Cab lights review with pictures - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Lawn and Garden Attachment Reviews Whatever the use, if it connects to a Lawn or Garden Tractor, this is the place to review it!
post #1 of 16 Old 01-22-2014, 09:27 PM Thread Starter
Tractor Enthusiest
FatJay's Avatar
After building the cab I wanted to increase visibility around me. I was looking around at 12v spot lights and flood lights but they were either hand held or led or $100. I didn't want LED because my experience with led bulbs has been terrible. 10w same as 100w save power! But equal to lighting a candle.
I found some cheap ones on amazon and they had good reviews, even though they were LED, so I tried them. These are them:
http://www.amazon.com/gp/product/B008XZAQDU/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
I've got two in the front and one in the back. They're advertised as 10w but they're actually only 7ish. One of my concerns was power draw, 15amp alternator and all those lights, didn't want to overload it.
Here it is with no other lights influencing hte light. Headlights and spotlights are on.
Here it is with headlights only.
Here is headlights and spotlights. It's litterally a night and day difference.
Here's the rear spotlight. It's the only source of light back there
Overall I'm really happy with it. If you're looking to add some light to the outside of your cab definitely keep these in mind.
1951 Ferguson TO-30 w/5' Loader & 7' Grader
1953 Oliver 77 Industrial TLB w/Super 88 55hp engine
1971 New Holland S14 plow, 46" single stage snowblower
1986 Kubota B8200HST 4WD 50" dual stage snowblower, 60" rear blade, and heated cab
2001 Kubota ZD21 60" Zero Turn
FatJay is offline
post #2 of 16 Old 01-22-2014, 10:03 PM
MTD 990 Twactor Guy
SammyRye's Avatar
Re: Cab lights review with pictures
Wow - now those really do add light where you need it!
Thanks for the pics - I'm going to check those out for my cab.
Rich
1973 MTD 990 (Silver) 16 hp B&S Single
1982 MTD 990A (Red) 16 hp B&S Single
2003 Craftsman LT2000 22 hp B&S Twin
Reduce - make do with what you have,
Reuse - give it new life by being creative,
Recycle - if you can't use it, maybe someone else can!
http://www.wunderground.com/US/WI/La...typeclick=big2
SammyRye is offline
post #3 of 16 Old 01-22-2014, 10:43 PM
:wow: Those look great!
How well do they work with the engine stopped? I've read here that LEDs aren't very good unless the engine is running.
I'm looking to install some rear lights to help me with firewood duty (hauling), which I sometimes have to do at night after work.
Mike
mikeinri is offline
post #4 of 16 Old 01-22-2014, 11:09 PM Thread Starter
Tractor Enthusiest
FatJay's Avatar
Lights are just as bright with the engine off. I put them on when working on the tractor. I leave them on for 15-20 min and it doesn't make any difference on starting it up. They have a 110v version of the same thing. People reported problems with the vintage inverter though so I'm not sure how well I'd trust it.
FatJay is offline
post #5 of 16 Old 01-23-2014, 06:05 AM
Excellent, thank you.
Mike
mikeinri is offline
post #6 of 16 Old 01-23-2014, 10:40 AM
funengineer's Avatar
I've got a set of the LED I bought on .bay for around $55. It was a heck of a deal. Haven't found them that low since. Rated at 24 watts. They really light up the night.
funengineer is offline
post #7 of 16 Old 01-24-2014, 09:56 AM
Farmer
FordTractors's Avatar
Wonder if there are mounts so I can put them on ROPS without drilling and still look good????
Never Met A Tractor I Did Not Like
My wife has a website for our Farm, please join us at:
http://www.myhappyacres.com/
We hope to give you a smile at our new facebook page.
https://www.facebook.com/myhappyacres
FordTractors is offline
post #8 of 16 Old 02-01-2014, 04:22 AM
Tracor_Newbie's Avatar
Big pipe clamps, and some spray paint might work. Just make sure to bend the pipe clamp so that you've got a straight end to feed into the screw part that tightens it up.
Mark in MA
Tracor_Newbie is offline
post #9 of 16 Old 02-01-2014, 08:39 AM
Farmer
Good idea, thanks.
post #10 of 16 Old 02-11-2014, 08:00 PM
Hummer.2012's Avatar
I'm not sure the diameter of the ROPS but something like these from Amazon might work.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=ADJ%20Products%20Plastic%20o%20Clamp%20360%20Degree%20Wrap%20Around%20Clamp
2014 - X758SE w/Block Heater, Rear PTO, 3-point, 54"HC Deck
2013 - Heavy Hitch w/sleeve hitch option, 647 Tiller
2013 - Ohio Steel core aerator, curtis cab w/heater
2012 - JD X748SE w/Block Heater, Bercomac 48" Snow Blower
2012 - 60" 7-Iron Mower ,3-point, Rear PTO, IMatch
Help support White Paws German Shepherd Rescue when you order from Amazon. Click here to find out how.
Video:
http://www.youtube.com/watch?v=y_3ss8GsSlo
Hummer.2012 is offline
post #11 of 16 Old 02-12-2014, 08:05 AM
Farmer
http://www.amazon.com/s/ref=nb_sb_no...Around%20Clamp
The Amazon link took me to home page of Amazon. Thanks for trying to help.
post #12 of 16 Old 02-12-2014, 11:25 AM Thread Starter
Tractor Enthusiest
FatJay's Avatar
If the ROPS isn't solid, drill a hole. Then put two screws in to mount it and you're done.
FatJay is offline
post #13 of 16 Old 02-12-2014, 11:26 AM
You're right. Hmmm, not sure what went wrong. Try this: Go into Amazon and in the search box put in: ADJ Products Plastic Clamp 360 Degree Wrap Around Clamp
You can do a copy from this message (highlight the text followed by CNTRL-C) then when in Amazon put the cursor in the search box and do a CNTRL-V. If it works it should come up come up with 2 sizes of clamps that look like this
Hope this helps.....
Video:
post #14 of 16 Old 03-22-2014, 02:20 PM
Scott.O's Avatar
Thanks for the post FatJay you got my interest.I think I will order a pair...Scott
QT-17 48"deck, 6' utility dump trailer
Scott.O is offline
post #15 of 16 Old 03-22-2014, 04:38 PM Thread Starter
Tractor Enthusiest
FatJay's Avatar
I'd like to follow up on this. I've ahd these things exposed to the worst, rain, sleet, snow, ice, -10F, etc. 2/3 are working great. 1 is flickering, like there's a bad connection somewhere. I haven't investigated yet, the wiring job isn't the best though. It's about 3 fine strands of wire to supply them with power, so making a good connection without solder is kind of tough. I don't see any moisture inside at all, so I don't think that's the issue.
FatJay is offline
