Brinly-Hardy 40" Tow-Behind Plug Aerator Review - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Lawn and Garden Attachment Reviews Whatever the use, if it connects to a Lawn or Garden Tractor, this is the place to review it!
post #1 of 12 Old 10-14-2012, 09:28 PM Thread Starter
Rider on the Storm
SwedishRider's Avatar
Thumbs up Brinly-Hardy 40" Tow-Behind Plug Aerator Review
I bought the Brinly-Hardy 40" Tow-Behind Plug Aerator (http://www.brinly.com/PA_40BH.html) from a local Home Depot about a week ago and gave it a good workout over the last two days. Here's my review:
Assembly: It went together relatively fast. It took me a few hours by myself, but that was with a slow pace and reading over the directions as I went. It's well laid out for assembly and the instructions are well written. A few oddball-sized wrenches were needed (15/16"), but most homeowners would have the necessary tools to assemble the unit without a problem.
Actual use: It works really well! I ended up experimenting with weight in the tray, and settled on 120# as the sweet spot for my yard. It was used both before and after rain showers, and it worked much better after the rain shower. The instructions say to use this aerator after watering the lawn the evening before or after light to moderate rain, and that is definitely accurate. It pulled plugs with no hesitation and hit rocks a few times, but left no bent tines whatsoever. It went up and down some pretty significant hills without a problem and consistently created plugs and holes between 2.5" and 3".
Bottom line: This is an affordable, quality-built aerator that does what it's advertised to do. It was used on back to back days and never gave a problem. Cost was $169 and available both online at homedepot.com and at brick and mortar HD stores. There is also a 48" model that is available for $10 more but only through online ordering at homedepot.com. I would highly recommend this unit to anyone looking for an affordable, tow-behind core aerator- it does what the manufacturer claims it does... and does it well.
ID:	233133   Click image for larger version
ID:	233134   Click image for larger version
2012 Husqvarna R322T AWD
SwedishRider is offline
post #2 of 12 Old 10-14-2012, 11:13 PM
Rescue43's Avatar
Re: Brinly-Hardy 40" Tow-Behind Plug Aerator Review
Great review on this. I have studied on getting a plug aerator.
The Green Sickness:
1968 110......1969 110......1971 110......1972 110......
1976 210......1978 316......1981 314......1977 300......
1990 2155 w/loader
And a decent collection of Swisher, Agri-fab, and
Brinly equipment to follow the garden tractors around.
Rescue43 is offline
post #3 of 12 Old 10-17-2012, 07:11 AM
MTF Tractor Nut
wizzo's Avatar
Sounds like your aerator works as well as mine. I agree that it's a great accessory for the price.
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline
post #4 of 12 Old 10-17-2012, 08:21 AM
Likes Vintage JDs
UrbanTractor's Avatar
Thanks for the helpful review.
I take it the wheels are for transport, and the lever is used to somehow raise the wheels when the aerator is in use?
SOLD: 1966 JD 110 Round Fender Integral Sleeve Hitch, Model 42 Blade,
1972 JD 140 H3, 1972 Cozy Cab Model 14 JDX (2nd Ed.), Front-, Mid-, and Rear-PTOs, Model 54/48" 4-Way Blade, Model 48 MMM, 542 Front PTO, 3-Point-Hitch, Heavy-Hitch, a bunch of Model 80 Carts, MTF Dec. 2013 Machine of the Month
UrbanTractor is offline
post #5 of 12 Old 10-17-2012, 10:42 AM Thread Starter
Rider on the Storm
That's exactly it. There is a pin that the lever locks into that puts the wheels down for transport (over land, pavement, concrete, or whatever). When the handle is lowered, weight is placed on the tines and the movement of the tractor spins all three independent sections of tines. It's split into 3 sections so when turning corners, lawn damage is minimal, if at all. Good design!
post #6 of 12 Old 10-20-2012, 01:56 PM
I have had the 48" version for two years. It was a great purchase. Pulls good plugs.
2010 X500 48" Deck
chainsaw4130 is offline
post #7 of 12 Old 05-18-2019, 10:03 AM
I have the same aerator, and I agree that it does a great job.
Just one design feature that bothers me is that you have to get off the tractor to raise and lower the tines, since the handle faces backward. It would be far more convenient if that raise/lower handle could be operated while remaining seated on the tractor.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline
post #8 of 12 Old 05-18-2019, 10:26 AM
Hmmm,.....maybe there is a modification project in Jeff's future......
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is offline
post #9 of 12 Old 05-19-2019, 07:18 AM
Rich
X300owner's Avatar
I have had the Brinly 40" plug aerator for over 20 years. First use in Atlanta and I did yards for $30 each, paid for the Brinly in one weekend. Use it every fall now for at least 2 or more yards with no problems. Replaced the tines once many years ago. I love the way the handle is as I rigged up a cheap winch to run it up and down at sidewalks and for backing up, video attached. Also made a weight box to hold water for weight.
Details on adding a winch here https://www.tractorbynet.com/forums/...ml#post3145127
Name:	Aerator small 2.JPG
2010 Deere X300, Deere 40" shovel, Brinly plug aerator, Brinly 125 lb spreader, Homemade Dethatcher on shovel, Craftsman 38" lawn sweeper.
X300owner is offline
post #10 of 12 Old 05-19-2019, 12:27 PM
Another project? Why not!
The_Geologist's Avatar
I've been considering getting one of these for a while, but I have also wondered if pulling it while loaded down would mess up the transmission in my mower. It's just an early 90's Coast to Coast (MTD) riding mower, so not the most stout transmission out there.
Anyone have any thoughts on this?
Adam
Flathead Valley, MT
1994 Coast to Coast 12.5/38 rider (Grandpa's tractor)
1983 Lawn Chief 11/36 rider (project)
Other Machines in My Yard:
1974 Wizard (Gilson) tiller (project)
1977 Ariens Rocket V tiller (project)
1980 Ariens ST824 snowblower
1990s Toro CCR1000 snowblower
2003 Snapper Hi-Vac mower w/Thatcherizer
2004 Craftsman mower
Previously Owned Machines:
1990 & 1992 Snapper Hi-Vac mowers
2006 White 18/42 rider
1996 Ranch King 12/38 rider
The_Geologist is online now
post #11 of 12 Old 05-19-2019, 12:40 PM
Rich
X300owner's Avatar
Originally I used a Scotts tractor made by Murray with a weak Peerless trans. Lasted longer than it should have. In Atlanta I pulled the aerator up some very steep hills and sometimes had to go up the less steep side with tines raised, across the back yard and then down the steep side plugging down hill. Atlanta clay required a lot of weight on the aerator. Severe abuse the trans had. If you abuse the tractor it will not last. On flat yards most tractors should do fine just rolling the aerator.
post #12 of 12 Old 05-19-2019, 09:10 PM
Thanks for the feedback. I suspect that my yard is a bit too hilly. I might see if I could pull it with the Lawn Chief instead...once I ever get that one running.
Adam
Flathead Valley, MT
