Gravely flame thrower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 10-01-2015, 10:48 PM Thread Starter
Gravely 2-wheeler
No, its not a new attachment. I seem to have a similar problem to the one in this thread https://www.mytractorforum.com/24-gra...till-sick.html I was mowing in the dark tonight and the muffler was glowing cherry red and throwing a steady 8 inch blue flame. Very impressive. The other brief times I used it were during bright daylight and it wasn't that noticeable. It is a 1950 L and this is the second season that I have had it running. It sat unused with the PO for over 30 years and a couple more with me before I got around to getting it running. It has good compression, so I am thinking that the exhaust valve isn't stuck. It is hard to start cold and even harder when hot, which is why it hasn't been used much by me. It runs strong once started. It has a Bendix Scintilla mag and I cleaned and gapped the points this summer. I cleaned the carb last summer and now run ethanol free premium gas with Seafoam added.
I will check the timing and adjust as needed to see if that eliminates the flame. Is there anything else that I should check? I would really like to get it so that it starts with less pulling or needing a belt start.
Paul L
Gravelys: 1950 L, 1954 L, 1968 Comm 10A, 1969 C8, 1971 C8, 1984 5665
1967 430, 1969 432, 1980 8122
Craftsman 917.270670
PaulL is offline
post #2 of 14 Old 10-02-2015, 07:29 AM
Yokomo99's Avatar
Re: Gravely flame thrower
Sounds like it might be late timing. I advanced the timing slightly when I went to high test gas. The higher the octane level the slower the burn particularly in a low compression engine.
Please visit my YouTube pages,
The "Matthew Bergin" Channel
https://www.youtube.com/user/MatthewBergin1
and The "Bergin's Garage"
https://www.youtube.com/channel/UCJC...M8xO9nXeQ-iSQQ
“Experience is something you get five minutes after you need it.” –Stephen Wright.
1951 L
1960 LI
1973 C8
1974 816S
1975 816S parts donor
1978 8162B
Yokomo99 is offline
post #3 of 14 Old 10-02-2015, 08:00 AM
jrd
Check the timing, make sure the carb is clean and adjusted properly.
Hard starting as you describe could be timing or mixture or both. A properly adjusted L will generally start in 2-3 pulls, even if it's been sitting a while.
I run my Ls on 100LL, which is higher octane than your premium pump gas, and don't see as much drama as you're describing
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is online now
post #4 of 14 Old 10-02-2015, 08:43 AM
Gravely1964
gravely1964's Avatar
Timeing could be 180 out to. Been there done that myself
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is offline
post #5 of 14 Old 10-02-2015, 10:07 AM
I would add check the valve gap, .015" for both.
Faux Pas are my forte
beaner2u is offline
post #6 of 14 Old 10-02-2015, 02:56 PM
cmeyers77's Avatar
In regards to timing.....check the fiber coupling that couples the mag to the exhaust camshaft, too much wear will cause timing issues.
cmeyers77 is offline
post #7 of 14 Old 10-02-2015, 03:19 PM
maxmetal's Avatar
Bingo.
I would like to see a chain saw, sulky, flame-shooting Gravely in the Halloween parade.
maxmetal is offline
post #8 of 14 Old 10-02-2015, 03:50 PM
Gravely bug bit.
Originally Posted by maxmetal View Post
Bingo.
Do you want to throw a tow behind Pro Chip 310 into that mix? Not sure a 2-wheeler can pull it as the Rapid XZ is at its max with it in grass. And that is with the deck up for added traction. The Pro Chip will send its own flames up the twin exhausts.
Current L/C count = 38.
Fla Don is offline
post #9 of 14 Old 10-02-2015, 05:49 PM
Good catch Corey!
beaner2u is offline
post #10 of 14 Old 10-02-2015, 06:01 PM
cmeyers77's Avatar
Originally Posted by beaner2u View Post
Good catch Corey!
Thanks Roger, though I can't really take credit for it...I was recalling an article in a recent gravely gazette that shows photos of a worn coupler as well explained how it effects timing.
post #11 of 14 Old 07-24-2019, 02:02 AM Thread Starter
Gravely 2-wheeler
I still have a flame thrower and red hot muffler with the '50 L. I am pretty sure I adjusted the timing back in 2015 when I first reported the problem. I haven't used it in a while but would like to get it running better. I am now running 91 octane ethanol free gas with Sea Foam. At the start of the thread in 2015 I was running 87 octane 10% ethanol gas with StaBil. The 1951 and 1955 L manuals state fire should be 30* before TDC. What is the preferred timing for a '50 L running on 91 octane ethanol free to eliminate/reduce the blue flame out of the exhaust and a red hot muffler? At what point is there a kickback problem if I move firing earlier before TDC?
Paul L
PaulL is offline
post #12 of 14 Old 07-24-2019, 02:04 AM
Last time I had one with whole exhaust glowing red it was a briggs 18 horizontally opposed twin and the timing was very retarded from key way in crank and flywheel not being lined up.
TobyU is offline
post #13 of 14 Old 07-26-2019, 02:03 PM
The after burning at muffler is possible with gas additives.
edwardgoodridge is online now
post #14 of 14 Old 07-27-2019, 02:31 AM Thread Starter
Gravely 2-wheeler
I run the same mix in my '54 L, '69 C8, '71 C8 and my other 4 cycle small engines with no flame problem or excessively hot muffler.
Paul L
PaulL is offline
