Getting rid of stumps - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Shed General Discussion of SCUT Tractors
post #1 of 44 Old 03-25-2019, 11:29 PM Thread Starter
Ok, so this isn't scut specific but I thought I would ask. The previous owner cut down five trees at some point. You can see that they had tried to burn the stumps out, but like a lot of what they did they didn't put much effort into it. I have started the process of burning the one at the edge of the driveway but it's slow going. So far a little diesel fuel and charcoal and sticks piled up have worked the best but the rain last night killed the smoldering fire I had going. I used my bx to dig out around the stump but it certainly doesn't have the testicles to dig the stump out. So what do you guys do? This stump is sitting right where I am planning on building the garage so I need it gone soon.
Sent from my XT1635-01 using Tapatalk
chrispbrown27 is offline
post #2 of 44 Old 03-26-2019, 02:34 AM
20,000 Posts & Climbing
Re: Getting rid of stumps
Pics?
Digging a stump out depends on the size of stump. I've found that the hoe on my MF GC2310 can break the roots if you dig the equivalent of 3 stump diameters away from the stump. That can still leave a big root ball with associated dirt on a big stump. A garden hose or pressure washer works great for reducing the amount of dirt on the root ball to make it lighter and offer places to hook a chain to pull it out.
Note that a hoe can pull harder than the tractor that it is attached to, and the bucket of the hoe will pull the most. The bucket cylinder will pull about 4000 lb for the length of its stroke when the rod end is connected to the chain.
Note: Chain, not tow strap. You don't want a slingshot!
TUDOR is offline
post #3 of 44 Old 03-26-2019, 02:37 AM
Rent a stump grinder. I've taken out over a hundred stumps. There is no easier way.
Dee_Veloper is offline
post #4 of 44 Old 03-26-2019, 02:45 AM
Blank Space
All about the size of the stump and type of wood. I've dug a few out, but nothing over about 12" diameter or so. Smaller ones I just cut off at the surface and mow over them.
If you're talking about something 20" or more, you'll need a bigger machine. Or a lot more time. Some will bore 1" holes with a wood auger bit on a drill, then drop stump rotting chemicals in and let them work for a year. Supposedly they degrade the wood to make it easily to break up.
Sent with my great fat fingers and a real keyboard, no tappity-tap stuff
Obscured_by_Clouds is offline
post #5 of 44 Old 03-26-2019, 06:14 AM
Pour salt brine all over it and let the porkies have at it
wooserco is offline
post #6 of 44 Old 03-26-2019, 07:07 AM
Cat385B's Avatar
Since youíre building over that spot, it needs to be removed completely. Continue to dig out around it until you are able to pull it out.
Cat385B is offline
post #7 of 44 Old 03-26-2019, 07:59 AM
55 gallon metal barrel placed around and over stump. Saturate with diesel 2-3 times per week and place lid or other covering after saturating. After one month, build a fire inside metal barrel with stump in it. Several bags of cheap charcoal work quite well. You want the fire & heat contained right around the stump. This will burn and smolder for several days as the stump and roots are consumed. Fill barrel with nearby wood debris, easy way to clean up area. After heat is gone, remove barrel and fill ash filled hole with suitable material.
Or rent a large tracked stump grinder, 25 -35 HP, for about $1,000 a week and do all of them in that time.
Flaken is online now
post #8 of 44 Old 03-26-2019, 10:07 AM
Agreed 100%. If you are building over this stump, it needs to be gone completely. They you'll need to thoroughly compact any fill used, otherwise you risk settling at some point down the road.
TWG1572 is online now
post #9 of 44 Old 03-26-2019, 10:58 AM
Once ground below the root ball, then use your loader to remove ALL the chips and roots.
And then fill and compact. And I'd still let it sit a year or so just in case.
Rent a stump grinder. There is no easier way.
Dan
Bolens / TroyBilt GTX20
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is offline
post #10 of 44 Old 03-26-2019, 11:22 AM Thread Starter
The stump sits just outside of where I will be building. The roots might be of a bigger concern than the actual stump as far as the building goes.
It's hard to tell from the picture but the stump is probably two feet across and I believe it is oak.
post #11 of 44 Old 03-26-2019, 01:49 PM
Blank Space
If you've already dug that far, keep digging. Use a chain saw to section the stump and cut it out in pieces. Once you get it below the surface, fill and compact the hole, but be aware it may settle over time. If you're not building over top of it, settling will be less of an issue.
post #12 of 44 Old 03-26-2019, 02:52 PM
Rocko's Avatar
I took out a massive oak stump a couple years ago, about 36 inch dia.
Like Obscured said, I sectioned the stump with a chainsaw.
I had a HUGE hole dug around the stump to break/cut the roots.
I also used a dewalt 20v sawzall with a pruning blade on some roots, an axe, lots of sharpened chains for the chainsaw, as soon as a chain got dull I swapped it out...I think that when I got my HF chainsaw sharpener.
There were alot of large TAP roots off roots.
Thee roots had grown around a very large rock also, but that came out early in the battle.
Cleaned out the nooks and crannies with an old paint brush, long cold chisels, pry bar, crow bars to get stones out.
Some times I had to partially fill the hole in to get a good position for the Back Hoe.
When I finally broke the stump free, I had to dig a ramp to drag it out of the hole.
I get to burn that tree in the wood stove next season.
Massey GC1710
Cub Cadet GT2542
Cub Cadet LT1320
Scag Liberty Z
Echo CS-600P
Dolmar 5100s
Dolmar PS-421
Stihl MS-270
Stihl MS-180C
Stihl MS-171
Homelite 330
Sears 358.355061
Echo PPT-280
MacKissic 12PT1100
Rocko is offline
post #13 of 44 Old 03-26-2019, 06:55 PM
I've done this with good results but I had a center section from those large wire spools. Same idea just larger diameter. I laid 5-6 bricks around to get it an inch or so off the ground for air flow.
It would burn for days then you'd see roots burning underground.
Sent from my Bell Rotary
Sevenhills1952 is online now
post #14 of 44 Old 03-26-2019, 07:24 PM
sonny's Avatar
This is what I use----bought it 2 years ago and still chompin stumps!
http://machinebuildersnetwork.com/
sonny is offline
post #15 of 44 Old 03-26-2019, 07:39 PM
The Admin from... Nowhere
littletractorguy's Avatar
Yeah, depends on what your time is worth, and how soon the garage project is starting... Stump grinder rental is definitely $$$, but boy its fun, and then the thing is gone... Or at least the main chunk of the stump. If you need the roots gone, you can chase them with the stump grinder, or you can try all the other long-term decaying methods. I like either the stump grinder or my chainsaw or my sawzall with a 8" wood blade on it..
littletractorguy is offline
Two stumps to remove Square Dude Landscape and Yard Discussions 9 05-16-2018 02:29 PM
Picked up a cheap YTS3000.... get rid of it fast? tonythemediaguy Backyard Round Table - L & G Tractor Related Topics 5 05-08-2018 05:05 AM
JD 317 - Get rid of 49 series blower for blade? narlycharley John Deere Forum 20 01-20-2018 06:04 AM
JD318 Powered up/down Snow Blower Chute - got rid of that manual knob! forrestbeagle John Deere Forum 18 02-13-2013 06:56 AM
