Found in the woods - Metal Tube with with screw on end - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
What Is It ??? Non-Tractor related
post #1 of 23 Old 08-10-2019, 07:36 PM Thread Starter
Have Dog - Will Travel
Jere39's Avatar
I found this small tube, about 6" long and 3/4" outside diameter. It is made of a metal that has not oxidized. It has a screw on top that has oxidized green like copper so perhaps brass. The top/lid has a dimple in the center as though it might center something inside. I cleaned it up and gave the top a good soak in WD-40, and I suppose I'll attempt to open it unless one of you recognize it as a canister of some component of a WMD. It's hardly big enough for anything I can think of that might have been used for a shooting sport.
Anyway, I'll let this here for a day or so before attempting to open it. If you don't hear from me again, you should suspect it was not safe.
Thanks for any hints
ID:	2390343   Click image for larger version
ID:	2390345   Click image for larger version
Jere39 is online now
post #2 of 23 Old 08-10-2019, 08:11 PM
Don
Re: Found in the woods - Metal Tube with with screw on end
Old rifle scope.
Don
post #3 of 23 Old 08-10-2019, 09:03 PM Thread Starter
Jere39's Avatar
Originally Posted by My craftsman 917.27308 View Post
Old rifle scope.
I should have included a picture of what I would call the bottom of the tube which is closed.
ID:	2390353   Click image for larger version
post #4 of 23 Old 08-10-2019, 09:33 PM
Senior Moment
Greybeard09's Avatar
Looks like a pipe bomb... I wouldn't mess with it.
Late 50's Bready... aka, "The WoodRat"
1969 John Deere 110 w/front blade
1998-99 MTD/AYP "Black Thing" 18hp Briggs MUTT-Mower
2002 Cub Cadet 2166 (in process)
2006 Cub Cadet GT2544
2011 Cub Cadet Z-Force S 48
Greybeard09 is online now
post #5 of 23 Old 08-10-2019, 10:17 PM
You still alive, Jere?
Mrlunchbox is online now
post #6 of 23 Old 08-10-2019, 11:28 PM
Kinda small for a PB. Not much room for boom-stuff and bits of shrapnel. And you don't generally don't want to solder it with the boom-stuff inside, so they would normally have screw-on caps.
dave_r is offline
post #7 of 23 Old 08-10-2019, 11:37 PM
mytmouz's Avatar
Seismic charge...
mytmouz is offline
post #8 of 23 Old 08-11-2019, 12:15 AM Thread Starter
Jere39's Avatar
Still kicking - didn't attempt to open it yet
Would be very small for a pipe bomb, and since it has likely been there in the woods for over 30 years, not likely anyone was building pipe bombs in this area that long ago, let alone miniturizing them. I see no evidence of solder. The bottom (at least from my perspective) appears a continuous part of the side walls of the tube. As though it was extruded, or perhaps it was drilled out of a solid piece of metal.
I see no markings at all. Maybe I should apply some wire wheel to the cap for another clue.
post #9 of 23 Old 08-11-2019, 02:51 AM
Collector of many tractors
Kbeitz's Avatar
I'll be watching this....
Kbeitz is online now
post #10 of 23 Old 08-11-2019, 06:10 AM
Blank Space
Brass powder horn for muzzle loader?
LS MT125
post #11 of 23 Old 08-11-2019, 07:49 AM
Military Member
LB4502's Avatar
I would recommend taking it to the local sherfiff's department and let their EOD guys look at it. I've seen all kinds of ordnance over the years and I've not seen anything like that, but that doesn't mean it still doesn't have explosive material in it. As mentioned before, seismic charge, maybe an old style blasting cap, maybe a home made blasting cap, detonator, etc.
If you are determined to open it yourself, make sure you are grounded and you ground the case of the device to prevent static charge build-up. Just in case.
IMO, the EOD guys are your safest bet. Most likely it is harmless, but why take the chance?
LB4502 is online now
post #12 of 23 Old 08-11-2019, 11:32 AM
Blank Space
Curious if he's in an area that it could be a Civil War relic.
LS MT125
post #13 of 23 Old 08-11-2019, 11:45 AM
Country1966?'s Avatar
Put a welding helmet and welding gloves on and open it up with Chanel locks use towel in so jaws don't Mar it.. I wouldn't use a cutoff wheel.
It might be for sealing written messages for delivery during civil war
Try not to damage it; with relecs condition is everything.
Massey GC2400
Gravely ZT HD 60" 24hp Kaw.
Old Troy Build Horse Tiller
Husky Snow Blower 24" 6hp
Not Enough Barn
Country1966? is offline
post #14 of 23 Old 08-11-2019, 11:49 AM Thread Starter
Jere39's Avatar
Thanks folks. And thanks to the Reddit "Whatisthis" threads who identified it as the Central Carbon rod from a very old Zinc Carbon battery. It is not a cylinder, it is not technically a tube, and the brass end is the terminal, not a cap or lid at all.
So, good news for me, I will not explode, nor unleash some WMD. I guess it might be less good news for folks getting tired of my posts.
And, in answer to some of your comments. I do live in SE PA where there was some civil war battles. I did find civil war era bullets in the farm fields of my youth. This thing is not nearly that old. Not a seismic charge sensor nor sona bouy, nor explosive.
post #15 of 23 Old 08-11-2019, 01:33 PM
So is that a solid carbon rod?
Dan
Bolens / TroyBilt GTX20
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is online now
