harbor freight tire changer - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Tool Reviews Mechanic's Tools, Gardening Tools, Carpentry Tools, Etc. This is the place to tell us what you think!
post #1 of 21 Old 02-04-2014, 08:53 AM Thread Starter
FileL's Avatar
I'm fairly new here, an auto mechanic all my life... was needing to install new front tires on the 317 and only had flat irons, and just couldn't get the bead broke loose . . . so checking Harbor Freight - I now have a bead breaker for motorcycle tires that works great on lawntractor tires (with alittle patience), and a manual type tire machine. (similar to the full size manual machine I used as a young man at the local gas station in the 60"s) tire machine is light weight = won't take a lot of abuse = but I've got mine done with ease..... got some fairly severe dry rot on the rears.. that'll be next... gonna load the rears soon, so be installing tubes and WWFluid maybe this weekend... look into the Harbor Freight tire machine if your lookin for any easier way to get er done..... price was great also.......
FileL is offline
post #2 of 21 Old 02-04-2014, 08:56 AM
k91
Re: harbor freight tire changer
Have the same one. Works well on the bigger tires not so much on smaller ones. Bead breaker sure does come in handy. Welcome to MTF BTW
1967 John Deere 110H
19? John Deere 332
k91 is offline
post #3 of 21 Old 02-04-2014, 09:11 AM Thread Starter
FileL's Avatar
thanks K91.... amazin site.... was wonderin if the tool will work on the rears..... worked great on the fronts..... I've changed four fronts on my 317 and an older cub cadet I have. just gotta keep the bead lubricated heavily...
FileL is offline
post #4 of 21 Old 02-04-2014, 09:23 AM
I bought one and used it to mount the new tires front and rear on my 110 RF. I made an adapter to make it easier to do the fronts and made rubber pads to keep from scratching the wheels after I painted them
Name:	Tire changer adapter II 7 11 13 resized.jpg
ID:	664466   Click image for larger version
Name:	Tire changer adapter 7 11 13 resized.jpg
ID:	664474   Click image for larger version
Name:	Tire changer 5 17 13 resized.jpg
ID:	664482   Click image for larger version
Name:	Tire changer II 5 17 13 resized.jpg
Name:	Tire machune pads resized.jpg
ID:	664498   Click image for larger version
Name:	Tire machine pads II resized.jpg
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 8 JD suitcase weights. 2-50# cast rear wheel weights. 4 home made 63# wheel weights. Front fork frame for 45 loader.
197? Economy Power King Model 1614 with tandem transmissions, hydraulics and 3PH and 48" mower deck.
Thread for 110 RF build https://www.mytractorforum.com/12-john-deere-forum/287161-66-110-rf-rebuild.html
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Pro Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is offline
post #5 of 21 Old 02-04-2014, 09:40 AM Thread Starter
FileL's Avatar
larry,, didn't get the one you've posted... didn't even see it available... wish I had..... now I gotta reshop..... mine is smaller - lots.... I mount it onto my shopmate ... the bead breaker is a separate tool. thanks for the reply.
FileL is offline
post #6 of 21 Old 02-04-2014, 09:42 AM
jgayman's Avatar
I have one of these. It will work on tires of all sizes and you can store it right in your tool box. Pushes the bead over that pesky inner ring.
Name:	Bead Buster.jpg
jgayman is offline
post #7 of 21 Old 02-04-2014, 09:47 AM
k91
Ahh FileL I have the one like Larry does. Maybe you got the ATV one? I thought about making an adapter like you did Larry or maybe getting a piece of all thread to put in it but for now I just chuck a piece of pipe in my vise for small tires
19? John Deere 332
k91 is offline
post #8 of 21 Old 02-04-2014, 10:02 AM
aquist06's Avatar
I have the one like KW and it is very handy. I have used it many times to break the beads and remount tires. Works best when you have it mounted to the floor or a trailer deck though.
2016 1025R TLB, 54" AutoConnect Deck, 49" Kuhn Tiller, 47 snowblower, 54 rotary cutter
2016 X758, 54" HC mower, three point hitch, 14 Bushel bagger, 60" QH blade
aquist06 is offline
post #9 of 21 Old 02-04-2014, 10:16 AM
SonnyT's Avatar
you probably want this one. Olny a few dolars more than your mini.
http://www.harborfreight.com/portabl...ger-69686.html
RIP Sonny T.
1954-2015
SonnyT is offline
post #10 of 21 Old 02-04-2014, 10:17 AM
I tried the smaller one first from harbor Freight and I bent it so I took it back and exchanged for this one.
I mounted the smaller one to a sq. tube and attached it to my Heavy Hitch to hold it. I bent it trying to break the bead on my go cart tires.
Name:	X729 tire changer.jpg
Just call me Larry
Thread for 110 RF build https://www.mytractorforum.com/showthread.php?t=287161
KWDAILYD is offline
post #11 of 21 Old 02-04-2014, 10:19 AM
I mounted mine to a heavy oak pallet when I did my tractor tires. I still have to decide where I want to mount it. May come up with something like I did for the smaller tire changer.
Just call me Larry
KWDAILYD is offline
post #12 of 21 Old 02-04-2014, 10:49 AM
professor's Avatar
I bought the HF tire changer years ago, drilled my garage floor for anchors when it is used (have to blow out the holes before use).
I remember some bending occuring using the bead breaker so that is not used.
Sure is great not bending over on the floor with tire irons though.
Never could figure out what the paddle/ spoon like thingy is on the one end of the long bar. Could have used instructions with it.
Anyone know what it is used for?
Every day is a victory.
'64 Simplicity Broadmoor
'66 Simplicity Broadmoor 707
'68 Sears Xl 10
? Dynamark 11/42
'71 Wheel Horse Special
'71 Wheel Horse Gt14
'72 Cub 127
? Bolens 10H
professor is offline
post #13 of 21 Old 02-04-2014, 01:20 PM
One end is for removing the tire, the other is for putting it back on.
Just call me Larry
KWDAILYD is offline
post #14 of 21 Old 02-04-2014, 11:51 PM
QAFarm's Avatar
I have the small one and its ok. I do have to a bit careful with it and the all thread has a kink in it now I realized but I just used it to do the tires on my 80 cart and it worked. It does put them on alot better than taking them off. I don't know if I could do rears on it though. I need to pick up the bigger one soon to do some rears and maybe retire the little one before I completely kill it. That's a nice adaptor you made Larry. The smaller tires is why I didn't get the big one but now I see the light.
1981 john Deere 317. 1986 John Deere 318
1964 International B414 1982 John Deere 400
10 s cart
26T John Deere sweeper
Model 50 cart
1969 Patio model 80 cart
1982 John Deere 80 cart
1976 John Deere 80 cart
Former equipment. 1979 JD 216 so others can live.
1999 Scott's 46 inch cut
1972 simplicity 3415H w/tiller
1977 JD 214
69 John Deere 112H SF
QAFarm is offline
post #15 of 21 Old 02-05-2014, 09:36 AM
mytmouz's Avatar
I have that one. I used an old axle and bolted it to a rim and tire. I cut the axle at the height I wanted and welded a flat plate on it and mounted mine. I roll it into a corner out of my way when I don't need it...
mytmouz is offline
