Troy-Bilt Horse gear oil - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Outdoor Power Equipment Reviews Tillers, Snowblowers, Chain Saws, Leaf Blowers, Etc. Say it here!
post #1 of 3 Old 05-29-2019, 06:47 PM Thread Starter
Camaromark
I just picked up a mid-70's Troybilt tiller. My question is, Is there a drain plug for the trans other than the one on the side of trans which I understand to be the overfill mark.
I would like to drain all the old oil out and put in new. Also can I get the oil at auto stores?
Thanks
camaromark is offline
post #2 of 3 Old 05-29-2019, 08:15 PM
Re: Troy-Bilt Horse gear oil
If you want exact responses we need a model number? Other than that some troy bilts have a drain plug lower down, some you have to remove the top handle cover plate, some use 80-90-140 gear oil.
Normally not a critical gear oil. I've even dumped in a 1/2 tube of EP2 gun grease to mix with the 140 oil.
Forest Gump is offline
post #3 of 3 Old 05-29-2019, 08:25 PM
There is a section here dedicated to Tillers...
Grab your manual here:
https://www.mytractorforum.com/291-t...iller-manuals/
Also, download the Transmission Service Manual (also on that page).
As for the oil, NAPA has this: http://www.napaonline.com/Catalog/Ca...238_0006410049
It is GL-4, but the label says it's OK for yellow metals.
Troy Bilt's website used to have an FAQ posting on the issue, seems like MTD may have misplaced that?
EDIT: Found it: https://support.troybilt.com/s/artic...language=en_US
  • Tiller Transmission Lubricant
  • Sep 11, 2017FAQ
  • ARTICLE NUMBER
  • 000002341
  • PROBLEM
  • What lubricant should be used in the tiller transmission case?
  • SOLUTION
  • In the past the rule was: For partial fill-ups (a few ounces or less) use SAE 140, SAE 85W-140 or SAE 80W-90 weight gear oil with an API rating of GL-4 or GL-5. For full replacement use SAE 140 or SAE 85W-140 gear oil with an API rating of GL-4 only.
  • We have also found that 80W-90 oil with an API rating of GL-1 is acceptable for both partial and full replacement of tiller gear oils.
  • We have 80W-90 lubricant available (12 quart case) at our Online Parts Store as part number 737-04040.
  • This oil is also available at most automotive supply stores.
I've seen a number of newer articles online stating to avoid GL-5 due to additives that may harm yellow metals.
Good luck, keep us posted with your progress.
Remember,
Mike
TRACTORS:
OTHER (NOTABLE) EQUIPMENT:
Echo PB751T backpack blower
Husqvarna 350 chainsaw
RETIRED TRACTORS:
mikeinri is offline
