Custom backhoe mounted post auger - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 07-09-2019, 09:17 PM Thread Starter
Hi there,
I own a 2015 Massey Ferguson GC1710 with a backhoe. I recently acquired a small hydraulic driven post auger that I would like to mount to the backhoe boom. The brackets and mounting the unit and whatnot are the easy part for me but I am trying to figure out the best way to actually spin the auger.
My initial thought was to basically treat it like one of those rental towable units from home depot(with the head mounted onto the backhoe instead of my hands!) and have a separate power pack - a gas engine like a GX390 or similar to run a hydraulic pump with relief valve, tank, cooler, lines to auger head etc and have the hydraulics completely self contained.
The more I think about it, the more I consider running it off the tractor hydraulics though. Which is what I am hoping some of your experiences will help.
My only concerns are I do not want to lose any of the loader or backhoe functions to run the auger. I am also worried that the tractor might be on the low side for hydraulic flow and pressure. The auger unit claims 2600 psi max, with gpm from 3.7 to 14.7 max. Those home depot towable style do roughly 1900 psi and 5.5 GPM. From what I understand the tractor will do around 2000 psi but only 4.3 GPM.
Am I asking too much from the little tractor? I mostly use a 6" or 10" auger for fence post installs. Is there an aftermarket remote hydraulic function valve that will give me forward/reverse with some level of control etc? Or am i stuck running it off the loader tilt valve lol.
Anybody else have any thoughts or ideas? Would love to hear from somebody that actually knows what they are doing haha.
Thanks in advance!
turboboost is offline
post #2 of 11 Old 07-09-2019, 09:49 PM Thread Starter
I have attached another picture of the auger drive unit and one of the tractor loaded up as well.
ID:	2385955   Click image for larger version
post #3 of 11 Old 07-09-2019, 09:55 PM
Re: Custom backhoe mounted post auger
I would run it off a separate pump and spool. Leave the BH fully functionable. You will need all its maneuverability to keep the auger straight as it digs.
Ariens93GT20 is online now
post #4 of 11 Old 07-09-2019, 10:10 PM Thread Starter
Yeah is that going to be the best bet? I have always been pleasantly surprised how little the engine actually seems to work running the backhoe hydraulics. The 60" blower will sure make it snort in wet snow however.
post #5 of 11 Old 07-09-2019, 10:16 PM Thread Starter
Also do you mean power or maneuverability? I wouldnt sacrifice any functions on the backhoe, only some power loss from the auger.
post #6 of 11 Old 07-09-2019, 10:28 PM
Will the tractor hydraulics provide to much pressure to the auger head. It will still require a spool with forward and reverse capabilities. A relief valve would take of pressure issues. Then the issue of having enough ports without disconnecting something. You do not want to loose maneuverability anywhere.
post #7 of 11 Old 07-09-2019, 10:39 PM Thread Starter
Yeah I definitely agree it would require me to figure out a foot operated forward/reverse controls for the auger. There is a company out there that makes a 3rd valve kit for the tractor that would enable me to keep every current function and also have an aux port for the auger or a wood splitter, cement mixer etc.
As far as actual psi, the tractor only does 2000 psi max and the auger drive unit is rated for 2600 psi max.
This is the machine the auger drive was designed for:
https://www.woodmanstore.com/883/pro...ol-engine.html
post #8 of 11 Old 07-09-2019, 10:54 PM
I was thinking you would be taking the bucket off when using the auger, so why not tap the lines that supply the tilt ram for the bucket. You shouldnt need a ram on the auger as they can be directed easily with the boom.
Junky is offline
post #9 of 11 Old 07-10-2019, 02:26 AM Thread Starter
Plumbing extra remote for auger on Massey Backhoe
Hi there,
I also posted in the custom equipment subforum but they led me this way for additional help. I own a 2015 Massey Ferguson GC1710 with a backhoe. I recently acquired a small hydraulic driven post auger that I would like to mount to the backhoe boom. The brackets and mounting the unit and whatnot are the easy part for me but I am trying to figure out the best way to actually spin the auger.
My initial thought was to basically treat it like one of those rental towable units from home depot(with the head mounted onto the backhoe instead of my hands!) and have a separate power pack - a gas engine like a GX390 or similar to run a hydraulic pump with relief valve, tank, cooler, lines, spool valve to auger head etc and have the hydraulics completely self contained and separate from the tractor. A portable power pack basically.
My only concerns are I do not want to lose any of the loader or backhoe functions to run the auger. I am also worried that the tractor might be on the low side for hydraulic flow and pressure. The auger unit claims 2600 psi max, with gpm from 3.7 to 14.7 max. Those home depot towable style do roughly 1900 psi and 5.5 GPM. From what I understand the tractor will do around 2000 psi but only 6.6 GPM - and its likely the steering takes 2 GPM or so to run.
Am I asking too much from the little tractor? I mostly use a 6" or 10" auger for fence post installs but dream of also using it for small screw piles for decks and sunrooms. Even if I had to do the last couple feet with a cheater bar occasionally lol. I have used a 3pt hitch style auger with the tractor before and it has no problem sinking the auger bit in like a screw pile until the head is sunk - if you're not careful with the controls.
I am also currently in talks with a gentleman that makes a remote valve kit with additional working lines for this exact machine but I would like to confirm the tractor itself will actually run the auger reasonably effectively and do what I want it to do before I go that route.
Sorry about the essay but thanks for reading and your input.
ID:	2385981   Click image for larger version
Old 07-10-2019, 02:34 AM
turboboost
This message has been deleted by Newsman. Reason: not needed after merger
post #10 of 11 Old 07-10-2019, 07:16 AM
Could you put quick couplers on the hoses and then quick couplers on your ram and also the auger? It should work fine like that. Then just remove the ram or tie it in place.
Im not sure if you have rubber hose by the ram or just steel line. Some improvising may be needed.
Junky is offline
post #11 of 11 Old 07-11-2019, 06:47 AM
20,000 Posts & Climbing
Bolt a bracket to the control pedestal for a separate valve set. (Watch for knee clearance.) The power beyond kit is already in place. Run a new hose from the return (left side) of the back hoe valve set to the new valve, and move the return line to the return side of the new valve. You may need a new return line to make it long enough to reach the normal return quick connect on the tractor. String the work lines along the boom to the bucket for quick connecting to the auger. Tie them well. You will probably need the bucket cylinder serviceable for making small adjustments to the auger position.
Connect and disconnect the back hoe as normal. Protecting the quick connects from dirt, debris, and sideways impacts when the auger is disconnected will take some thought. If you split the quick connects (one male and one female) for each, the tractor side and the auger side, they can be connected together when not in use to keep the dirt out and so that reconnecting them results in the same rotation direction for the valve position every time that it is reconnected.
The low flow and pressure will limit the size of the bit and the type of ground that you will be drilling. The flow is higher than minimum, but not by much. The 23% lower pressure rating may be of more concern.
TUDOR is offline
