GT20 PTO not kicking in - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 05-19-2019, 07:29 PM Thread Starter
None
Hello, I have a GT20 that it is difficult to get the deck PTO to kick in. When the PTO switch is pulled, the ammeter moves and I hear a click but nothing happens. I have to turn the switch on/off 15-20 times before it may finally kick in. I am not mechanically inclined, so any help in layman's terms will be appreciated. Thank you.
RCS62 is offline
post #2 of 17 Old 05-19-2019, 08:18 PM
Cat385B's Avatar
Re: GT20 PTO not kicking in
Check the condition and connections of the wires, especially from the switch to the pto.
Cat385B is online now
post #3 of 17 Old 05-19-2019, 11:25 PM
Any problems getting the rear pto engaged? Just trying to figure out if it maybe a safety swith problem. Also with a test light or voltmeter check the front clutch wire connection. This will varify the switch is working. If the switch is working ok the air gap on the clutch may need adjusting. With limited mechanical abilities you may have to find someone to do it for you. The worst part it getting to it.
Ariens93GT20 is offline
post #4 of 17 Old 05-26-2019, 09:36 PM Thread Starter
None
Hey guys, thanks for the input. The tractor is on land we lease for hunting, about 2 hours away so not sure when I can get there but hopefully soon. Will let you know how I make out.
RCS62 is offline
post #5 of 17 Old 06-22-2019, 10:30 PM
Have this problem now also. Only mine dies when turning on the PTO front or rear and also when taking it out of neutral. Will be checking relay and time delay relay tomorrow. Seat and neutral switches have already been tested. Darn safety devices anyway.
post #6 of 17 Old 06-26-2019, 06:24 PM
If you here a click the relay is good. Not sure if the time delay would function intermittently. But if your rear pto functions the problem is elsewhere.
post #7 of 17 Old 07-02-2019, 07:26 PM
For a quick and dirty check, put a simple heavy duty on/off toggle switch where the pull out switch normally resides. Remember to either make a sketch of the position of each wire of take a few pictures so that you can put everything back correctly later. Then run a hot wire from either the battery or the amp gauge to one side of the switch (don't forget to include a fuse) and put the wire running to the PTO on the other side. It's the yellow wire I think, but back trace it to be sure. With the engine off, flip the switch and see if you hear the clutch "click" on. If it works, try using it for a while. If everything works, you can order a new switch or just rewire the toggle switch so that it uses the original power wire from the ignition switch. Also don't forget, until you restore switched power, the toggle switch will be "hot" all the time, and you might run the battery down if you're not careful and check it every time to ensure it's in the off position when you have finished with the tractor.
Thant's what I had to do to the GT, but unfortunately I haven't had time to rewire it back to switched power yet. It's working fine, but I have to remind myself to check it after I park the tractor.
Demented is offline
post #8 of 17 Old 07-06-2019, 10:10 PM Thread Starter
None
Hey guys, thanks for the advice...I checked the air gaps, and they were way off. Had to close them up quite a bit, and seems to be working perfectly now. Set the gaps at .11. One other question, it's not really an issue, but when I start the GT20, it squawks for a second when it starts. Doesn't last long, just a split second squawk. Any idea what causes it?
RCS62 is offline
post #9 of 17 Old 07-06-2019, 11:39 PM
Maybe the hyro starting up. Nothing else should be activated.
post #10 of 17 Old 07-07-2019, 03:17 AM
i just did this with mine, they were way open and nuts almost loose. Once the gap was closed up, no issues.
Dan
Dan
Bolens / TroyBilt GTX20
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is offline
post #11 of 17 Old 07-07-2019, 10:57 PM
With the ignition switch on check the red wire on the time delay. That wire activates the relay attached by the same bolt. On the relay the purple wire is the feed off of the ignition switch and the before mentioned red wire activates to relay. If the relay is working there will be voltage at the relay double yellow wire terminal that feeds the PTO switches. The double yellow should show voltage any time the ignition switch is on, neutral switch and seat switch is activated. Engine need not be running.
I have a bad time delay. Ariens want $215 and Jacks $175. I am sure there is a cheaper way to fix this properly. For now a 5 amp resettable circuit barker will have to do. The clutches are supposed to function on a 3 amp load. 5 amps should protect from overloads.
post #12 of 17 Old 07-09-2019, 09:29 AM
Buwaro's Avatar
How exactly do you check the air gap? I need to do this for my GT20 for the exact same reason.
Ariens GT20
Buwaro is offline
post #13 of 17 Old 07-09-2019, 10:35 PM
Will let someone answer that that has done it recently. I have yet the need to do it but think that day will be coming also.
post #14 of 17 Old 07-10-2019, 10:30 AM
Hammerhead007's Avatar
I hope this is readable...but here you go.
Name:	Air Gap on Clutch.jpg
Hammerhead007 is offline
post #15 of 17 Old 07-10-2019, 10:33 AM
If you click on the pick and then save it to your computer you can then make the pic bigger and easier to read. Hope this helps.
Replaced PTO on my 94 STX 38 Black Deck Gus G. Backyard Round Table - L & G Tractor Related Topics 4 10-30-2018 08:24 PM
Replaced PTO on 94 STX38 Black Deck Gus G. Introductions 1 10-30-2018 03:01 AM
20G PTO Lever Suribachi Gravely 7 01-14-2018 07:07 PM
John Deere 4720 PTO Problem billboyce2 The CUT Hut: General discussions of Compact Tractors 8 12-26-2017 04:05 AM
99 gt235 PTO Issues garymows John Deere Forum 3 12-01-2012 03:05 PM
