Shibaura SD220D-0 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 07-04-2019, 10:29 AM Thread Starter
Doc Salvage's Avatar
Shibaura SD220D-0
Alrighty--here we go. Pics to come. This tractor is equipped with solenoid controls for the hydraulic lift. What I am attempting is to either figure out how the things work and repair...or cobble together an override control. I looked at a thousand pics and decided that the Ford 1500 lift surely would bolt straight on to my sd, and got one on ebay. Nope. Not the same dimensions. I'm still going to sit the 1500 lift on it for pics for proof, in case anyone else is thinking about trying it. I'll make all the mistakes so keep an eye on this thread if you have or are thinking about picking up a Shibaura.
Doc Salvage is offline
post #2 of 9 Old 07-04-2019, 08:05 PM Thread Starter
Re: Shibaura SD220D-0
Seat and "tool box" removed--here is a raw pic of the lift from the top. SD2200D-0
Name:	SD2200 lift1.jpg
post #3 of 9 Old 07-04-2019, 08:13 PM Thread Starter
Here is a quickie vid of how the solenoids work
post #4 of 9 Old 07-04-2019, 08:19 PM Thread Starter
We are going to figure this out together. Dad gum it, if somebody made these things, they can be figured out!
Never give up! Never surrender!
post #5 of 9 Old 07-07-2019, 01:48 PM Thread Starter
Got the lift of the tractor this morning. Here's a look at the piston. I think I might need a new seal.
ID:	2385637   Click image for larger version
post #6 of 9 Old 07-14-2019, 12:50 PM Thread Starter
Here's the piston with it's new seal installed. Got a seal from Messicks--SBA050309012, found the part number on New Holland's website. Very nice of them to carry the parts listings on these legacy machines. You can save the listings as a pdf file as well. Has exploded diagrams and all the part numbers. I was going by 1700 tractor, as that one seems to match this 2200 best.
edit--put the seal in a cat food can with some safflower oil, heated it up to 200 in the oven, went on easy.
post #7 of 9 Old 07-14-2019, 12:54 PM Thread Starter
Side by side pic of the lift from the 2200 and the Ford 1500 lift I picked up. The head looks very close--may be the same one, but the base of the lift cover is smaller than the 2200 cover.
post #8 of 9 Old 07-14-2019, 01:25 PM Thread Starter
Tested the ports on the side of the lift with air pressure, after I got the cylinder in and head bolted down. The right port pressure makes the lift rise. The middle one is apparently the "line in" from the pump. Blow air in it, and it comes out of the hole where the steel line from the pump attaches. The left port I think lets the lift down. Air directed to this port is venting into the crankcase as far as I can tell.
Name:	Lift ports.jpg
post #9 of 9 Old 07-20-2019, 03:13 PM Thread Starter
I've got the solenoids taken apart but no pics yet. Drained the hydraulic fluid out this morning. Next step is to get some solvent and clean the oils off the solenoid and lift cover. Test the solenoids coils with a 12 volt source, then hope to find a close enough grey to shoot a coat on before I start bolting back together.
ID:	2387299   Click image for larger version
ID:	2387301   Click image for larger version
