Pro-16 PTO Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 06-29-2015, 07:49 AM Thread Starter
Pro-16 PTO Problem
I have a Pro-16 tractor and when I mow the grass with a 40 Kidney mower the PTO slows down or stops completely. If I stop the tractor the PTO sometimes comes back up to speed, but not always. I removed the mower and put on a cultivator to eliminate the tractor or the mower as the problem. The cultivator also seemed to slow under little pressure. Need some help...Thanks
mb49727 is offline
post #2 of 9 Old 06-29-2015, 08:38 AM
Re: Pro-16 PTO Problem
Look at pages 4-13 and 4-14 here http://gravelymanuals.com/pdf/Prof_2...v_Man_0800.pdf
You need to do the slip clutch adjustment. Careful, set the tractor on its tail when you remove the quick hitch, if it tips forward oil will spill out of the chassis. There should be five quarts of oil in the chassis.
Roger,
Faux Pas are my forte
beaner2u is offline
post #3 of 9 Old 06-29-2015, 08:46 AM Thread Starter
Thanks for the help...Roger
mb49727 is offline
post #4 of 9 Old 06-29-2015, 09:36 AM Thread Starter
Roger,
Will I only be dealing with the Dog Plate. Tighten the bolts to correct foot pounds per square inch. I don't see anything called a "slip clutch" What am I missing?
mb49727 is offline
post #5 of 9 Old 06-29-2015, 08:06 PM
Gravely1964
gravely1964's Avatar
You have to remove the quick hitch from the tractor. On the back there is a slip clutch for attachments only.
Like this on these decks on the back
Theres a spring clearance setting of .010 or something. Or my method for the older ones is go a 1/2 turn tighter at a time and repeat until satisfactory. Kinda PITA with the new style quick hitch though takeing it off each time.
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is offline
post #6 of 9 Old 06-29-2015, 08:57 PM
First of all, this is a PRO so sort of a PITA to reinstall the quick hitch, as the dog floats btw. the shaft and the brake.
Being that it's a pro, what's on the back of the quick hitch is a PTO brake. The clutch pins on the output shaft with a snap ring. That's what you'll need to check.
I find it's easiest to re-install the quick hitch and dog setup with the PTO engaged. You can slip all the pieces together fairly easily this way when you're done.
Before you open up the internals, I suggest checking the hi/low planetary adjustment as sometimes a worn or out of adjustment clutch can cause the same symptoms you describe -- but usually if it's a planetary issue it will affect your ground speed as well.
gm1276 is offline
post #7 of 9 Old 06-29-2015, 10:22 PM
Gravely1964
Section 4.8 clearly states adjusting the slip clutch. But the brake is also there
Been 2 years since I was in one
Steven Turcheck
1944 WWII L
48 L grw's
1950's Bready
48 Willy's CJ 2A
2007 F250 Big White
2010 Sc2450 yanmar
post #8 of 9 Old 06-30-2015, 12:23 AM
Gravelyyard.com
arcam8123's Avatar
Send a message via Yahoo to arcam8123
Originally Posted by mb49727 View Post
Roger,
Page 4-14, section 4.8 like Steven said.
You're lucky, yours is slipping. Most times they lockup. Few people EVER check them for proper function on the Pro tractors. Depending on the attachment being used, it can be dangerous to the tractor or to the operator. Search for "Helix maneuver".
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #9 of 9 Old 07-01-2015, 09:48 AM
I have G.A.S.
helixhippie's Avatar
. Yup!
I'm a "Heuristic Engineer".
helixhippie is offline
