Workin' on a Farmall - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 83 Old 12-25-2018, 09:56 PM Thread Starter
cjet69's Avatar
I brought this tractor home about a month ago and a couple weeks ago I pulled it into the shop with a HF winch. The tractor belongs to my cousin and he wants me to get it running for him. He also wanted me to get all of the sheet metal put back on and give it a good checking over. Hopefully things go well without to many surprises.
Name:	100_0524 (Medium).JPG
ID:	2353575   Click image for larger version
Name:	100_0525 (Medium).JPG
ID:	2353577   Click image for larger version
Name:	100_0522 (Medium).JPG
ID:	2353579   Click image for larger version
Name:	100_0683 (Medium).JPG
Name:	100_0684 (Medium).JPG
ID:	2353583   Click image for larger version
Name:	100_0685 (Medium).JPG
ID:	2353585   Click image for larger version
Name:	100_0687 (Medium).JPG
ID:	2353587   Click image for larger version
Name:	100_0689 (Medium).JPG
Name:	100_0690 (Medium).JPG
John Deere: 322, 318, 316, 214, #1-GT225, #2-GT225, LX255, 165, 111H, 111, SX95, SX75, RX73, F525, STX38
John Deere Gator 6x4 #1
John Deere Gator 6x4 #2
Sears: SS14, GT18, 16/6
Craftsman: 18.5 46, LT4000
Cub Cadet: 1450, 124, 1220
Simplicity: 725, 3415H
Homelite: CT-10
MTD: 990
Montgomery Ward: 14 variable speed
Dynamark: 12/38
Bolens: 1050
Case: 444
cjet69 is online now
post #2 of 83 Old 12-25-2018, 10:03 PM Thread Starter
cjet69's Avatar
Re: Workin' on a Farmall
The owner started a 12v conversion so I will need to complete that with a coil, VR, and wiring for the charging system. I had a coil from my parts 350 that still works and today I tested the alternator that came with the tractor and its good.
Name:	100_0692 (Medium).JPG
ID:	2353593   Click image for larger version
Name:	100_0694 (Medium).JPG
ID:	2353595   Click image for larger version
Name:	100_0782 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #3 of 83 Old 12-25-2018, 10:20 PM
Smalljob's Avatar
Looks like a great project!
Bill
1988 332 with 49 blower , 54 blade and 3 pt hitch
X500 w/48 deck and 44 blower
1023E H120 loader, B260 BH, 54D deck
Moved on to new home
1962 IH Cub Cadet Original
1963 110 Round Fender... Restored
1963 IH Cub Cadet 100, plow, deck, weigh box, 3 point hitch
1965 110 Round Fender with Model 38 deck..Restored
1966 110H Round Fender with Model 42 Blade..Restored
1967 112 Round Fender with Model 36 blower
1967 112 Round Fender with Johnson Model 10 Loader
1971 120 with 48 deck and 49 blower and OTC cab
1973 140H3 with 41 deck
1987 318 with 46 deck, 54 blade, 49 blower, 3pt hitch
1987 332 with 46 deck
Smalljob is online now
post #4 of 83 Old 12-25-2018, 10:35 PM
kklowell's Avatar
Can't wait to see what this looks like when you're done!
kklowell is offline
post #5 of 83 Old 12-25-2018, 10:38 PM Thread Starter
cjet69's Avatar
Bill
Hopefully it won't take too much work. I know the engine is good because my brother did an inframe rebuild on it probably 15-20 years ago for our uncle. It was driven around a few times its been sitting in my cousins shop ever since. I will be getting another Farmall tractor project as payment for my work.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #6 of 83 Old 12-25-2018, 11:41 PM
Kish JD 318/420/430
RussKish's Avatar
cjet69, Is that a Delco alternator? If so you may not need a VR, because the VR may be built in. I have a 12 volt conversion on the Farmall A. The ignition is still a magneto though.
