Trailer Jumping : The Legend Continues.... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 38 Old 09-20-2014, 08:55 PM Thread Starter
WH401's Avatar
Haha, it seems it has struck again.
As I mentioned in the, "What did you do with your Gravely," thread, I got a lead on a CCKA powered 816 earlier this week. Today I made a short 500 mile round trip to go pick it up. The guy i got it from picked it up in the early summer, but found he was never going to get around to working on it. he mainly was looking for a trade, not cash. He's a collector of all tractors, no matter the brand or features. I offered him my 75' 810 and he liked that so we struck a deal.
It's in fairly good shape overall. The Onan runs, I heard it and saw it running today, and it has all the normal 816 features including rear liftable hitch, snow plow latches, and PTO axle block. It also has the very rare Gravely individual steering wheels, not be confused with individual rear wheel brakes, . Obviously it needs a little work. The steering arm on the bottom of the sector box is missing its key and the wheel just spins; the reverse clutch has worn out splines, (the forward was well greased but not the rev,); there's an oil leak somewhere on the left side of the engine, as you can see the rear hitch and left axle is coated in it; the rear hitch is missing the lift rod that connects to the rocker shaft; the fuel tank collected water and is coated in rust on the inside; and the hydrualics leak down, which may be where the leak is. Overall though I'm happy. I only paid $150 for the 810, and it actually came from about 20 minutes up the road from where I got this 816. The serial looks to put the tractor as a 74'
Rick
Name:	ImageUploadedByMyTractorForum Free App1411260755.420945.jpg
ID:	977369Click image for larger version
Name:	ImageUploadedByMyTractorForum Free App1411260787.638012.jpg
ID:	977377Click image for larger version
Name:	ImageUploadedByMyTractorForum Free App1411260828.422192.jpg
ID:	977385Click image for larger version
Name:	ImageUploadedByMyTractorForum Free App1411260844.098049.jpg
ID:	977393Click image for larger version
Name:	ImageUploadedByMyTractorForum Free App1411260888.983603.jpg
Sent from the MTF Free App
1960's-70's IH 340
1974 Gravely 816
1977 Gravely 817 (2)
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #2 of 38 Old 09-20-2014, 09:13 PM
devans's Avatar
Re: Trailer Jumping : The Legend Continues....
Nice grab!
You may be right that the leak is coming from around the hydraulic pump, check the hard lines for tightness or maybe the gasket is leaking. The reverse clutch is dirty too so it could be coming from the seal there.
The steering wheel will spin when the gear at the bottom of the wheel shaft disengages from the sector gear in the box so it may not be a missing key.
Don Evans
I thought I had G.A.S. under control, I was Gravely mistaken
1963 L8 - Under reconstruction M 96599, M# G-5451
1972 816
1973 408 rider
1973 C - Parts tractor S/N 88418
1973 C8 - Current workhorse
1983 5200 - Current workhorse
30" Quick hitch mower
30" 106 mower
MA-210
48" plow blade
Restored Estate Sulky
Restored Standard Sulky
Lawn Roller
Pull behind dump cart
Chain guard for the 30" mower
Rotary plow
Haban sickle mower
Kwik way loader
Wish list 3/4's of a mile long
devans is offline
post #3 of 38 Old 09-20-2014, 09:22 PM
Gravely1964
gravely1964's Avatar
Double check all the fittings at the pump. Had one at work we had the tranny out of and put back and the fitting at the pump I didn't touch started leaking.
But at any rate nice haul (again)
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is offline
post #4 of 38 Old 09-21-2014, 01:02 PM Thread Starter
WH401's Avatar
Thanks guys, ill check the fittings and the steering shaft and see what's up. At the moment the arm that comes off the bottom of the box can't be attached because that's where I'm missing a key. As you can see both wheels are pointed out wards at the moment because of this.
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #5 of 38 Old 09-21-2014, 08:46 PM
wjohn's Avatar
The bona fide 816 models are pretty sweet. Now you get to compare the original CCKA-powered version to your 816T.
'72 John Deere 110, '39 and '40 Allis Chalmers Bs, '41 WC, '56 WD-45, '80 Gravely 8102, '63 L8, '52 L, '63 LI, '73 CI, '68 C10A, '57 LI, '58 LI, '69 C8, '58? Wisconsin LI, '73 816, '72 816, '40 L SN 2958, '71 450, '70 432, '48 L, '51 LI, '66 C10, '79 5240, '81 UFT Mountaineer 120E
Looking for: Gravely LS/CS, various '40 L parts
wjohn is offline
post #6 of 38 Old 09-21-2014, 09:47 PM
4K Poster and climbing!!!
Canary Al's Avatar
Quite a list of maladies there Rick but your the right guy to figure them out. I wonder if those reflectors on the back are original? Can anyone shed any light on that?
“Failure is simply the opportunity to begin again, this time more intelligently.”- Henry Ford
1992 - 20G-Kohler Magnum Twin (KMT) M20 big Red
1981 - 8183-repowered w/97 M18S 'lil Red
1972 - 816-repowered w/92 M18S 'lil white
1987 - Pro-12 Mr. Lucky
1984 - 8122 to get a diffrnt K301 soon.
1982 - 8123 Fred's Tractor an adoptee
1974 - 812 which is donating.
1970 - 450 w/CCKA Old Yellow
1968? - 424 - shared toy w/Grandson
1974 - C10A - for sale
1961 Ford Industrial 4000 w/Bkhoe-FEL
Canary Al is offline
post #7 of 38 Old 09-21-2014, 09:53 PM Thread Starter
WH401's Avatar
Thanks! I agree, I can totally see why they were one of the most important models in Gravelys entire line. You really get a whole, and a pretty awesome looking tractor at that. There's just something about seeing that big ole' CCKA sitting there on the back end. It just gives the tractor an entirely different stance.
