Need some help finding info about my 16G - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 06-27-2015, 02:24 PM Thread Starter
I've read a lot of threads on this forum and see there are some really knowledgeable people here. Please be easy on me as I'm a noob...
I just purchased a 16G can having some troubles determining the year of the tractor as well as the spec of the engine.
Can anyone tell me what year my 16G was made? I noticed the emblems on the front cover are not the same as most posts of 16G's. Most of the one's I see say "professional" on them. The only ID tag that I can find is inside the dash panel and it shows 43780. I cant seem to find a serial number anywhere. Would there be any serial numbers stamped on the frame?
The engine is a Kohler M16 but it does not have an oil filter and the spec sticker is missing. Most of the gravely manuals refer to the M16 as a single cylinder not a twin. It has the flat square air filter. I'm hoping to find out more infor about the M16 so I can order the correct parts. I hope this info and pictures help.
My grandfather and father have owned Gravely's, mostly mid to late 70's 812's. This is the first G in our family. I'm proud to now be a Gravely owner myself.
ID:	1333921   Click image for larger version
ID:	1333929   Click image for larger version
ID:	1333937   Click image for larger version
portsider is offline
post #2 of 11 Old 06-27-2015, 10:14 PM
Re: Need some help finding info about my 16G
Welcome,
OK, first thing, the engine. I know those info stickers on those Kohler's can be hard to read when old, but your engine is not an M16, it is an M18.
Kohler did not make a 16 HP horizontal engine in the Magnum twin series, but they labeled them 16 HP for GRAVELY and left off the oil filter. They also labeled the same engine 15 HP for some Cub Cadet models. Your engine is 18 HP and the oil filter is easily added.
Someone re-did the decals.
That tractor is an early Professional G series because it has a hand control, right hand brake and transmission driven hydraulic lift - 1987, 88?
The number on the plate is the detailed model number - a GRAVELY dealer can look up when it was made/shipped/delivered - especially if you can find the serial number. Not sure exactly where it was on those years.
There are some other on here who may be able to look it and tell you more about the year - but I'm close.
Looks to be in fair shape, you will find plenty of help here.
Sheldon
ATLANTIC CENTRAL is offline
post #3 of 11 Old 06-27-2015, 11:32 PM
I agree with what Sheldon said. Your tractor has to be a 1986-88 since those are the only years to use the short steering column and the hand fwd/rev lever and right side brake pedal. Those parts all changed in 1989. Jason
my stuff
1987 8123 40"
1974 816 50", rear liftable hitch PTO, steering brakes, front PTO, snowplow, R&P steering
1977 817 50"
1983 8179KT 50", front PTO
1989 12G 40"
1995 18G 50" mulch kit, 3 can bagger steering brakes
1989 20G 50", rear liftable hitch PTO, steering brakes, front PTO
Pro8 Robin 9hp repower
Pro8
Dads stuff
1967 430 40", front PTO/30", rear liftable hitch
1978 812 40"
1990 16G 50"
1992 16G 50", snow plow, steering brakes
1989 24G 72"
2015 Gravely Atlas JSV3000
5665
Some walk behinds
my brothers stuff
1936 D Model
UFT Mountaineer 88E 30" deck, rotary plow
Pro16 40" 3-blade, 40" kidney bean,snow plow
Pro16 50" rigid mount, power brush
1996 16G 50"
lt4xtreme is offline
post #4 of 11 Old 06-27-2015, 11:40 PM
4K Poster and climbing!!!
Canary Al's Avatar
Welcome portsider. You're starting out with a nice machine.
You've just heard from 2 of the most knowledgeable. Someone will be able to nail it down I'm sure.
I see you already know -
If you can post some more of closeups of the engine and transaxle they may ad clues to the year. Neat looking engine guard.
Once again -
“Failure is simply the opportunity to begin again, this time more intelligently.”- Henry Ford
1992 - 20G-Kohler Magnum Twin (KMT) M20 big Red
1981 - 8183-repowered w/97 M18S 'lil Red
1972 - 816-repowered w/92 M18S 'lil white
1987 - Pro-12 Mr. Lucky
1984 - 8122 to get a diffrnt K301 soon.
