CCKA Rebuild - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 194 Old 10-27-2014, 06:03 PM Thread Starter
SteveSWMI's Avatar
CCKA Rebuild
Couple questions:
1. Is the botton of the cylinder supposed to be pitted?
2. Are the valves supposed to have grooves?
This is the 1973 816 limited slip with steering brakes I picked up that had the broken shifter fork. After replacing the shifter fork I used it to mow the grass, 3-4 acers. I started to notice it used oil and had noticeable blow by, also I couldn't keep the oil clean. This model cck has the breather straight to atmosphere which makes the blow by more noticeable, not so much visually but you could smell burnt oil. Other than that, it honestley ran great. Knowing it was pretty worn out I imagined some wear inside but was surprised to see the pittting and worn valves.
If it had enough power to swing a 50" deck and pull a 60" tow behind in this condition I cant wait to see what it is like rebuilt!
ID:	1021321   Click image for larger version
ID:	1021329   Click image for larger version
ID:	1021337   Click image for larger version
SteveSWMI is offline
post #2 of 194 Old 10-27-2014, 07:26 PM
Richard-tx's Avatar
Re: CCKA Rebuild
no and no
It is hard to tell what condition the valves are in. It is possible that what you are seeing is just deposits.
Looks like you will need to have the block bored to get rid of the pitting.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #3 of 194 Old 10-27-2014, 08:46 PM
CADplans's Avatar
Re: CCKA Rebuild
The pitting may be "optically" deep,,,,, I would hone it before I bored it.
The pitting might only be 0.001" deep,,,, honing would "fix" that!!
CADplans is offline
post #4 of 194 Old 10-27-2014, 09:40 PM
Inveterate Putterer
Mikey4's Avatar
Re: CCKA Rebuild
I agree. I have seen scored cylinders clean up nicely with a good honing. True enough, you only get to do it once, but I always think it better to do the least first and escalate only as necessary.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is offline
post #5 of 194 Old 10-27-2014, 10:08 PM
Richard-tx's Avatar
Re: CCKA Rebuild
Time to measure the bore. No sense in honing if the bore is already worn out of spec.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #6 of 194 Old 11-04-2014, 01:47 PM Thread Starter
SteveSWMI's Avatar
Re: CCKA Rebuild
Finally had some time to finish taking things apart. I will be taking everything in to be measured up and get the diagnosis.
I will report back after.
ID:	1031041   Click image for larger version
ID:	1031049   Click image for larger version
post #7 of 194 Old 11-04-2014, 01:49 PM Thread Starter
SteveSWMI's Avatar
Re: CCKA Rebuild
One more picture
post #8 of 194 Old 11-04-2014, 03:59 PM
Richard-tx's Avatar
Re: CCKA Rebuild
Be sure to bring a copy of the dimensions and tolerances from the manual.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #9 of 194 Old 11-04-2014, 04:00 PM Thread Starter
SteveSWMI's Avatar
Re: CCKA Rebuild
Thanks Richard thats a good reminder!
post #10 of 194 Old 11-04-2014, 09:53 PM
Ralph
Re: CCKA Rebuild
Looks like a fun project I need to do the same with mine. I bought a digital dial bore indicator so I can measure my own bores. It comes in very handy....
post #11 of 194 Old 11-04-2014, 09:58 PM Thread Starter
SteveSWMI's Avatar
Re: CCKA Rebuild
Where did you get the digital dial bore indicator from? Was it expensive?
post #12 of 194 Old 11-04-2014, 10:08 PM
Richard-tx's Avatar
Re: CCKA Rebuild
I almost bought a bore indicator until I realized that it really didn't do what was needed. A bore indicator is OK but it won't tell you if the worn bore is elliptical and by how much which most are. You can't get a good ring seal if the bore is egg shaped.
This is what I use. Takes a little more finesse to use but you know what you have when you are done.
2"-12" inside micrometer from Fowler. About $100. Includes standard.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #13 of 194 Old 11-05-2014, 05:55 AM
Ralph
Re: CCKA Rebuild
My digital bore indicator works great. It will measure run out etc like the post above mentions. You Ali need a micrometor to calibrate it. The dial indicator was around $100 I think I either got it on eBay or amazon..
post #14 of 194 Old 11-05-2014, 06:01 AM
Ralph
Re: CCKA Rebuild
Here it is. It's only $50 now. You need to get a 3-4" micrometor to set this two. For example you need to set it to a known value. If your bore is 3.25" you start by setting the indicator to 3.25". I should make a video of how to use it....
Http ://www.ebay.com/itm/330880385983
post #15 of 194 Old 11-05-2014, 07:51 AM
Richard-tx's Avatar
Re: CCKA Rebuild
That would work. I was referring to the 3 legged variety. Those won't work.
Code:
                              Current Inventory
                              8183T (Onan B48)