Thanks Al! I'm looking forward to it, with the steering in the condition that it is I may have to work on my R/P conversion quicker than I had planned. Not sure on the reflectors, ill have to take a closer look and see.
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #8 of 38 Old 09-27-2014, 08:37 PM Thread Starter
WH401's Avatar
Got a chance to really look the tractor over tonight. I figured out why the steering wheel just spun. When the set screw on the output shaft of the sector box loosened up and the key fell out, the wheel was over turned completely in one direction. If you turn the wheel all the way in one direction with the steering arm disconnected then the gear gets dislodge from the shaft, which I'm assuming is the same thing that was mentioned earlier in this thread. Turning the output shaft and the wheel at the same time got the gears realigned. I replaced the key with a spare that I had, and now the steering works enough to be able to drive it. The box does have the usual amount of play, about 5" of the wheel turning to either side before it goes right or left. Are all of the sector boxes supposed to have grease zerks? The 810 I trade had it, it was a 75', and my 432 has one, but I can't seem to find one on this 816.
I had hoped to fire it up tonight. Got the terminals cleaned up and an IV tank going to the carb. As I was opening the valve on the tank, (I had already hooked up the battery about a minute prior,) I started smelling an electrical burning smell near the engine. I started checking the wires and noticed the bundle of wires going to the stator, and whatever else may be down behind the flywheel, was getting way too hot. Key wasn't even on, and the battery was just hooked up. Looks like ill have to look into the wiring before I can fire this thing up.
All in all though, glad I was able to get the steering fixed pretty easily.
Rick
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #9 of 38 Old 09-28-2014, 01:08 PM
RedRider8179KT's Avatar
Good luck with the 816. Once everything is sorted you'll enjoy it. I rewired mine from end to end last year and it was well worth the trouble. While I was at it I replaced regulator and relocated it to under the dash.
RedRider8179KT is offline
post #10 of 38 Old 09-28-2014, 06:22 PM Thread Starter
WH401's Avatar
Thanks! Hope to get it going soon. I've had to completely rewire two tractors in the past and even though it's a pain, it's worth it in the long run. Did yours have the regulator behind the flywheel? I know some of them do. Mine has some thing that looks like a regulator mounted on the inside of the frame below the seat pan. Don't believe it's the regulator though.
I spent some time pulling the R/P retro fit kit from my 810 parts tractor. On one side the bolts came off fine, the other side required an angle grinder with a cut off wheel. After about 30 minutes I had it out; was even able to separate the steering wheel from the shaft. The shaft has seen better days. I'll go with it for now, but keep my eyes open for a replacement. This 810 sat in the woods for a while and the old battery completely disintegrated the frame. Worst shape I've ever seen a frame in. The weldment will need a little derusting and some paint, but the core pieces of it are in good shape. Now to find the rest of the parts that I removed 2 years ago and make a template. This 810 was my first rider, never had it running, but it's amazing the amount of stuff I've been able to pull off of it.
Rick
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #11 of 38 Old 09-28-2014, 09:11 PM
yamato72's Avatar
Don't know what you paid for the 810 but I'm guessing just the R&P kit made it worth the purchase. And you mentioned getting other parts off it, to boot.
yamato72 is offline
post #12 of 38 Old 09-29-2014, 10:29 AM Thread Starter
WH401's Avatar
I think I paid about $315 for it. That price included a running L with a snow plow, a 106 mower with a sheared horizontal shaft, and the 810 came with a complete 40" commercial mower running off of a front drive kit with lift assist. I think I made it all back after selling the L with the repaired 30" mower. From just that 810 I've been able to pull off and use: entire front drive kit and mower, front wheels and tires, hood, 1 rear hub, (can't get the other one off,) clutch studs, carb, fuel pump, grass catcher screen, hitch, and now the R/P retro fit kit. I think I've gotten my moneys worth from it...
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #13 of 38 Old 10-12-2014, 09:40 PM Thread Starter
WH401's Avatar
Had a little time to start jumping into the wiring issue. Interesting to find that the inside of the shielding was painted yellow. Perhaps the engines were painted a standard color by Onan at the factory before going to equipment OEMs? I pulled the flywheel and, "holy oil build up Batman." Though, any CCKA I've ever seen on this board has never been clean on initial inspection. After brushing and picking away some of the layers of dirt I found the wire connector going to the stator. One of the two yellow wires is corroded, almost broken off, and missing its insulation. I'd say that's probably the wiring problem. From what I can tell it looks like someone removed the original regulator behind the flywheel, based on the two wires in that 4 wire connector that were cut off. Its now located on the inside frame rail under the seat. My goal is to patch the wiring up enough to run and inspect all functions, PTO and such, before tearing deeper into it. I'll keep my eyes open for a good used exhaust, this one had already been welded on numerous time. Anyone know the PT# for the original one? Couldn't find it noted in any IPL.
ID:	1002177   Click image for larger version
ID:	1002185   Click image for larger version
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #14 of 38 Old 10-12-2014, 11:33 PM
wjohn's Avatar
From what I remember others telling me, that may have been the primer color from Onan. Here's a picture of one of the shroud pieces from my '73 816. You can see the yellow on the inside as well. It definitely has a different tinge from the yellow that Gravely used on the earlier Commercial series machines.
wjohn is offline
post #15 of 38 Old 10-13-2014, 12:12 PM
yamato72's Avatar
This is correct, sir.
yamato72 is offline
