Help with box blade ID - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 09-25-2019, 09:58 PM Thread Starter
KCFLY's Avatar
Hello everyone.
I recently purchased my first tractor, a JD 2025R. Its the older style.
Anyway, I just picked up a box blade for super cheap. It's in great shape, but has no identifying marks on it. It did not come with any rippers. Can anyone help ID this and/or give me any info on what type of rippers to buy and where I can find the best pricing?
Added picture of tractor. I know you guys love pictures.
Thanks!
ID:	2397539   Click image for larger version
-Brad
JD 2025r wMMM and Loader
JD GT235 w/48C, PowerFlo, & front dethatcher
42" blade, and 42" snowthrower
2 105 lb. cast wheel weights
JD 757 ZeroTurn w/60 deck
JD L120
KCFLY is offline
post #2 of 4 Old 09-29-2019, 11:45 AM
AKA Moses Lawnagan
KHodges's Avatar
Re: Help with box blade ID
I've looked at a ton of pictures, but haven't seen anything with the combination of lower lift bar mount and strap frame like the one you have. How wide is it, 5 foot, maybe?
At any rate, you should be able to order ripper shanks from someone like Agri Supply that would work with it. Measure from the top of the ripper bar to the bottom of the box and get shanks that would have the bottom hole about 2-3 inches longer distance then that from the bottom of the ripper tooth. All the box blades I saw have a small inverted "V piece of angle welded on either side of the slot for the ripper, to secure the pin that holds the ripper in place (like in the picture below). You might have to get that done.
Very nice machine you just bought, enjoy. I just traded up from an X7 to a 2520, basically an older version of your tractor.
Name:	box blade 006 (2).jpg
'09 JD 2520, CX200 loader and 62D deck
LP RTR0550 rototiller
?? 60" box blade
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
'08 X748SE, gone but not forgotten
KHodges is offline
post #3 of 4 Old 09-30-2019, 07:44 PM
wnyguy's Avatar
Ripper shanks are pretty common from an Ag store. You'll have to probably acquire the clip type vs the pin through type immediately above.
https://www.agrisupply.com/box-blade...saAhP9EALw_wcB
https://www.ebay.com/i/262140323313?...YaAtydEALw_wcB
Sent from my Pixel 3 XL using Tapatalk
wnyguy is offline
post #4 of 4 Old 11-06-2019, 03:42 PM Thread Starter
KCFLY's Avatar
Well, thanks to you both for your input. I think it may be a LandPride based on this photo I found.
I guess I need to order some rippers
Thanks again!
-Brad
JD L120
KCFLY is offline
