DR Power Grader - Review - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Lawn and Garden Attachment Reviews Whatever the use, if it connects to a Lawn or Garden Tractor, this is the place to review it!
post #1 of 9 Old 12-11-2014, 02:55 PM Thread Starter
I just used my new 4 foot DR Power Grader last weekend and I'm not impressed. I'm putting together a full video review that I'll try to get posted, but it's not doing what I hoped it would do and I'm already debating sending it back.
Granted I started from an ugly but average scenario where it had not been graded or disturbed in 5-10 years in some spots. There were about a dozen potholes with an average depth of 2-4 inches and a scattering of loose gravel on top of a hard pan of smooth, compacted limestone dust. Another hill had a lot of gravel washed out.
Potholes: it does a fine job of filling them in. Which is to say it takes gravel from one area of the driveway and drags it into the hole. This sounds like a solution, but it's not fixing the accumulation of water in that spot. The teeth only allow less than an inch or so of scarification. It doesn't dig down deep enough to get to the bottom of the pothole, thus it never breaks up the pan of the pothole to re-lay the whole area flat. Since the pan of the pothole is still there, it fills up with water again, you drive through it pushing out the gravel and you have the same problem.
Washouts: my issue related to gravel getting washed down the hill. The sides of the roadbed are too high, making washout inevitable. However filling gravel back up the slope works temporarily until the next washout. I'm fine with that concession. I used the DR to drag gravel up the slope of the driveway and fill the washout back in. I did this several times, backing up and pulling more gravel up the slope. It did great at that, and with the electronic lift function and 2 button remote control, it made it a whole lot easier than it could have been. 5/5 stars.
Washboard/Uneven gravel: the DR levels out both washboard and generally uneven areas. However due to the limited depth of the scarifying teeth, it has left several areas of flat hardpan with a scattering of gravel where the orange rails simply ride on top of the 2 sides of the tire tread and the teeth never touch the road bed. It does not reset the hard pan of the road bed.
Compatibility with machine: I used a 750 Kawasaki UTV in low gear and felt it was a good match going up the slope with a full grader. I wouldn't want to do it in any ATV/UTV without a low gear. In high gear you'd either go faster than the 5 mph limit or tear up your transmission. A full load of gravel happens when you've got the machine all the way down and you're going over 3-4 inches of gravel bed. You will feel it.
Grass: It does get rid of the center line grass that grows between the tire treads. However it takes a long time due to grass getting stuck in the teeth, making them ineffective at grading. I found I had to weave back and forth for 10 passes which pulls the grass out of the center line, clogs the teeth up, cross over onto the road bed and raise the electric adjustment sometimes would let the grass fall from the teeth, then weave back over to the other side to do it again.
I can't see how this would be effective at overseeding a lawn if you wanted to use it for that.
Time: If you're grading your drive for the first time like I did, this will take all weekend. Again due to the limited depth of the scarifying teeth, the first pass would get a slice of the high edges. Several passes later still left me wondering what I was doing wrong. It took me about 30 passes to get an area worked. I did 1800 feet of my drive and it took me 4 hrs on Saturday, 8 hours on Sunday, and 10 gallons of gas. Not fast, but how does that compare to a box blade or other competitor?
Durability of the machine: From the weekend of first use the plastic weight tray broke and dropped all the limestone I had put in there. I don't believe I did/used anything different than I've seen on the DR promotional videos.
The shear pin broke. Just one of the 3 total they give you, but you should expect it to happen. Better that than the frame I suppose.
The two hitch options they give you are fine. If you're going to ever back up with the machine attached, use the pin attachment vs the ball coupler. The ball coupler just pops off when you try to back up, but it's a good option if you don't have any other.
Overall: it's the first use I've had of this thing. I'm not convinced it's what I want to keep. Any competing product that gets deeper into the road bed would be better. I'll hang onto it and see if the potholes redevelop.
It may not be the best product for my use, but maybe it's just enough for the price.
bluecanoe is offline
post #2 of 9 Old 01-16-2015, 01:26 PM Thread Starter
Re: DR Power Grader - Review
Here's the video review for the grader.
post #3 of 9 Old 01-16-2015, 08:04 PM
We're all friends here
APinNY's Avatar
Your video has been marked by YouTube as private. You need to change settings on their site so we can view it.
Al
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #4 of 9 Old 01-17-2015, 09:57 AM Thread Starter
Give it another shot. The settings have now been changed.
Apparently changing private to public on the mobile interface doesn't work well.
post #5 of 9 Old 01-17-2015, 10:25 AM
APinNY's Avatar
Sorry the DR didn't work out for you. It looks like your hard pack is more than the grader can handle. It's like cement. Their website videos show the machine in plain gravel or semi-loose dirt, and it seems to work well in that environment. Under normal conditions, grass in the teeth shouldn't stop it from moving the gravel. Because of the width of the tooth bar, it can't possibly reach down to the bottom of a pothole and scrape it out but it will fill the hole with stone. If you haven't already sent it back, call their customer service. The guys up there are good to deal with. They may have suggestions.
for the review.
Al
APinNY is offline
post #6 of 9 Old 01-17-2015, 10:56 AM
micblock's Avatar
To be fair to the DR, it is' impossible to crush hard pan with something that is pulled by a Garden Tractor / UTV / ATV. All adds are embellished, making there product look like the cure all, if you notice in there commercials, they are using it on sandy surfaces, it doesn't take much weight to cut in. Now for hard pan, a implement that weighs less then then power train, being used to pull it, or it couldn't pull it, such as a ATV / UTV / Garden Tractor it just won't work. You will most likely need a bulldozer with raker teeth, this time, with tons of down force, or something like a chisel plow, meant to break up hard pan. It takes tons of weight and power to break up hard pan. Once the hard pan is broke up, I would think the DR will work for maintenance, as long as it is regular maintenance. Good luck, I hope I helped, sorry, please keep us in the loop. /////// I just was able to watch your video. You will never get it to work on that surface and satisfy your expectations, if the teeth of the grader would go in a fraction your UTV couldn't pull it, it would be like being spiked to concrete. You wouldn't have enough weight or power to move it. That will take a dozer to break it up, but once it is, maintenance will be a breeze with a grader or a drag, that will be a nice road for you. On the plus side, it's not a mud bog. Good luck dude.
Mickyb
micblock is offline
post #7 of 9 Old 01-17-2015, 12:59 PM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Just watched your vid, and in all honesty, from what I saw, that is not a driveway, that is a county road. Your expectations were just too high.
You need to get a hold of the county grader operator and tell him there is a couple crates of beer waiting for him at your house if he drops the ripper teeth on the way in and out.
Then you will have some material to work with.
Agreed, the plastic weight pan should have been heavy metal and fancy electronics have no place on a piece of equipment like that. Mechanical hand cranks would have been more durable, especially since it probably gets left outside between usages.
Larry ( in Southern Ontario )
"Deere Built" 2001? Honda HA 4120 / 48" Power Flow Bagger.
Larry LGT 165 is offline
post #8 of 9 Old 01-19-2015, 09:55 AM Thread Starter
Agreed, I think it would make a fine machine for maintaining a road that has already been loosened. A month now since I've returned it, the potholes have redeveloped and the gravel that was brought up is disappearing into the roadbed.
My expectation was that it would make my driveway flat and be a reliable machine. It wasn't.
post #9 of 9 Old 01-19-2015, 10:33 AM
Sorry it is already gone. If the school bus used that driveway to service more than one house at the other end, the county will sometimes help you out.
Good to hear DR honored the agreement and took the machine back.
Did they offer any feedback as to your comments ?
