1023e leaking hyd oil on left side - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 2 Old 04-21-2019, 10:25 PM Thread Starter
CRL
Has anyone been having any problems of leaking hyd oil from upper left side. Looks to be coming from the range selector H N L that goes into transmission. Leaks down and under hydro case. Tried tighting hydro fittings that go into transmission and all seem tight. I appears Deere used some type of silicone gasket on this tractor that isnt holding up. I've replaced both front hub seals over the past couple years for they were leaking oil out the front differential. Any recalls on this issue??
crlacy1228 is offline
post #2 of 2 Old 04-23-2019, 08:12 AM
martincom's Avatar
Re: 1023e leaking hyd oil on left side
The transaxle filter is near there. Is the filter leaking?
2017 1025R TLB & 2017 1025R FEL
2*54 Mower Decks w/Independent Lift
2*47 Snow Blowers
2*Cozy Cab
2*Heavy Hitch Receiver Hitch w/Dual Suitcase Weight Brackets, Storage Cart, & 1*Front Suitcase Weight Bracket
50" Wicked Root Grapple
Land Pride LR1560 Land Rake w/ wide gauge wheels & plow blade
BXpanded Backhoe Dolly
MCS20 Leaf/clippings hopper
647 Tiller
2001 455 AWS & 1999 455 AWS--Both Sold
martincom is offline
John Deere gt235 18hp Kawasaki leaking oil Skfauser John Deere Forum 7 07-29-2018 05:45 PM
X500 oil change - ARGGH! So mad at myself! newtomeX500 John Deere Forum 26 03-15-2018 11:58 PM
Left side brakes on 400 grandpajay John Deere Forum 18 10-13-2017 03:29 AM
What to use for Bar & Chain Oil? hotajax Chain Saws 46 05-07-2013 09:17 AM
2011 JD z425 hydro oil changing procedures dlb118 John Deere Forum 1 11-25-2012 03:01 PM