Russ
Proud Owner of: 318/420/430
RussKish is online now
post #7 of 83 Old 12-26-2018, 12:33 AM Thread Starter
cjet69's Avatar
It is a Delco but, its not internally regulated(see link). I have one just like it on one of our JD's.
GM Alternator Identification
Name:	100_0783 (Medium).JPG
ID:	2353615   Click image for larger version
Name:	100_0778 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #8 of 83 Old 12-26-2018, 10:10 AM
I'd go with a 10SI Delco off a 1970's to late 80's GM that has a built in regulator..
Those older externally regulated ones are usually only 37 amp or 63 at most,and the regulators are fairly expensive and don't like sitting idle long periods..
That alternator is a pre 1971 version which is getting harder to find used nowadays,and costs more at parts stores than an internally regulated one will..
The one advantage of the externally regulated ones is you can rig one up to make 110V DC by full fielding the regulator and run some tools with AC/DC motors with it..but you can do that with an internally regulated one too..
Tractor-Holic is offline
post #9 of 83 Old 12-26-2018, 01:05 PM Thread Starter
cjet69's Avatar
The way he plans to use the tractor most of the time the charging system will only be used to maintain the battery. Occasionally the lights might get used.
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #10 of 83 Old 12-26-2018, 01:20 PM
Kish JD 318/420/430
RussKish's Avatar
Cjet69, Thank you for the link I will have to go back and double check the A!
Russ
post #11 of 83 Old 12-26-2018, 02:14 PM Thread Starter
cjet69's Avatar
Here is another article on these: https://www.jalopyjournal.com/forum/...p-asap.812606/
Post #8 has a good pic.
And another: older style Delco alternator confusion, 1 wire possible, or not?
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #12 of 83 Old 12-27-2018, 08:15 AM
Collector of many tractors
Kbeitz's Avatar
I'll be watch this post...
I just bought a 350U that's been sitting a few years.
It's just to cold in Pa. to be playing with tractors right now...
I'm sure waiting for spring.
Kbeitz is online now
post #13 of 83 Old 01-07-2019, 08:55 PM Thread Starter
cjet69's Avatar
I made it out to the shop for a bit today. I found some material to make a bushing for the pivot bolt on the alternator bracket. It had a 1/2" pipe welded on and a 3/8" bolt thru it which allowed way to much slop. Now I need to address the tensioner bracket to get it lined up. I had to remove the fan and pulley to access the bolt that holds it in place. The bolt goes into the water jacket so I need to drain the coolant before pulling it out. Looks like I may need to get a longer belt also.
Name:	100_0809 (Medium).JPG
ID:	2355749   Click image for larger version
Name:	100_0806 (Medium).JPG
ID:	2355753   Click image for larger version
Name:	100_0807 (Medium).JPG
ID:	2355755   Click image for larger version
Name:	100_0808 (Medium).JPG
Name:	100_0805 (Medium).JPG
ID:	2355759   Click image for larger version
Name:	100_0804 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #14 of 83 Old 01-22-2019, 08:46 PM Thread Starter
cjet69's Avatar
A couple weeks back I tried to remove the bolts holding the fuel tank. They were really rusty and felt like they were going to break. I've been soaking them in ATF/Acetone every few days and today I tried them again. They all came out with a little working back and forth with out breaking any of them. Now I have good access to the gauges for wiring and can also clean out the fuel tank.
Name:	100_0860 (Medium).JPG
ID:	2358061   Click image for larger version
Name:	100_0862 (Medium).JPG
ID:	2358063   Click image for larger version
Name:	100_0872 (Medium).JPG
ID:	2358065   Click image for larger version
Name:	100_0871 (Medium).JPG
Name:	100_0861 (Medium).JPG
Homelite: CT-10
MTD: 990
Dynamark: 12/38
Bolens: 1050
Case: 444
post #15 of 83 Old 01-22-2019, 09:05 PM
Smalljob's Avatar
I have heard of others having good luck with ATF and acetone. What mixing ratio do you use?
