The Gravely Timeline Thread - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 65 Old 06-09-2015, 03:46 PM Thread Starter
CTPhil's Avatar
Re: The Gravely Timeline Thread
Originally Posted by Gravely Frank McM View Post
My father's LI, purchased new in 1961, has a REAR-FACING aluminum Zenith, with the long moulded rubber tube from the air-cleaner, with the U-turn to the carb air-horn. (Essentially a rubber version of the earlier metal-flex tube with the cast U-turn). This machine also came with a governor, and old-style "rod-type" throttle control.
Dad's LI is Serial # M 61914 Mfg. # 12416, built in 1960, according to the PDF attachment.
I do know that it came that way from Gravely, and was never modified.
This machine also has the slotted fan housing
I'll try to grab some serial info from my other tractors...
It would be great to get a handle on just what happened in the changeover from iron to aluminum carbs.
Gravelys: 1951 L, 1952 L, 1954 L, 1956 LI, 1961 LI-SR, 1962 L, 1962 LI, 1963 LI, 1965 L8, 1965 LS, C 10, 524, 5460, 8102.
I can quit any time I want. I just don't want to right now.
The rest: 1969 WH Raider 12, 1983 WH A-111, 1985 WH 314A, AC 917H, 1978 Ford 2600, 1978 Ford 4100, 1975 Ford 3550 Industrial, 1959 Farmall 560, 1949 Case VAC, 1951 Case VAC Eagle Hitch, Troy Bilt Horse, Troy Bilt Pony. Mowers, rakes, balers, and far too much other old junk to list....
CTPhil is offline
post #17 of 65 Old 06-10-2015, 10:02 AM
cmeyers77's Avatar
We are missing something sorting big, when did gravely introduce the first two wheel tractor?
We all know the first two wheel machine is commonly known as the hex axel L, It was produced in 1930 what? Then when did the first true L come about?
Also from what I understand some early L's had an aluminum head, when did this start/stop?
I have an old Gazette at the house that has a nice write up about the L, I'm away on vacation till the 18, when I get home I'll do some digging.
cmeyers77 is offline
post #18 of 65 Old 06-10-2015, 10:15 AM
Gravely Frank McM's Avatar
"We are missing something sorting big, when did gravely introduce the first two wheel tractor? "
I believe it was 1936 ?
Gravely Frank McM is offline
post #19 of 65 Old 06-16-2015, 02:48 PM
1938- Change to single fill tank
1939-Change to Zenith carburetor
1940- Change to oil bath air cleaner
19?- Change to straight handlebars
1946- Change to Fairbanks magneto
1947- Change to Edison AJ1 magneto
1949- Change to Wico and Bendix magnetos
1953?- change to large oil bath air cleaner
1955- LI and LS start production
1957?- Bendix magneto is completely abandoned
1964?- Change to 12V Delco starter
19?- Change to 12V Bosch starter
Theo655 is offline
post #20 of 65 Old 06-16-2015, 03:26 PM
devans's Avatar
I wouldn't mind knowing when the Bosch starters were introduced. My 63 came with one and I ended up buying another for my 73. My 63 was picked over pretty good when I got it so I'm not sure if the Bosch is original.
Don Evans
I thought I had G.A.S. under control, I was Gravely mistaken
1963 L8 - Under reconstruction M 96599, M# G-5451
1972 816
1973 408 rider
1973 C - Parts tractor S/N 88418
1973 C8 - Current workhorse
1983 5200 - Current workhorse
30" Quick hitch mower
30" 106 mower
MA-210
48" plow blade
Restored Estate Sulky
Restored Standard Sulky
Lawn Roller
Pull behind dump cart
Chain guard for the 30" mower
Rotary plow
Haban sickle mower
Kwik way loader
Wish list 3/4's of a mile long
devans is offline
post #21 of 65 Old 06-16-2015, 03:35 PM
I have three L's from the mid-1960's,('63,'64,'64 ) two Supers and one Custom, all have Delco 12-volt starters, and I believe they are original to the machines.
post #22 of 65 Old 06-16-2015, 03:52 PM
I know the original starters were 6 volt Autolite (early) or Delco (later). I know the change to 12 volt happened in the early to mid 60s. My neighbor has a '63 and a '64 with electric start. The '63 is 6 volt and the '64 is 12 volt. Both starters are original. Not sure if the 6v is just a leftover that Gravely used, or if they were still used on all tractors in '63. I'm assuming the change happened in late '63 or early '64.
Theo655 is offline
post #23 of 65 Old 06-16-2015, 04:55 PM Thread Starter
CTPhil's Avatar
Adding in recent entries plus notations
"1922: The Gravely company was incorporated
1923: First production D Model built.
1924: Oldest known to exist D Model built.
1925: Wheel Design change on D Model.
