DR Lawn Vacuum Review - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Lawn and Garden Attachment Reviews Whatever the use, if it connects to a Lawn or Garden Tractor, this is the place to review it!
post #1 of 24 Old 10-21-2009, 04:30 PM Thread Starter
We're all friends here
APinNY's Avatar
Since leaf season is upon us, and at the suggestion of our good friend Volfandt, I will attempt to review the features, likes and dislikes of this machine for anyone contemplating a purchase.
I used to tow it with a Craftsman DYT4000 which handled it very well, although when the collection box was full you could feel the weight pulling on the tractor, particularly on side slopes. It is attached to the tractor with the Kubota boot and a hose adapter from DR. Towing behind the BX you don't even know it is there unless you sideswipe a tree. This can easily happen if you are not careful turning. The smaller models like mine have large caster wheels and a fixed hitch. This makes it easy to back up but the box swings out in the opposite direction on forward turns. I have brushed a few trees with no damage to the unit. My 5.5 hp machine does not have a chipper but they are available. The engine starts with 1 pull every time. The lifetime warranteed mulching blade does a great job with leaves, grass, small twigs, acorns, needles, etc. The engine is mounted to the frame(trailer) with knobs that can be removed. Then the engine can be lifted off and rolled around on small casters. Very handy for storage. All of the box panels(heavy abs plastic) can also be removed by means of small rubber bungee clips. The trailer can then be stored upright.
Compared to a standard 3 bin bagger I would say the box holds about 20x as many leaves in mulched form. That equates to 19 times not having to get off the machine to empty bins. Leaves enter the box through a cyclonic input chamber which stops them from coming out of the top. The exception is when the box is packed full and there is no where else for them to go. A full indicator would be a nice touch.
The box can be released from the front of the trailer for dumping. As long as the casters are facing forward, the box will stop when it rests against the tires, but if the casters are facing rear the box will flip completely down on its back. It's a bear to lift back up when it's full. I tied ropes between the frame and box which stops that from happening now, and I have found that because the trailer is connected to the 3PH I don't have to release the box at all. Just raise the 3PH and the entire vac tilts back as far as necessary.
There are several other manufacturers out there but I only have personal experience with this machine for about 4 years now and I really do like it.
Pay no attention to the dirt in the photos as this is a working machine.
DR's boot to hose adapter.
Cyclonic chamber keeps leaves and dust inside.
Strong rubber bungee clips work well.
Pneumatic caster wheels with turf tires.
Engine removal knobs. No tools required.
I added the trailer jack for ease of moving
If I missed anything or there are questions, fire away or PM me. Al
Al
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #2 of 24 Old 10-21-2009, 05:28 PM
USMC
slkpk's Avatar
Re: DR Lawn Vacuum Review
Nice review. I've never had a DR but I had the JD MC519 collection system and if a person has an area to dump the DR/cart forget about the double and tripple baggers, go with a cart. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #3 of 24 Old 10-21-2009, 11:51 PM
jay ray's Avatar
Nice rig. I didn't see any dirt.
jay ray is offline
post #4 of 24 Old 10-22-2009, 05:34 AM
USMC
slkpk's Avatar
Does the DR really keep the dust from being blown around? slkpk
2007 JD 2305
slkpk is offline
post #5 of 24 Old 10-22-2009, 08:08 AM Thread Starter
APinNY's Avatar
Maybe I'm a little too fussy.
Al
APinNY is offline
post #6 of 24 Old 10-22-2009, 08:11 AM Thread Starter
APinNY's Avatar
It really does. I don't know what happens to all the trapped air in the box but the only time dust comes out is when you hit a tree. It comes out where the panels come together, but that rarely happens.
Al
APinNY is offline
post #7 of 24 Old 10-25-2009, 12:16 PM
How does the DR vac do when the leaves are wet?
limpit is offline
post #8 of 24 Old 10-25-2009, 12:21 PM
I'd rather be threshing!
mbkerk's Avatar
Send a message via AIM to mbkerk Send a message via Yahoo to mbkerk
Nice review AP!
If I had a place to dump the leaves, I would own one! I have to put everything into a 20 yard roll off dumpster at a collection site.
Thank you for writing of your experience, and for posting the pictures!
Mark
Fargo, ND
Where are you from? VOTE HERE! To represent your state!
