-   Gravely (https://www.mytractorforum.com/24-gravely/)
-   -   Need advice on battery for Commercial 12 (https://www.mytractorforum.com/24-gravely/791665-need-advice-battery-commercial-12-a.html)
coss 04-20-2015 03:21 PM
I'm about to pick up an early 1970s Commercial 12 that has been mothballed for years. It will need a new battery.
What would you recommend?
CADplans 04-20-2015 04:33 PM
Re: Need advice on battery for Commercial 12
I go to Sams (or Walmart) and get the cheapest thing that fits!! :thThumbsU
http://i1104.photobucket.com/albums/...ps5bff237a.jpg
Don't forget to take the old one back,,,, :hide:
PaulL 04-21-2015 02:09 AM
I snagged some Sears Plus Start batteries on sale for $59. I have also bought used from an auto salvage yard for $25. I think the size is group 24F. Take your measurements and note the orientation for + and - posts based on the cables. I keep unused batteries indoors over the winter and rotate a HF battery float charger between them with 1 month on each battery since I have 6 batteries to maintain.
minnesota outdoors north 04-21-2015 04:32 AM
I get mine at fleet farm for 21..99 and on sale for 16.00... the usually last me 6 years
it is the 12 L size and although smaller they put out 300 cranking amps...they work great for me...if you are going to use them for an electric pto clutch then you want the higher output or your electric clutch will not engage...
PA RedRider 04-21-2015 07:14 PM
I run 26R's in all my Gravelys, 2-wheel or 4-wheel.
coss 04-26-2015 09:01 PM
The NAPA book said to use 26R, which is what I got. I measured the 24F, and it might have squeezed into the battery tray, but it also may have been about 1/8" too wide, and I didn't want to risk it.
After sitting in a garage for at least 25 years, it fired right up. It does, however, leak gas out the bottom of the carburetor, so I will be starting a new thread to ask for advice about this problem.
Thanks for the help.
Theo655 04-26-2015 10:43 PM
I would use a Group 35. I buy my batteries at the junkyard for $15.