1926:
1927: D Model switches from water cooled to air cooled.
1928: D Model engine design changes
1939-Change to Zenith carburetor from what?
1940- Change to oil bath air cleaner from what?
1946- Change to Fairbanks magneto from what?
1949- Change to Wico and Bendix magnetos is it that clean, or were there odd mags mixed in sometimes?
1953?- change to large oil bath air cleaner from what? the smaller one?
1964?- Change to 12V Delco starter from? from 6v? or another brand?
1958, mid year: L models were equipped with high pressure oiling systems
1958? L models went from intake cams with a protruding end to one that was flush with the engine case
1958? L models switched from spring style valve covers to the style with covers (also info on the 2 types with covers?)
1960: the Gravely Tractor Company was bought by Studebaker corporation for $12.5 million
1963: L model hoods changed from angular bent style to stamped style. any in '62?
1962-3: L models changed from oil bath to dry element air cleaners needs verification
1961-2-3? L models changed from cast iron rear facing to aluminum bodied front facing carbs. Was there a year with rear facing aluminum? Needs further narrowing
1962-3? L models changes fro the "regal" or "sunrise" red color scheme to "chevy engine orange" and off white
1964: and later L series had rectangular axle housing ends as did the Swifty 63's.
19? "Chevy engine orange" changed over to "Mustang" orange. (add other names)
19? L models incorporated a trunion block into the pto shift dog
19? L models changed fan shroud style from flower pattern to horizontal cutouts
19? L models became 6.6 HP and had beefier jug tops
19? L models switched from wood hand grips to plastic
CTPhil is offline
post #24 of 65 Old 06-16-2015, 05:04 PM
devans's Avatar
Based on the 63 manual it has the forward facing carb. I read on here somewhere it was short lived. I don't know if the 62 had it or not or how short lived it was. I was confident enough in the poster that I got one for my 63.
Don Evans
1972 816
1973 408 rider
30" 106 mower
MA-210
48" plow blade
Lawn Roller
Rotary plow
Haban sickle mower
Kwik way loader
devans is offline
post #25 of 65 Old 06-16-2015, 05:07 PM
1939- Change to Zenith carburetor from Stromberg.
1940- Change to oil bath air cleaner from side mounted Donaldson Dry air cleaner.
1946- Change to Fairbanks magneto from Edison-Splitdorf.
1949- Yes, there were some odd ones mixed in, leftover Fairbanks and Edison, a few Eisemann, I've seen a few with Wico A and C series, rather than X series, magnetos.
1953?- Change to large United oil bath air cleaner from small Donaldson.
1964?- Change to 12V Delco from 6V Delco. Not sure when the 6V ones changed from Autolite to Delco.
Theo655 is offline
post #26 of 65 Old 06-16-2015, 05:10 PM
Also:
1935- Hex axle L begins production
Late 1936?- Hex axle L is replaced by regular L.
Theo655 is offline
post #27 of 65 Old 06-16-2015, 05:17 PM
devans's Avatar
Ralph has a 57 with the autolite starter. At least it's a date even if it isn't the transition year.
Don Evans
1972 816
1973 408 rider
30" 106 mower
MA-210
48" plow blade
Lawn Roller
Rotary plow
Haban sickle mower
Kwik way loader
devans is offline
post #28 of 65 Old 06-16-2015, 05:36 PM
"1961-2-3? L models changed from cast iron rear facing to aluminum bodied front facing carbs. Was there a year with rear facing aluminum? Needs further narrowing"
Yes. There was at least one year with rear-facing aluminum.
My father bought a new LI in 1961 from the Gravely agency on Defense Highway in Annapolis. It has a "Zenith-Bendix" rear-facing aluminum carb.
It has the long, moulded rubber wrap-around hose from the air-cleaner to the carb.
Its numbers are as follows:
The Gravely serial number pdf from the Stickies puts this machine as a 1960.
This machine also has a governor. Don't know if this feature was factory or dealer-installed.
Dad bought this machine new in 1961, and I came along in 1967. I began cutting grass with it around 1972 ( Dad would start it for me, I would mow the grass and hopefully not stall it ! )
Dad never replaced any parts on the machine, except the gas-tank, which tended to crack around the square bung-reinforcement.
I still have the machine.
Further clarification: Red & Black, with "old-style" brake-bent hood, tin shields on top and sides of cylinder, slotted fan intake, four-blade fan, Wico X magneto, Full-pressure oiling with spin-on filter and gauge.
post #29 of 65 Old 06-16-2015, 06:06 PM
I have a '57 with a non-protruding intake cam, so it didn't change in '58. I would guess '55, because I have seen '56 tractors with non-protruding intake cams.
Theo655 is offline
post #30 of 65 Old 06-16-2015, 06:08 PM
Also, the Convertibles had rear facing aluminum carbs.
Theo655 is offline
