2305 Battery? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 09-09-2019, 02:36 PM Thread Starter
Curly69's Avatar
2305 Battery?
What are ya guys using for a battery. The closest JD dealer wants nearly $180.00, next closest dealer is about 50 min away.
I tried a few local auto stores but nothing physically matches and there isn't much room. Last one was $135.00 but again an hour drive into SC.
DON'T ASK, NO TOOLS LOANED
JD 2305
200X FEL
60" K-K R.D. Finish Mower
Pittsburgh/Taylor-Way Tiller
EMCO Auger 9" bit
5' Pittsburgh Scrape Blade
48" Cultivator / Hiller
Homelite SuperXL Automatic 33yrs old
Homelite Super XL 38 yrs and still humming
Homelite XL-12 40 yrs
Homelite XL 36 yrs and humming away
Echo weedeater SRM251E
TroyBilt Log Splitter
Curly69 is offline
post #2 of 6 Old 09-09-2019, 08:09 PM
JeffBen's Avatar
Re: 2305 Battery?
Mine still has original. I just did a quick search and yep your right very expensive. Im going to have to baby mine even more knowing this.
JeffBen is online now
post #3 of 6 Old 09-09-2019, 09:18 PM
Re: 2305 Battery?
I replaced mine about five years ago with the JD Strong Box. Expensive up front but it has earned its keep.
JD 2305, 200CX FEL, 62C MMM, Weight Box, Heavy Hitch Hitch'n Can, Pat's Easy Change, BroTek Skid Plate, Funk Workz drawbar stabilizer and 2" reciever
BamaJDFan is online now
post #4 of 6 Old 09-09-2019, 09:42 PM
10 fingers 10 toes
Kubota Ronin's Avatar
Re: 2305 Battery?
Remember you're looking for CCA and terminal compatibility rather than physical size... a smaller case battery may well provide sufficient power.
Is there a size/CCA designation stamped into the battery itself?
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #5 of 6 Old 09-11-2019, 01:36 PM
Re: 2305 Battery?
The thing to do is to actually measure the place where the battery is going to sit. You want the dimensions in width, length and height in either inches or in millimeters. Then use the chart below to find a battery group size that will fit into the space that you measured.
You do want to get the same, or greater Cold Cranking Amps (CCA) as the one that you are replacing.
https://www.jegs.com/Sizecharts/bcigroup.html
Flaken is online now
post #6 of 6 Old 09-12-2019, 09:35 AM
c5rulz's Avatar
Re: 2305 Battery?
Last week I had a big job to do, spreading 3,500#s of fertilizer with the 3 point spreader. Went to start the 2305 and the 9 year old Farm & Fleet battery took a dump. Wouldn't even crank with the 50 amp booster charger.
Soooo............being in a big hurry was an understatement. Went to Farm and Fleet and they didn't have the same one in stock so in desperation I took a 22FS. The height, width and posts and polarity were correct it was about a 1/2" wider so I thought "no big deal". Well it was. Had to modify a bracket where the hood latch passes. Dicked around 2.5 hours and the positive terminal broke when I cleaned it up. Had to use a hose clamp to keep it on. Got the job done though.
This 540 CCA battery was $80.
John Deere should be ashamed of their price for parts that are inferior. The OEM JD battery lasted 4 years.
JD X758 60" HC deck
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Echo PPT-266 pole saw
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
c5rulz is offline
