BARN FIND! Whats it worth? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 12-05-2015, 03:28 PM Thread Starter
Had an oppertunity to check out a small tractor that I have been working on the owner to sell me to sell locally for some time. It was stored under cover in lean to. Has not been run in a couple years. Went over to check it out today. Brought a battery. It fired right up and ran great.
Heres the info
Cub Cadet 7205 Diesel 3 cyl 780 hours with loader 4x4 Power steering.
Dusty but runs well. Lights did not seem to work. Def needs a clean up and fluid / filter / service and maybe some fresh paint. I ran it for a bit nice and easy and everything seemed to work well oil was clean and machine operated well. Tires has some minor dry cracking nothing major. Front loader pistons had some minor rust that seemed to come off when I rubbed it maybe some light steel wool to clean them up?
Seems like a cool little tractor to do light work with maybe move some snow and brush etc. So whats it worth? Is it a good machine? What should I look for besides the obvious leaks and such.
ID:	1502417   Click image for larger version
ID:	1502425   Click image for larger version
ID:	1502433   Click image for larger version
ID:	1502449   Click image for larger version
ID:	1502457   Click image for larger version
mrmrules is offline
post #2 of 9 Old 12-05-2015, 10:14 PM
Senior Moment
Greybeard09's Avatar
Re: BARN FIND! Whats it worth?
Don't know what it's worth... but now I want it too.
Late 50's Bready... aka, "The WoodRat"
1969 John Deere 110 w/front blade
1998-99 MTD/AYP "Black Thing" 18hp Briggs MUTT-Mower
2002 Cub Cadet 2166 (in process)
2006 Cub Cadet GT2544
2011 Cub Cadet Z-Force S 48
Greybeard09 is offline
post #3 of 9 Old 12-06-2015, 08:56 AM
Gravely1964
gravely1964's Avatar
Don't have a clue on what its worth.
Only know issues to me are drive shaft and pump related issues. Make sure you make the drive shaft longer if it hasn't already been done The drive shaft were to short and hardly engaged the splines. They'ed striped the splines and the drive shaft would slide off under load. It is not pretty when they do Cub junked many with less that 50hrs because of the issues
So just check and make sure, but with that many hrs im sure its fine. But to me looks in pretty good shape
Best of luck getting it, and hope somebody has an idea on value. I'd guess 4 G's or less on a dealers lot. That is just a thought though
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is offline
post #4 of 9 Old 12-06-2015, 09:51 AM
10,000 +posts!
glenn27's Avatar
Wow--nice find--looks like a solid little tractor. Is that the only accessory--The FEL?
Maybe offer $ 3,200, if you know this person good...Not too low--don't insult, but not high enough to burn you out, either. You are going to have to spend some $$getting her back in good running order. I'd be all over that one after a careful check-over.
PS--You no , I have uttered this before when I see things like this--WHY in the world would a machine like that just sit, at least covered up??
I know--situations and times change, but ??
glenn
Jimmy Buffett
glenn27 is offline
post #5 of 9 Old 12-06-2015, 12:12 PM
Professional Homeowner
steddy's Avatar
$6500 would likely be a low fair asking price on Craigslist around here.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
steddy is offline
post #6 of 9 Old 12-06-2015, 12:15 PM
there,s another one that i need.that,s 3500 all day long stripped spline or not. if it were closer i,d be looking at that one.for sure.
gray wolf is offline
post #7 of 9 Old 12-11-2015, 11:50 AM Thread Starter
I ended up buying it with a landscape trailer the other day guys I will post a few more pics. Its a cool little machine!!
mrmrules is offline
post #8 of 9 Old 12-11-2015, 11:54 AM Thread Starter
Here is me the day I got it leaving and then at home after I washed it I tried it out moving a pile of brush!
ID:	1508609   Click image for larger version
mrmrules is offline
post #9 of 9 Old 12-11-2015, 11:56 AM Thread Starter
I want to change the oil and filter asap since its been sitting. Anyone know where I can download a manual online or buy one? Thanks
mrmrules is offline
