Plow Gear Box Seals on model L(old style) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 04-25-2015, 06:02 PM Thread Starter
Procedure for doing this? As simple as pulling seals without dismantling gear box?
Also, the hexagonal tube the plow slides into. Should there be any side to side movement if I try to move it by hand? I have about 1/16" movement total. Thanks
tmays is offline
post #2 of 3 Old 04-25-2015, 07:14 PM Thread Starter
Re: Plow Gear Box Seals on model L(old style)
I figured the seal replacement out. But mine had two seals on top and bottom. Manual I looked at showed one on each?
tmays is offline
post #3 of 3 Old 04-25-2015, 07:35 PM
Richard-tx's Avatar
Due to the unavailablity of the original wide seals, Gravely used 2 narrow ones.
There should be no movement side to side. Either the bearings are bad or someone added shims that should not be there. If the seal plates are not tight, then that could cause excess slop in the bearings.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
