Getting rid of stumps - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Shed General Discussion of SCUT Tractors
post #16 of 41 Old 03-26-2019, 08:55 PM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Re: Getting rid of stumps
The Gents who have rented and used stump grinders would never even consider going about stump removal any other way, unless maybe you own a heavy equipment company.
A $100 daily rental fee, or even $200 for a weekend and a whole lot of your stumps will be history.
This pic is just to show there is no stump too big. It measured about 60" across at 3' high, and 8' across the exposed roots, right at the ground. I had been quoted $800 (a hundred bucks a foot) to remove it.
.Click image for larger version
Name:	Stumos and flower pots removed 004.JPG
ID:	2368245Click image for larger version
Name:	Loader, grinder and stump gone 006.JPG
In the first pic I had already ground out and backfilled the surface root runners for better access.
The stump was then chainsawed off about 1' above the surface and I used my 13hp Rayco grinder to remove everything to atleast 1' below the surface.
Admittedly, that particular stump took this old man all day, including hand loading about 20 bucketfuls of grinding chips for transport to the compost pile, and backfilling the hole with topsoil.
This grinder is my own, but if you rent one, just be sure it has been recently sharpened "before" you take it home.
Larry ( in Southern Ontario )
Last edited by Larry LGT 165; 03-26-2019 at 09:21 PM. Reason: corrected price per foot
Larry LGT 165 is online now
post #17 of 41 Old 03-26-2019, 09:41 PM
This is what I used to get rid of those 100+ stumps on my property. Some of them were over 3' diameter at the top and 4-5 ft at the bottom.
Bluebird, 11-hp, 14" wheel
Dee_Veloper is online now
post #18 of 41 Old 03-26-2019, 10:33 PM
Attachment 2368301
Looks very similar. Not sure what size the cutting wheel is but this Rayco does seem to have a much heavier wheel than the ones you see at the rental places. Takes it a few seconds to get up to speed, but then never slows down while cutting.
8 cutters, 4 each side and it loves wood.
Pic was taken before I removed and sharpened them
Name:	Ryan stump grinder overhaul 012.JPG
ID:	2368379Click image for larger version
Name:	stump ground out 006.JPG
post #19 of 41 Old 04-21-2019, 10:29 PM
forkz
forkz's Avatar
take an old 3/4 or bigger drillm bit full of holes soak with used motor oil let soak in burn it
country in her soul but she loves to rock n roll charlie daniels
forkz is offline
post #20 of 41 Old 04-21-2019, 10:42 PM
I slice big cuts in them with chainsaw then soak with the oil I get from riding mowers that the fuel has flooded the crankcase and burn them several times then hit with sledge hammer.
TobyU is offline
post #21 of 41 Old 04-22-2019, 10:53 AM
I read in an old Popular Mechanic's encyclopedia if you drill many holes in the stump and pour Saltpeter into the holes,it will rot and decompose rapidly..
Too bad I don't know what the heck "Saltpeter" is !..
Ok--quick google research says its Potassium Nitrate,used in fertilizers and explosives..
Hmmm..buy any of that,and I'll be put on a terror watch list probably..
I have quite a few stumps I'd like to get rid of,cant burn them where they are located...and I'm not up to doing it by hand,neither is any of my equipment..
I have a half dozen old working push mowers..was tempted to try making one into a stump grinder,using an old cars manual transmission flywheel with teeth bolted on where the pressure plate used to mount..but it would be easier to just rent one I suppose..
Been thinking about buying a 12,000 lb winch and yank them out with that & some snatch block pulleys for more pulling force..most of the stumps are under 6" in diameter..I can use the winch for other things on my truck and yard work too..
Tractor-Holic is offline
post #22 of 41 Old 04-22-2019, 06:16 PM
...most of the stumps are under 6" in diameter
Rent a grinder...5 minutes per stump and you're done.
post #23 of 41 Old 04-22-2019, 09:15 PM
I like Tractor-holics idea but it tends to attract unwanted attention in urban areas. The least labor intensive method I have seen is the barrel dropped over the stump, soak it with used oil, contaminated diesel what have you then let it smoulder.
RoyM is offline
post #24 of 41 Old 04-23-2019, 10:32 AM
Back in the good old days you could just blow them up with TNT!..
post #25 of 41 Old 04-24-2019, 01:45 PM
I ground a big stump in my front yard 4 years ago. Went down about a foot, cleaned out chips and refilled with good soil, replanted lawn.
Every year, it still settles. Wood left in ground will rot and it will settle. OK if your lawn is only thing resting on it.
If I were building on top, I'd use or rent a back hoe, dig down the sides, chop off any spreading roots and pull the stump out. Then back fill, tamping down real good every 6 inches of back fill.
You don't want to see concrete floor cracks a year or two after your garage is built. Then you'd be in for some REAL costs!! Footings are to be placed only atop undisturbed ground, and any settling below a slab, is going to leave a weak spot just waiting for that car or tractor tire to collapse it.
Unless it is just out in the yard, pull the stump out. Luck has a habit of running out just when the concrete job is complete.
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is offline
post #26 of 41 Old 04-24-2019, 09:20 PM
Country1966?'s Avatar
Country1966? is offline
post #27 of 41 Old 04-25-2019, 02:14 PM
forkz
forkz's Avatar
i drilled mine full of 3/4 inch holes let the oil soak in kert pouring oil in a couple weeks they smoldered awhile
forkz is offline
post #28 of 41 Old 04-26-2019, 11:44 AM
I got one of these :-)
Its good at grinding pretty much anything down to a few inches below the surface, well apart from rocks, it doesn't like rocks
PlugnPlay is offline
post #29 of 41 Old 04-26-2019, 08:44 PM
Professional Homeowner
steddy's Avatar
Hey can you drop that rig off at my house please?
steddy is online now
post #30 of 41 Old 04-26-2019, 09:58 PM
I got one of these 🙂
You Canadians have all the cool stuff. SnowCats, snowmobiles, awesome fishing, snow and not rain & [email protected]$$ stump grinders.
Two stumps to remove Square Dude Landscape and Yard Discussions 9 05-16-2018 02:29 PM
Picked up a cheap YTS3000.... get rid of it fast? tonythemediaguy Backyard Round Table - L & G Tractor Related Topics 5 05-08-2018 05:05 AM
JD 317 - Get rid of 49 series blower for blade? narlycharley John Deere Forum 20 01-20-2018 06:04 AM
JD318 Powered up/down Snow Blower Chute - got rid of that manual knob! forrestbeagle John Deere Forum 18 02-13-2013 06:56 AM
