I need some Onan help - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 06-28-2015, 02:29 PM Thread Starter
Dayton_King's Avatar
I am working on an Onan b48m. It was running great but when I went to start it this weekend it wouldn't run good. It would idle badly and really didn't want to rev. I have completely replaced the fuel system, and removed the carb, cleaned it, new carb kit, plugs checked intake and checked spark. I am getting spark put its not the brilliant pop it should be. My tester only goes down to 200 ohm but it tested the coil at 5.9 to 9 ohms and wouldn't stay consistent. Would a bad coil cause a engine to run rough, and act like something is terrible wrong.? How do I check condenser, I am not sure what setting to put my tester on?
1967 Allis Chalmers B10 hydro lift
1967 Allis Chalmers B10 manual lift
Gravely 8122 project to 8242 honda conversion
Gravely 8183-T project to 8203-D diesel conversion
Dayton_King is offline
post #2 of 22 Old 06-28-2015, 02:47 PM
Gravely1964
gravely1964's Avatar
Re: I need some Onan help
Bad coil will do some weird things. Had a miss in my 48 willy's jeep one day. Kinda figured bad plugs since it ran. Next week no spark at all. Coil went so it does happen.
Those carbs are a PITA to get correct some times too so double check no fresh dirt got in the carb and or bad gas
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is online now
post #3 of 22 Old 06-28-2015, 02:55 PM Thread Starter
I am 100% positive my carb is clean. With all the steps I take I know that is good. I am trying to figure if my condenser or my coil is the culprit. I am not strong with electrical work.
First pic shows my meter
Second shows what it reads
Third shows how I am testing it. Also I just noticed the black piece in the center of the coil has a crack?
ID:	1335201   Click image for larger version
ID:	1335209   Click image for larger version
post #4 of 22 Old 06-28-2015, 03:03 PM
Gravely1964
Not sure what it should measure out to, but if the plastic is cracked its getting moisture inside and its only a matter of time.
Also thats the new style coil as well been replaced at some point already.
See if Boomer comes along, or Richardtx and says what it should test to and be good.
If you replace the coil put a new condenser on with just an fyi
Steven Turcheck
1944 WWII L
48 L grw's
1950's Bready
48 Willy's CJ 2A
2007 F250 Big White
2010 Sc2450 yanmar
post #5 of 22 Old 06-28-2015, 03:05 PM Thread Starter
I believe the coil is supposed to be around 3 ohms. But good advise replace both and it can't be either lol
post #6 of 22 Old 06-28-2015, 03:08 PM Thread Starter
The crack
post #7 of 22 Old 06-28-2015, 06:04 PM Thread Starter
Any body? I would like to order the parts tonight
post #8 of 22 Old 06-28-2015, 06:32 PM
Richard-tx's Avatar
I would call Boomer and have him send a coil and a tuneup kit (points and condenser)
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #9 of 22 Old 06-28-2015, 06:40 PM Thread Starter
Does it sound like a bad coil to you?
post #10 of 22 Old 06-28-2015, 06:42 PM Thread Starter
I will start ordering parts I guess. The points and condenser are a year old and coil is is 2 years and has maybe 25 hrs
post #11 of 22 Old 06-28-2015, 07:42 PM
dayton
the coil you show should be 3.87 to 4.73 ohms for the primary.
you do need to deduct the resistance of
the leads and internal resistance of your meter.
touch the leads together and record that reading,
and subtract it from your reading.
you have not stated anything about your plug wires.
thank you. boomer
boomers_influence is offline
post #12 of 22 Old 06-28-2015, 07:53 PM
dayton
i forgot to add the secondary ( leads in the towers )
should be 37.800 + or - 10% for this late model coil.
set the meter at 200K.
thank you boomer
post #13 of 22 Old 06-28-2015, 08:39 PM Thread Starter
I will go test it now
post #14 of 22 Old 06-28-2015, 08:46 PM Thread Starter
The coil reads 40.100
The wires are 1.2 and 1.6
The meter has 1. Reistance so does that make my coil 4.3?
post #15 of 22 Old 06-28-2015, 08:54 PM Thread Starter
And my wire .2 and .6?
