Had a few issues lately - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 04-14-2019, 12:28 AM Thread Starter
Last week while putting the deck on I noticed a bar hanging off the left side of my bx under the PTO controls. After some investigating I figured out it was the arm that goes from the diff lock pedal to the diff. It was just dangling from the pedal. I pulled it off and figured I would fix it later. Next, while putting the deck on I discovered that the deck PTO shaft had seize up and I had to beat the hell out of it and then grease it up once I got it apart. Today I went to take the loader off and noticed that the kickstand had the loader sitting crooked. At first I assumed I was on unlevel ground but after moving it still wasn't right. I finally got it off then realized I needed the loader so I could put the deck on and pulled back over to the loader. I had one hell of a time getting it back on. The right side just wouldn't lay into the cradle right. It was at this point I discovered that the left bar on the kickstand was missing the c clip that kept it attached to the pin (why they used c clips instead of a cotter pin I have no idea) was missing and this is why things were crooked. After some wrestling I got the loader back on. I didn't have any c clips on hand so a piece of copper wire twisted tight served to hold it temporarily.
The diff lock bar doesn't seem to be a big deal. I did stop by the dealer and they said if I couldn't get it back in place they would come out and do it. I will probably order the c clip eventually. I might pick up one at the hardware store for a temp fix... I know the copper won't hold forever.
All pretty minor stuff but just a little annoying.
Sent from my XT1635-01 using Tapatalk
chrispbrown27 is offline
post #2 of 5 Old 04-14-2019, 11:40 AM
We're all friends here
APinNY's Avatar
Re: Had a few issues lately
Glad you were able t get it all figured out, Chris. I've never heard of the deck PTO shaft seizing up, but I guess it happens. I guess I should check things under the tractor more often but if parts haven't fallen off by now, they probably won't...I hope.
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL w/ bucket hooks, snow thrower, cab, Heavy Hitch
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #3 of 5 Old 04-14-2019, 09:59 PM
Chris, sorry to hear about your troubles, normally people down have problems with them. I put some hours on mine this weekend doing yard work. Mine has cotter pins on the loader stand and most other things, never had a anything come off, 9 years old. The PTO ceasing up is odd, where are you storing? Someplace where moisture can get to it? if so, probably should grease stuff more., I grease the shaft splines and u-joints regularly.
Next time you have loader mount issues, shim the back tires to make the tractor tilt the same as the loader, itíll go right on. I use pieces of scrap wood or anything you can run over, sometimes I use my wifeís shoes.
orangetractor is offline
post #4 of 5 Old 04-15-2019, 07:13 AM
rudedawg's Avatar
Undoubtedly your not saying when feet get that long they call them yards?
rudedawg is offline
post #5 of 5 Old 04-15-2019, 09:18 AM
Machinery enthusiast
Volfandt's Avatar
Hope her feets still ain't in them... LOL.
https://www.mytractorforum.com/showth...highlight=BX23,
1966 Wheel Horse 856, Gear.
1966 Wheel Horse 876, HST.
https://mytractorforum.com/showthread...hlight=856,876
Volfandt is offline
JD X500 Issues POLL Alien5044 John Deere Forum 7 10-28-2018 09:11 AM
John Deere 455 fuel issues? Ksolem1224 Backyard Round Table - L & G Tractor Related Topics 6 10-23-2018 09:18 PM
430 Charging and overheating issues wcsok913 John Deere Forum 9 10-03-2018 07:20 PM
What should I fix/replace to solve power issues binarywhisper Ford/Post 1990 New Holland 1 08-26-2018 07:07 AM
Blade Belt issues with 2013 Troy-Bilt (MTD) mower KArthur MTD 10 07-18-2018 10:15 PM
