Need help with tire size. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 05-22-2018, 06:01 PM Thread Starter
My MW 16 Variable speed has 23x8.5-12 tires on it.
The tires I want to get only come in sizes 23x8-12 or 23x10.5-12.
Does anybody know if the 10.5 will fit under my fenders?
Thank you.
LaPlantebd is offline
post #2 of 4 Old 05-22-2018, 09:08 PM
Hammerhead007's Avatar
Re: Need help with tire size.
Judging from the side profile, the 23 won't be a problem as that's what you have now. The 10.5 will probably require a wider rim, as yours are only 8.5 wide. It's the off set of that center bolt plate that you will need to keep but in a wider rim. I'm thinking an 8 or 8.5 inch wide rim with same offset as your original and you should be good to go. I have 23x10.5x12 on that blue Bradford you see below and I believe that rim is either 8 or 8.5 inch wide. These were an option for this tractor but the original size is 23x8.5x12.
Hammerhead007 is online now
post #3 of 4 Old 05-22-2018, 10:59 PM
Here is a rear pic of what yours might look like with 23x10.5x12 tires.
ID:	2291777   Click image for larger version
post #4 of 4 Old 05-25-2018, 08:38 AM Thread Starter
Thank you!
