Jd 316 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Shed General Discussion of SCUT Tractors
post #1 of 9 Old 02-21-2019, 11:28 AM Thread Starter
Jd 316
I have a JD 316 with the Koehler engine and I cannot get it to turn over. I bought a new battery new starter and new battery leads I have 12volts to the starter but it will not even crank over not even a click. I got it running yesterday after replacing all that but now have the same problem. Ive checked the ignition switch and neutral switch both are working fine but have ordered new ones anyway. There is no safety switch on the seat. Any ideas on what I could do greatly appreciated thanks
Sswadling is offline
post #2 of 9 Old 02-21-2019, 12:02 PM
PeterE's Avatar
Re: Jd 316
Is there a safety on the PTO switch?
PeterE is offline
post #3 of 9 Old 02-21-2019, 12:29 PM
MARK (LI)'s Avatar
Re: Jd 316
ok...you have 12 volts to the starter..I am assuming that you are testing the heavy cable directly from the battery...the other wire ( usually purple on a JD ...could be red) that brings power to the solenoid when the key is turned to "start"...did you test that line..with key in start position?....also check where this other wire comes from the battery and connects to circuit breaker...I have seen that 90* connector break off inside the boot that covers the connector on the breaker
MARK (LI) is online now
post #4 of 9 Old 02-21-2019, 06:33 PM Thread Starter
I really don’t know. I bought it about a year ago and it was starting fine. the PTO seems to run whether the switch is up or down.
post #5 of 9 Old 02-21-2019, 06:38 PM
burned300's Avatar
Re: Jd 316
Were is ground cable connected to engine?
1970 112
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #6 of 9 Old 02-22-2019, 02:55 AM Thread Starter
Mark I’ll check that when I get back home thanks.
post #7 of 9 Old 02-22-2019, 02:57 AM Thread Starter
Burned 300 it is connected to the top right side just in front of the air cleaner
post #8 of 9 Old 04-02-2019, 09:01 PM
I don't know if you have fixed it yet but I had a similar thing happened to my 316, I had been working it all morning and shut it down to take a break and when I went to start it back up nothing, no lights on the dash nothing, then I happened to jiggle the pto switch off and on a few times retuned it to the off position and wala,it fired right up and hasn't done it since.
Ronbuff is offline
post #9 of 9 Old 04-04-2019, 02:40 AM
Re: Jd 316
I had a 316 with same symptoms. New ignition switch solved problem.
Alderman is offline
316 surprise portajon John Deere Forum 5 10-28-2018 03:53 PM
316 carb plate stormdog John Deere Forum 0 07-01-2018 09:28 AM
214 or 316 disco_kai John Deere Forum 8 04-29-2018 10:11 PM
420 blade on 316? cccaton John Deere Forum 9 12-29-2012 06:20 PM