1982 - 8123 Fred's Tractor an adoptee
1974 - 812 which is donating.
1970 - 450 w/CCKA Old Yellow
1968? - 424 - shared toy w/Grandson
1974 - C10A - for sale
1961 Ford Industrial 4000 w/Bkhoe-FEL
Canary Al is offline
post #5 of 11 Old 06-28-2015, 06:36 AM
The serial number on my early 16G is on under the hood right hand side on the outside of the plate that your model number is located
Gravely 5665 HF Powered
Kubota L245 (bought new by Dad in 1976) 'Ol Sarge
Steiner 430 MAX
Gravely 8193KT
Gravely 12G
SLGRAFTON is offline
post #6 of 11 Old 06-28-2015, 07:50 AM
Richard-tx's Avatar
Originally Posted by ATLANTICCENTRAL View Post
Welcome,
Sheldon is right. Kohler never made a Magnum 16 hp engine. Whether it actually produces 18 hp or not is a matter of debate.
Take good care of that engine. Certain core components are a little on the pricey side.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #7 of 11 Old 06-28-2015, 08:16 AM
Well, Richard, it does not produce 18 HP at the 3300 RPM governor setting GRAVELY used.
And it admittedly does not produce as much torque as those ONAN engines you prefer.
So maybe someone should have challenged GRAVELY about the advertising of the 18-G, but a 16-G easily had the implied 16 HP.
But both the torque and HP of the M18 are more than adequate running at the Kohler designed speed of 3600 RPM.
The Kohler engine was designed to run at top speed, its torque curve is pretty flat. I saw a noticeable increase in power/performance when I increased my governor speed.
GRAVELY did themselves a disservice by slowing down those engines. They may have done it thinking it would reduce warranty issues, but I suspect it caused as many problems as it prevented.
An engine that easily does the job wears less than one that struggles. My still runs great, 750 hours, 19 years, 200 hours running at 3600 RPM.
Sheldon
post #8 of 11 Old 06-29-2015, 10:03 AM Thread Starter
I thank each of you for your help!
This whole M16/M18 thing threw me for a loop. The engine has been repainted and the spec sticker removed. I had to scratch the paint away to reveal the original Magnum M16 logo. Now that I know that its really an M18, this should help me find parts for it. I was able to get the engine cranking but it wont run without spraying fuel in the intake. The fuel pump checks out so apparently I didn't do a good enough job cleaning the carb. It was pretty bad, lots of varnish from sitting for a few years full of gas.
Maybe one of these days I'll strip the paint and install correct emblems on the hood.
Canary Al,
I've posted three more pictures of the transaxle and engine if this adds any clues.
If not, thank you again for all of your input. I'm happy with knowing just knowing its in the 86-88 range.
ID:	1336385   Click image for larger version
ID:	1336393   Click image for larger version
post #9 of 11 Old 06-29-2015, 01:48 PM
Richard-tx's Avatar
What you described is a typical lack of fuel. Start by making sure that the fuel runs out of the line at the fuel filter. If it does no either the fuel shutoff valve is closed or something is blocking the gas flow possibly in the tank. If you get good flow of fuel then it is time to remove the carb for a good cleaning.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #10 of 11 Old 06-29-2015, 01:48 PM
Inveterate Putterer
Mikey4's Avatar
Canary Al,
You may also wish to replace the fuel line front the gas tank to the fuel pump, and then the short length from the fuel pump to the carb. I have a newer 16G that sat for many years before I got it. The fuel line on mine had deteriorated significantly on the inside, with most of the deterioration up near the tank.
Also, have you checked the tank shut off? It is hard to reach, but could be closed. It is at the tank, where the fuel line connects.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is online now
post #11 of 11 Old 06-29-2015, 07:35 PM Thread Starter
Since the tank was in really poor condition the first thing I did before trying to fire it was replacing the tank with a spare and replacing all of the fuel lines. Today, I found carb kit and was able to clean the carb well. Once it was clean and dry I hooked everything up, and vroom! It still needs some carb adjustments, but I'll work on that tomorrow.
I engaged the PTO and as soon as I did, it killed the engine (even at high RPM and no load on the PTO shaft). I'll have to start that investigation another day.
