of the shop for a test run in the driveway and then took it up to the farm. We are going to use it moving a couple thing's and then my brother wants to put the plow on to work up a garden area.
Name:	100_1630 (Medium).JPG
ID:	2379215   Click image for larger version
Name:	100_1631 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #48 of 63 Old 05-31-2019, 12:24 AM
Kish JD 318/420/430
RussKish's Avatar
Another project reaches a milestone. Up and running, functional test to come with plowing (power under load). Way to go cjet69!!
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #49 of 63 Old 05-31-2019, 01:22 AM Thread Starter
cjet69's Avatar
A short vid.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #50 of 63 Old 05-31-2019, 01:24 AM Thread Starter
cjet69's Avatar
That will be a good test for it. Hope my work is up to the challenge.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #51 of 63 Old 05-31-2019, 07:08 AM
Retired & lovin it!
Newsman's Avatar
An the hits just keep on coming. Another home run. Nice job.
MikeC
Newsman is offline
post #52 of 63 Old 05-31-2019, 08:13 AM
Float looks like water may have froze in the bowl.
My old Super C engine started momentarily running rich right after it hit a bump or rough spot in the field, even worse if hit a rub-board spot and vibrated the tractor. Found the bowl was slightly warped and the gasket not sealing the top of the bowl good and fuel would slosh into the top and get sucked into the other ports.
I sanded the bowl flat on a piece of glass using sandpaper and new gasket and all ok. (problem was not readily apparent until problem got worse) Would foul a plug at first, then later as it got worse (gasket distorting) would have to push in the clutch to unload the engine and let the engine un-flood.
Forest Gump is offline
post #53 of 63 Old 05-31-2019, 11:04 AM Thread Starter
cjet69's Avatar
MikeC
MikeC. I expect the carb may need some tweeking once it goes to work and we will need to re-torque the head and adjust the valves after a good hard run. If all is good at that point then it should be good to go.
Thats what I think happened also.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #54 of 63 Old 05-31-2019, 05:21 PM
Parts collector
mopar65pa's Avatar
Originally Posted by cjet69 View Post
Yeah buddy!
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #55 of 63 Old 06-01-2019, 12:03 AM Thread Starter
cjet69's Avatar
My brother gave it a good test plow his garden. The plow was just starting to shine up on the last few passes. The tractor ran good.
Name:	100_1632 (Medium).JPG
ID:	2379373   Click image for larger version
Name:	100_1633 (Medium).JPG
ID:	2379375   Click image for larger version
Name:	100_1634 (Medium).JPG
ID:	2379377   Click image for larger version
Name:	100_1638 (Medium).JPG
Name:	100_1640 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #56 of 63 Old 06-01-2019, 06:08 AM
Do you know the model number on that plow..?? I've never seen a 2 prong FH single bottom for a Super C before, other than the auto-flip single like I have. 16", or 18" bottom..??
DJ54 is online now
post #57 of 63 Old 06-01-2019, 11:38 AM
Parts collector
mopar65pa's Avatar
Yeah buddy!
I wish I could get my Brinley plow for my 300 JD to dig that deep. BUT I plow, then disc, then harrow, then till.
1970 140 H1
1977 300 H2
198? 332 50" deck
post #58 of 63 Old 06-01-2019, 12:50 PM Thread Starter
cjet69's Avatar
It is a 16" but, I'm not sure what the model # is. Are there any numbers on the to help ID them?
EDIT:I did a search and it looks like it might be a C-10 plow.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
post #59 of 63 Old 06-01-2019, 01:09 PM
Kish JD 318/420/430
RussKish's Avatar
A great project to get it up and running, now fully functional. Way to go!!
Russ
RussKish is offline
post #60 of 63 Old 06-01-2019, 07:00 PM Thread Starter
cjet69's Avatar
I looked the plow over today and found remnants of the painted on C 10 PLOW. My brother pressure washed all the dirt off the plow so you can see the black paint that is still on it and the nice shine thats just underneath.
Name:	100_1646 (Medium).JPG
ID:	2379449   Click image for larger version
Name:	100_1645 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is offline
Poppa Dave
First time JD buyer Celeste.wade.home Introductions 2 06-25-2018 07:32 AM
splitting my 1953 Farmall Super A hydro-trac IH Farmall 2 01-18-2013 11:36 AM
Farmall super A-140 duplex hopper tractorman90 IH Farmall 5 12-29-2012 10:08 PM
Late season seat time Talntedmrgreen Simplicity/Allis Chalmers Forum 13 12-12-2012 11:14 AM
