Gravely Photo Thread - Page 12 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #166 of 328 Old 07-07-2014, 06:50 AM
Duggit's Avatar
Re: Gravely Photo Thread
Found a LI in a barn with a broken intake. Thinking late 50's?
The tank that was on it leaked, so I through a spare on until I get something done with it.
ID:	879745   Click image for larger version
ID:	879753   Click image for larger version
ID:	879761   Click image for larger version
Duggit is offline
post #167 of 328 Old 07-07-2014, 09:21 AM
TheCaffeinatedOne's Avatar
Sweet! Can you tell us the serial number from the gas tank label? That can place its age pretty closely. It looks in beautiful original condition, and the gear reduction wheels are choice.
  • 1995 JD GT242, chains, loaded tires, wheel weights, repowered with Briggs Intek 18 hp V twin, named Lazarus.
  • 1978 Bob-Cat 21" self propelled C/I mower project.
  • 1954 Gravely L, s/n 93863 project
  • 1964 Gravely L1, s/n 2M4903, GRW rolling chassis.
  • 1966 Gravely L8, s/n 2M45423 project
  • 1967 Gravely C8, s/n J-17080, running strong!
  • Two Subarus, a Toyota and a Mitsubishi Pajero named Attila.
TheCaffeinatedOne is offline
post #168 of 328 Old 07-07-2014, 09:43 AM
Duggit's Avatar
Here are some more pics....
ID:	879873   Click image for larger version
ID:	879881   Click image for larger version
Duggit is offline
post #169 of 328 Old 07-07-2014, 10:05 AM
cmeyers77's Avatar
Based off of the serial number it is a 1962, but based off of the protruding intake camshaft the engine is much older, also the small oil bath air filter dates it earlier than 1962. My concern is that I've noticed that the oil filter is plumbed as if the engine has a high pressure oil pump when that crankcase originally came as a low pressure oiling system. Some more close up photos of the tractor can help further identify, such as how many bolts are holding on the advance casting, a photo between the lower pulley and the engine case, this will show the oil pump. I must say you scored a very nice looking well preserved L, I love how the hood decals are I. Such good shape.
Edit....
It looks like you have two different L's, the serial number that indicates a 1962 I suspect is from the L with the duel wheels and sickle bar, while I thought it was for the one with the gear reduction wheels. Any chance the older L with the gear reduction wheels still has a serial plate still attached? Still nice pair if L's
Sent from the MTF Free App using a device with auto correct
cmeyers77 is offline
post #170 of 328 Old 07-07-2014, 10:16 AM
Duggit's Avatar
I changed the oil lines to the low pressure system yesterday after is was brought to my attention that there was a difference between high and low.
Duggit is offline
post #171 of 328 Old 07-07-2014, 10:19 AM
Duggit's Avatar
Edit....
Same tractor...different look.
I don't think its a 60's tractor either...but it is an LI.
Duggit is offline
post #172 of 328 Old 07-07-2014, 09:42 PM
cmeyers77's Avatar
Oh, okay, the fan housing was probably replaced along with the serial plate. Really you should figure out what oil pump is installed, if it is a low pressure pump you should correct the plumbing otherwise you risk starving the engine of oil. That crankcase is defiantly pre high pressure oil pump, though.....it's not totally uncommon to see an early crankcase converted to the newer high pressure oil pump.
post #173 of 328 Old 07-31-2014, 09:28 PM
Not much to show but here are my few goodies
ID:	911113   Click image for larger version
ID:	911121   Click image for larger version
ID:	911129   Click image for larger version
mcraig79 is offline
post #174 of 328 Old 08-10-2014, 05:59 PM
maxmetal's Avatar
A couple of shots of my forlorn LI:
maxmetal is offline
post #175 of 328 Old 08-10-2014, 06:54 PM
CADplans's Avatar
[QUOTE=maxmetal;6050706]A couple of shots of my forlorn LI:
Whats forlorn??
It looks ready to work!!
This is forlorn!!
BUT, even that forlorn Gravely is running today (under new ownership,, LOL)
CADplans is offline
post #176 of 328 Old 08-10-2014, 08:28 PM
yeah CAD it should look familiar. its the machine i use alot with the trencher and stump grinder mostly. it all works nicely.
mcraig79 is offline
post #177 of 328 Old 08-11-2014, 01:42 PM
Hi all, figured I would join in. My 5665 that I got from my dad (original owner) and my '54 (Not sure of model) that I picked up Saturday. Got the multi-mode on the 5665 and the '54 is going to be my main brush machine. May have to hunt down an old 106 deck for the '54, as the new style 30" doesn't sit quite flush with the ground when hooked up. May not be a huge deal.
coferj is offline
post #178 of 328 Old 08-11-2014, 02:07 PM
boodogboo
boodogboo's Avatar
Not much but they are all still working!!!!!Click image for larger version
boodogboo is offline
post #179 of 328 Old 08-17-2014, 08:49 AM
shallowwatersailor's Avatar
I was re-arranging my projects for the week and had all of the Gravely tractors out.
2000 Toro Wheel Horse 520xi
1998 Toro Wheel Horse 518xi
1998 Toro Wheel Horse 523Dxi
1983 Wheel Horse C-105
1981 Wheel Horse C-145 Automatic
1981 Wheel Horse DC-105
1981 Gravely 5240
1980 Gravely 5665
1980 United Farm Tools Mountaineer
1974 Gravely C-8
1962 Montgomery Ward Power Trac
1952 Simplicity Model L
1951 Montgomery Ward Chor Trac Special
shallowwatersailor is offline
post #180 of 328 Old 08-17-2014, 10:01 AM
Just starting my project of adapting a gravely power broom/brush to work on the back of my Kubota. Tore it down, ready to change the drive from 1 side to the other. This should make it spin correctly. Adapting a 3pt hitch to it, eventually
*****Dang, meant to post this on the "what did you do" forum***
Gravely 5665 HF Powered
Kubota L245 (bought new by Dad in 1976) 'Ol Sarge
Steiner 430 MAX
Gravely 8193KT
Gravely 12G
SLGRAFTON is offline
