Trailer Jumping : The Legend Continues.... - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 38 Old 11-30-2014, 09:32 PM Thread Starter
WH401's Avatar
Re: Trailer Jumping : The Legend Continues....
Thanks all! Tidyied up the wiring today, adding wire loom in the right places, securing it all in place. Added a proper fuel tank so it could come off the bottle. Adjusted and greased the fwd clutch, needs a new bearing but works a lot better now none the less. Put the rear hitch back on and actually got to use it for the first time moving some firewood today. Ran pretty well, still needs carb work, I have to feather the choke at times to run. May try swapping a DD carb on to it if I find one for the right price.
Rick
ID:	1068225   Click image for larger version
1960's-70's IH 340
1974 Gravely 816
1977 Gravely 817 (2)
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #32 of 38 Old 07-05-2015, 09:00 PM Thread Starter
WH401's Avatar
I feel like this is probably my first lengthy post in about the last two months. Work was beyond busy in May/June, along with the personal life, so now I'm finally getting a chance to get caught up on some projects.
I tackled the "8" of play" sector steering in the 816. I took the box from my 72', which was less worn, and then JBWelded a few aluminum strips to keep the gear from moving up and down. Also added a zerk to the box, along with some grease-able tie rod ends. All of that took my play down to about an 1". The rest is in the king pins and axle bushing.
Name:	ImageUploadedByMyTractorForum Free App1436144103.058995.jpg
I needed to replace the front tires since the ones on it now would just plow whenever you made a turn. I cleaned an extra seat of wheel I had, mounted new Carlisle Turf Savers, and then painted them in Duplicolor Exact Match Stone White. It's a slight off white, though not as much as Canvas White. I was going to use Canvas White but it can't be found in any of the local stores. Overall I think the Stone White was a fairly good match. It definitely made it all look and function a lot better than what was on it before. One thing I found interesting was that the left hand side had a spindle with a longer shaft, so the bearing cap could only be seated half way on. The right side was fine though.
Before
Name:	ImageUploadedByMyTractorForum Free App1436144151.465310.jpg
ID:	1343489Click image for larger version
Name:	ImageUploadedByMyTractorForum Free App1436144175.755127.jpg
After
Name:	ImageUploadedByMyTractorForum Free App1436144195.511262.jpg
Overall this has become one of my favorite tractors. The CCKA just purrs and runs fantastic. I'm looking forward to tearing into my 72' LSD keyed clutch 816 later in the year. Although I may literally be tearing into it since I'm pretty sure the PTO clutch is gone.
Rick
Sent from the MTF Free App
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #33 of 38 Old 07-05-2015, 09:21 PM
Gravelyyard.com
arcam8123's Avatar
Send a message via Yahoo to arcam8123
looking good!
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #34 of 38 Old 07-05-2015, 09:22 PM
devans's Avatar
Looking good Rick, at least yours is red and white. Mine is still gravely red and rust red. Lols.
I know what you mean about the 816 being the favorite, mine is too.
Don Evans
I thought I had G.A.S. under control, I was Gravely mistaken
1963 L8 - Under reconstruction M 96599, M# G-5451
1972 816
1973 408 rider
1973 C - Parts tractor S/N 88418
1973 C8 - Current workhorse
1983 5200 - Current workhorse
30" Quick hitch mower
30" 106 mower
MA-210
48" plow blade
Restored Estate Sulky
Restored Standard Sulky
Lawn Roller
Pull behind dump cart
Chain guard for the 30" mower
Rotary plow
Haban sickle mower
Kwik way loader
Wish list 3/4's of a mile long
devans is offline
post #35 of 38 Old 07-05-2015, 09:39 PM
Inveterate Putterer
Mikey4's Avatar
Rick, is that the tractor you had at Chambersburg? Looking really good.
I know exactly what you mean about that tire tread pattern. I have three perfectly service sets of them, one coming from my 812. They're terrible! I can't count the times I steered left or right and they just continued in whatever direction they were going. Compound that on the vague sector steering and direction control was, at best, a mere suggestion of intent!
About the wheels: you painted them after mounting the tires or before?
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is online now
post #36 of 38 Old 07-05-2015, 09:48 PM
devans's Avatar
Now THAT is one of the funniest statements I've seen in a while!
Don Evans
1972 816
1973 408 rider
30" 106 mower
MA-210
48" plow blade
Lawn Roller
Rotary plow
Haban sickle mower
Kwik way loader
devans is offline
post #37 of 38 Old 07-05-2015, 09:56 PM
wjohn's Avatar
I hear you... I probably have 5 different threads hanging out there right now that I haven't touched in months.
I agree about the 816. They're just a fun unit to run even if they do suck down the gas. They certainly were the top-of-the-line unit in the '70s.
'72 John Deere 110, '39 and '40 Allis Chalmers Bs, '41 WC, '56 WD-45, '80 Gravely 8102, '63 L8, '52 L, '63 LI, '73 CI, '68 C10A, '57 LI, '58 LI, '69 C8, '58? Wisconsin LI, '73 816, '72 816, '40 L SN 2958, '71 450, '70 432, '48 L, '51 LI, '66 C10, '79 5240, '81 UFT Mountaineer 120E
Looking for: Gravely LS/CS, various '40 L parts
wjohn is offline
post #38 of 38 Old 07-06-2015, 08:36 AM Thread Starter
WH401's Avatar
Thanks guys!
Don, I have no doubts you'll get that 816 to it's proper red and white scheme. Painting is not one of my best skills, so I cheat and try to find tractors with good original paint lol.
Mikey, no the one I had at Chambersburg was my 816T, which actually now needs a coil, so that's another project I need to get to. For the rims I debated whether to paint them before or after mounting the tires, and ultimately decided to paint after. I knew that if I did it before I would take all the paint right off the edge of the rim with the tire changer. I just taped both sides of each tire off up to about the tread, and that worked perfectly. A degrease and wash with purple power, some sanding, 2 coats of Rust Reformer, and 3 coats of Stone White was the process. I may try doing the set of rims I took off in a slightly more off white paint and see how that turns out.
Rick
1960's-70's IH 340
1974 Gravely 816
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
