Block heater (what are you using?) - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 24 Old 11-19-2018, 03:03 PM Thread Starter
Still plays with tractors
jas11964's Avatar
Re: Block heater (what are you using?)
Originally Posted by Fiziksgeek View Post
I have the Massey block heater in my GC1720, little pricey, but works great. I plugged it into a wireless switch that I can control from eh warmth of the house. I'm considering adding a small silicone pad heater to the transmission housing. I can warm the engine, but the hydraulic fluid is still cold. I'd like to be able to hope on and go in the winter!
I assume you had your heater installed by the dealer? If you installed it yourself, how in the world did you get it to not leak? I can't get mine to stop leaking so I'm about ready to yank it out and put a new frost plug in. It doesn't leak a lot and only when I either start using it or after it cools down. Maybe that's normal, I just don't know. I'm tired of it and I think I'm going to cut my losses, install a new frost plug and go back to the magnetic heater that I used on my old 1705.
I said I work on them; I never said I fix them!
Jeff
http://picasaweb.google.com/jas11964
1964 Allis Chalmers B10
1966 Allis Chalmers B12 with Hi/Lo
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
1972 Wheelhorse Raider 14
1977 Wheelhorse B100 8 Speed
1942 Speedex Model B
2003 Wheelhorse Classic 315-8
2018 Massey Ferguson GC1720 Tractor/Loader/Backhoe
jas11964 is offline
post #17 of 24 Old 11-19-2018, 07:21 PM
Sorry, mine was dealer installed. I don't know what install methods they used, but it does not leak at all.
Location=Oxford, CT
Equipment:
2010 Stihl BR600 backpack blower
2012 Husqvarna 562XP with 20" and 28" bars
2013 Protero PTO-PV18 collection system.
2014 Wallenstein BXM32
2015 Stihl KM130 with line trimmer and hedge trimmer.
2015 Massey Ferguson GC1720 with 2360 front snowblower and 60" drive over MMM.
Fiziksgeek is offline
post #18 of 24 Old 11-21-2018, 04:15 AM
Rocko's Avatar
I installed my block heater last year, I watched this video then did the install.
I think my muffler bracket was a little different, but I have not had any leaks.
My heater was the same one as in the video, I think the older model heaters had a flat bracket and have a different part number.
I used lithium grease for the install like the video.
I also installed a stick on silicone pan heater for the Hydraulic Fluid.
Massey GC1710
Cub Cadet GT2542
Cub Cadet LT1320
Scag Liberty Z
Echo CS-600P
Dolmar 5100s
Dolmar PS-421
Stihl MS-270
Stihl MS-180C
Stihl MS-171
Homelite 330
Sears 358.355061
Echo PPT-280
MacKissic 12PT1100
Rocko is offline
post #19 of 24 Old 11-21-2018, 06:53 AM Thread Starter
jas11964's Avatar
I also installed a stick on silicone pan heater for the Hydraulic Fluid.https://www.youtube.com/watch?v=D_pulz2KlZw
Did you use any sealant at all? I have the same heater, made for the Massey. I'm thinking that I must have damaged the oring somehow. I know these things can leak but this one has been ridiculous. I watched the same video before I put mine it. Simple, right? I used the lithium grease as well. I may pop it out one more time, go over to NAPA and get an oring or three and see if I can't get this right.
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
jas11964 is offline
post #20 of 24 Old 11-21-2018, 07:59 PM
Rocko's Avatar
I did not use any sealant.
Check for scratches or burrs in the knockout plug hole.
Check the O-ring out with a magnifying glass.
If Napa doesn't have a high temp o-ring that size, check out Mcmaster Carr.
Maybe try an o-ring a little thicker or a larger OD
Massey GC1710
Cub Cadet GT2542
Cub Cadet LT1320
Scag Liberty Z
Echo CS-600P
Dolmar 5100s
Dolmar PS-421
Stihl MS-270
Stihl MS-180C
Stihl MS-171
Homelite 330
Sears 358.355061
Echo PPT-280
MacKissic 12PT1100
Rocko is offline
post #21 of 24 Old 01-14-2019, 01:03 PM Thread Starter
jas11964's Avatar
Well, as a follow up to all this mess, I did end up sticking with this heater and I'm sure glad I did. I ordered some new o'rings for it (a couple, just in case) along with the new freeze plug (again, just in case). I also found out the correct sealant to use so I was prepared to go to war. Once I removed the heater, I saw the problem. The o'ring was pinched and deformed in the hole and couldn't seal. It always did fit rather loose. The new o'rings fit much better and once I slid it into the hole, I knew it would work. It was a completely different fit. It just felt right. No leaks now and I gotta say, I love the heater. I plug it in for 30 minutes prior to using the tractor and the thing starts like it's summer. This also resulted in the operating temperature going back up to where it should be. In this case, a little patience went a long way. I'm in PA and bought the tractor in PA but I want to give a big shout out to Jason at Roudebush Equipment in Westfield, IN. I bought the heater from him. He worked with me (put up with me) and helped me get this right along with setting me up with the right sealer and parts for success. Now I'm ready for the snow we're supposed to get this coming weekend. Thanks for everyone's input and I hope this helps someone else.
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
jas11964 is offline
post #22 of 24 Old 01-16-2019, 07:22 AM
L120/G110 Hybridizer
ryanpf's Avatar
Just so the rest of us know, what was the "correct" sealer that worked for you?
Massey GC1710 - A little red diesel with a loader in front, a backhoe in the rear and a big smile in the middle -
John Deere L120/K66 with Berco 30" tiller, John Deere 44" Snowblower, Johnny Products Sleeve Hitch and
JB Jr bucket. Plus Brinly-Hardy 10" plow, 7-Tine Cultivator, 40" Plug Aerator, 40" Dethatcher, E-I-E-I-O...
ryanpf is offline
post #23 of 24 Old 01-16-2019, 07:53 AM Thread Starter
jas11964's Avatar
Yeah, I guess that would help. It was so simple, I feel stupid. I tried other sealants and this is the one that worked and the one that the dealership uses. Permatex water pump & thermostat housing gasket maker.
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
jas11964 is offline
post #24 of 24 Old 01-18-2019, 04:53 AM
Rocko's Avatar
Glad to hear you got it sorted out.
Massey GC1710
Cub Cadet GT2542
Cub Cadet LT1320
Scag Liberty Z
Echo CS-600P
Dolmar 5100s
Dolmar PS-421
Stihl MS-270
Stihl MS-180C
Stihl MS-171
Homelite 330
Sears 358.355061
Echo PPT-280
MacKissic 12PT1100
Rocko is offline