2004 Craftsman GT 5000 • 1962 Cub Cadet • 1944 John Deere B • 1954 John Deere R Diesel
1945 VAI Case • 1998 Dodge Ram 2500 4X4 / Cummins 24V
mbkerk is offline
post #9 of 24 Old 10-25-2009, 01:23 PM Thread Starter
APinNY's Avatar
It sucks up wet leaves pretty well. Like anything else you have to slow down some when wet to keep the hose from plugging up. I try to let them dry out before vacuuming as much as possible.
Al
APinNY is offline
post #10 of 24 Old 10-25-2009, 04:07 PM
I think I am going to make the investment in a 9.0 premier.
In fall I spend more time emptying my 9 bushel bagger than I do actually sucking up the leaves and I think one of these will make short work of things.
Thanks you for the awesome pics and information.
limpit is offline
post #11 of 24 Old 10-25-2009, 05:55 PM Thread Starter
APinNY's Avatar
That is why I bought it to begin with. I actually counted getting off and on to empty the 3 bin bagger 43 times in about 2 1/2 hours. That was the turning point and it made my decision easy.
Al
APinNY is offline
post #12 of 24 Old 11-01-2009, 09:43 PM
As a stand alone unit, Does this have enough suction to pick up leaves out of flower beds?
With 3 acres of Oak trees, the leaves in the flower beds, at the fence etc. are a pain unless you use the blower.
JBJeeprider is offline
post #13 of 24 Old 11-02-2009, 08:51 AM Thread Starter
APinNY's Avatar
Yes it does. An optional 16 ft. hose is available for just that purpose. It works very well. I usually wait until all the leaves are down and do the shrubs last.
Al
APinNY is offline
post #14 of 24 Old 11-06-2012, 08:52 PM
You seem to have the generation before I bought mine in 2010....most noticeable is that your hose clamp grippers are much more user friendly that the hose clamps with a thumb tag in newer models - makes for very painful and laborious removal of the hoses now. Newer models only dump at the rear (again needing laborious unscrewing of two rubber knobs. Newer models did away with the casters. So ok, here is my story....I asked for a refund after 2 years and mentioned pursuing a remedy legally and they said 'they love a good fight!......
DR Equipment 8 HP Lawn and Leaf Vac
In 2010, my first unit (which was later replaced free of charge) blew through 10 rubber engine couplers that prevent the engine from being damaged when there was a clog. Nothing was clogging the machine but 10 rubber gears were shredded and I replaced them.
For 2011 and 2012, the replacement machine experienced 5 rubber coupler failures but this was a big improvement over the original machine. In addition I have experienced the following issues with this machine:
1) Oil dipstick shakes loose and allows oil to spew from engine – needs to be monitored closely.
2) 4 large bolts holding the frame of the unit to the hitch have sheared off twice – I was finally able to find strong enough bolts from local hardware store to prevent them from shearing. (grade 8 bolts)
3) The universal deck adaptor is of such a shape that even slightly moist grass and leaves create clogs in the output chute just off the deck. This does require shutting off your tractor due to closeness to mower blades. The adaptor seems to collect the grass and leaves at a large area at the bottom and they quickly have to launch up and out to a 45 degree angle that gets to be too steep when they are heavy and therefore backup and create a clog. (this piece does seem very different from pic above - above seems better)
4) The black plastic thumb-pad screws to allow putting on and off 6 inch collection hose seem to only last 10 to 20 uses and when they break off you will need to have a pair of pliers to address the next, most important, issue.
5) Finally and most significantly, the 8hp lawn and leaf vac is very particular about wanting dry leaves with no twigs or sticks (sticks become twigs under a turning mower deck!) due to 1) the internally ribbed hose that enters a 90 angle plastic chute at the rear of the ‘box’ catching twigs in the hose or the 90 angle chute itself being a tough turn for the twigs and/or 2) the coupler between the hose and the 90 degree plastic angle warping outward within the 6 inch flex hose causing a greater surface area for twigs to grab on and clog the hose. I found myself getting about 15-20 feet of travel while using the product before I had to dismount, undo the hose at the rear of the box and unclog the hose, reattach the hose and get going again.
I have a 3 acre yard and I have found the product to be unusable in my particular situation.
ryanmad2000 is offline
post #15 of 24 Old 10-29-2013, 11:36 AM
I just got my Kubota BX1870 with the 48"mower. I have the a DR Lawn vac that I used with my Cub Cadet. I went to purchase the boot for my Kubota and the dealer was not sure what I needed. the boot is about $ 240.00 but the kit he recommended is over $ 800.00. Even he thought that was a mistake. I am waiting for a response from Kubota but in the meantime, got any ideas.
I may have to drag the Cub back out to do the leaves.
Thanks!
lt74 is offline
