FIMCO 40 Gallon Trailer Sprayer Review - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Lawn and Garden Attachment Reviews Whatever the use, if it connects to a Lawn or Garden Tractor, this is the place to review it!
post #1 of 40 Old 04-12-2010, 06:54 AM Thread Starter
USMC
slkpk's Avatar
In 2005 I bought the 40 gallon Fimco trailer sprayer with the 2.1 gal. electric pump with a 7 nozzle boom. This has been a great little sprayer and with the 40 gal capacity it's just right for my 3 acres. Last year I upgraded the pump to the 3.8 gal per minute pump and switched to flood jet nozzles hoping top get more recirculation to keep the product in suspension. I use 28% nitrogen for fert and it's heavy and needs to be recirculated while spraying.
If anyone is looking to buy one I might suggest going with the gas version and roller pump if your looking to spray anything heavy so you can use the by pass to keep everything in suspension. The by pass on the electric pump leaves a little bit to be desired for recirculating and spraying at the same time.
Overall I'm would give it 9 out of 10 rating. For spraying regular herbicides and other liquid fert it does extremely well. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #2 of 40 Old 04-12-2010, 09:07 AM
m7boondocker's Avatar
Re: FIMCO 40 Gallon Trailer Sprayer Review
Thanks for the review. Where do you get your N from?
I have been using granular type fert. for years but want to switch to a liquid based product. We purchased a new house with more land I feel a liquid based product maybe cheaper / easier to apply... Plus, I can more easily control what I put down.
m7boondocker is offline
post #3 of 40 Old 04-12-2010, 09:51 AM
Diesel Power
andyb's Avatar
I have had the same sprayer for a couple of years, and like it also. I spray the garden, trees, and around the house with insecticide, the spray gun works great. The nozzle can be adjusted from a fine mist to a stream that will go more than 20 feet. I use the boom to spray weed killer on the lawn, it covers 10 feet, and the pressure can be adjusted with the bypass valve so you don't get too much misting if it is a little breezy. I haven't used it with fertilizer. I would also give it a 9 out of 10, great sprayer for the money. I got it on sale at Tractor Supply.
2010 John Deere x748
3 point hitch
rear PTO
54" blade
62" deck
http://www.youtube.com/watch?v=h1dzMX49NC0
____________________
1994 John Deere 445 sold
andyb is offline
post #4 of 40 Old 04-12-2010, 10:05 AM
You could spend ~$20 on a bilge pump and stick it inside the tank for recirculation. The small ones only use a couple amps.
Chagrin is offline
post #5 of 40 Old 04-12-2010, 10:16 AM
Diesel Power
andyb's Avatar
That is a great idea. I have one I took out of my boat that the outlet broke off too short to attach a hose. Fully submersible, 500 gph, would work great.
http://www.basspro.com/webapp/wcs/st..._SearchResults
3 point hitch
rear PTO
54" blade
62" deck
andyb is offline
post #6 of 40 Old 04-12-2010, 12:40 PM Thread Starter
USMC
slkpk's Avatar
Great idea and thanks. slkpk
2007 JD 2305
slkpk is offline
post #7 of 40 Old 04-12-2010, 12:44 PM Thread Starter
USMC
slkpk's Avatar
I get the 28% from Farm Service. Any AG dealer should have it in bulk.
http://store.interstateproducts.com/...ts/Fertilizers
http://www.natureslawn.com/index.html
I haven't tried the natures lawn yet. I've used the interstate stuff several times and have had good luck with it. slkpk
2007 JD 2305
slkpk is offline
post #8 of 40 Old 04-12-2010, 11:54 PM
midnitetr8n's Avatar
slkpk,
Can you post a few pics of your sprayer or point me to a few you have already posted. Thanks.
Theo
Live Green or Die.
2008 JD-X500
JD 10P Cart, JD Integral Hitch, 40" Brinly Rear Blade, JBJR, 10" Brinly Moldboard Plow, 42" Brinly Lawn Sweeper, Brinly Cultivator, 1 Ton Winch
1984 & 1988 JD420
(Long Term Projects)
1988 JD332
1985 & 1988 JD318
3ph, #15 JD 3pt Moldboard Plow, 1 Ton Winch, Brinly 3pt Four Gang Disc Harrow, Brinly 3pt Cultivator w/ Hiller Discs, JD 54" 4 way Blade, 3pt Carry All, 4'-6' Telescoping Boom Pole, MCS
1972 & 1973 JD140 H3
Sleeve hitch, JD 54" 2 way Blade
1967 RF 112H
midnitetr8n is offline
post #9 of 40 Old 04-13-2010, 06:30 AM Thread Starter
USMC
slkpk's Avatar
Originally Posted by midnitetr8n View Post
slkpk,
https://www.mytractorforum.com/showthread.php?t=74778
I think this is all I have of the sprayer right now. I can get some more or shots of what you need this weekend. slkpk
2007 JD 2305
slkpk is offline
post #10 of 40 Old 04-13-2010, 11:40 AM
Diesel Power
andyb's Avatar
Here are some pictures of mine. I mounted the valve stand and assembly different from what the instructions said to move it back farther from the tongue to clear the three point hitch on my 445.
slkpk, I read the other thread, could you give me some information about the flood jet tips you used? It would be very helpful to be able to lower the spray bar when it gets breezy.
3 point hitch
rear PTO
54" blade
62" deck
andyb is offline
post #11 of 40 Old 04-13-2010, 08:04 PM Thread Starter
USMC
slkpk's Avatar
My tank is a little different design and my pump is out in front. slkpk
2007 JD 2305
slkpk is offline
post #12 of 40 Old 04-13-2010, 09:35 PM
Thanks for the pics slkpk and andyb, your setups look great. If I want my lawn to look any better than it does, I might need to invest in one of these units.
Theo
Live Green or Die.
2008 JD-X500
1984 & 1988 JD420
1988 JD332
1985 & 1988 JD318
1967 RF 112H
post #13 of 40 Old 04-14-2010, 06:40 AM Thread Starter
USMC
slkpk's Avatar
andyb, http://www.hypropumps.com/FileAttach...pray%20Tip.pdf
This explains it better than I ever could. slkpk
2007 JD 2305
slkpk is offline
post #14 of 40 Old 04-19-2010, 06:16 PM Thread Starter
USMC
slkpk's Avatar
Here is a pic of the red flood jet tip and the grey one is a fan spray tip.
2007 JD 2305
slkpk is offline
post #15 of 40 Old 04-19-2010, 06:18 PM Thread Starter
USMC
slkpk's Avatar
The product sprays down bouncing on the flat surface and then goes out in larger droplets.
compared to spraying out in a fan pattern straight down. With the flood jet tips you can drop the height of the spray boom. slkpk
2007 JD 2305
slkpk is offline
