new shoes for the 812 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 06-26-2011, 02:19 AM Thread Starter
Dad usually keeps this 1978 812 up in the mountains at his hunting camp/trailer park but it was needing some work so he swapped it out with on of the 16G. I had to weld up the seat pan and straighten up the back some. It was backed into a tree and busted up the flywheel, screen, and blower cover. Dad replaced those parts at camp but it was missing so he brought it home. Turns out the bent seat pan was contacting the coil and shorting out the coil when he hit a bump. The tires leaked really bad so I got the back ones changed a couple weeks ago and the fronts yesterday. Installed some wheel studs and relined the brake band with the woven material from Mcmaster Carr also adjusted and greased the clutch assemblies.
new Carlise Turf Savers 23/8.50/12 and 16/6.50/8
My buddy Sam's boy Dustin mowing in front of the shop
lt4xtreme is offline
post #2 of 15 Old 06-27-2011, 11:01 AM Thread Starter
Re: new shoes for the 812
I bought 2 feet of the 3/16" thick woven brake lining material from Mcmaster carr that will be enough to make 3 brake bands. I rolled it up tight and put a piece of wire around it for a few days to get it into shape. Then I cut it to size and dry fit it into the brake band and installed it back on the Gravely set the brake and left it for a few days. That really got it fitting well and made it easy to work with when applying the JB Weld epoxy. i coated the back side of the lining, fit it back into the band and then onto the Gravely again and set the brake to allow it to cure. Seems to work great. Less than $10.00 for enough to fix 3 sure beats $80.00 for a new one.
post #3 of 15 Old 06-28-2011, 01:42 AM
CalifornianGravelynator
rustyrideon68's Avatar
Great job
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
My name is Mike and I own these tractors, a...
68 Gravely 430 (40" Comm mower)
80 Gravely 8163-T (L.S.D trans)
(Mighty Mac Shredder)
67 Gravely 424 (40" kidney mower)
66 Gravely C8, with Governor and soon elec start. Rotary Plow, Rotary cultivator, and 30" deck x2
48 Gravely model L ,G.R.Hs with rotary plow
?? Gravely 5660 30" finish mower
72 Gravely 814, cig lighter parts machine(NFS)
72 Simplicity Landlord 3410 H with MM grading blade.
7? Allis Chalmers 314 D with Electric lift 3pt, tiller and 42" MM mower
74 Wheel horse D-160, 3pt, rear scraper blade. in sad shape.
79 (MTD) Dayton 11hp but looks great, "Survivor" ,and a 72 (Gilson)Wards 16 hydro w 48" MM mower
78 John Deere 214, 38" mower + brass tag snow plow ( I dont really need the snow plow). project. will get Onan 18hp. when its repaired
79 Sears LT 10/36 MMM.... also have a 70s HAHN LTD 500 RER, Electric conversion, when I have $
78 Sears GT/19.9 Six Spd with a Loader, dually, WW, MMM, Waren elec 3pt, dump tote box, disc harrow, Front mount shredder, rear scraper blade, Onan N52M-GA. low hours machine
81 Sears GTV Custom. Will get Wisconsin 18.5 hp THD. may have a Turbo. Or a 27hp Kohler needs a bore and .10 oversize pistons ....Nothing runs like a deere running from my GRAVELYS.................................. THE
87 Pontiac Fiero GT V6 3spd...69 Dodge A-108 Sportsman ,318 ,3spd man. McCulloch 10 (MAC 10) 2 vintage backpack blowers, 1953 Briggs and Stratton 6S , a B&S 1950 5S too with Firestone plug. GO BUCKS! OHIO State U
rustyrideon68 is offline
post #4 of 15 Old 06-30-2011, 05:44 PM
VigII's Avatar
I've owned a few of the L series two wheelers. I still use my 65 and have darn near every attachment for it some place or another. I was visiting with an old friend of mine who has three 812 all inside. They're in various stages of disassembly, two motors and a parts unit and two rough mower decks. He's offered them to me since he's up in years and doesn't want to fix stuff anymore. What's the general opinion, it it worth pulling this stuff home? Oh - and theres one that I don't remember the model of, a 4xx something or other.
Don't take me wrong - I love Gravelys and always have. It's just that I'm running out of room with two Massey-Ferguson MF10 and attachments, the L8 and her attachments and my most recent, a MF GC2310. Therefore my question - is it worth dragging all this home? I'm not sure about the engines but I know they're getting hard to find. I don't know if I want to get involved in re-powering unless therm's a adapter plate available.
VigII is offline
post #5 of 15 Old 05-18-2015, 09:55 PM
Inveterate Putterer
Mikey4's Avatar
Sorry about dragging up an old thread, but I have a question about the brake relining material. I found it at McMaster-Carr. There are five flavors listed:
~three molded sheets, high, medium, and low friction.
~two strips - non-metallic molded strips and high strength woven semi-metallic strips.
Intuition says I want the woven semi-metallic stuff. The cost these days is still reasonable at $4.01 a foot.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is online now
post #6 of 15 Old 05-18-2015, 10:12 PM
4K Poster and climbing!!!
Canary Al's Avatar
I used the woven. On 4 tractors. Still have a long enough piece to do one more.
Some have suggested a slightly thinner liner would be better. You might look to see if one is available. There is merit to the idea I believe.
“Failure is simply the opportunity to begin again, this time more intelligently.”- Henry Ford
1992 - 20G-Kohler Magnum Twin (KMT) M20 big Red
1981 - 8183-repowered w/97 M18S 'lil Red
1972 - 816-repowered w/92 M18S 'lil white
1987 - Pro-12 Mr. Lucky
1984 - 8122 to get a diffrnt K301 soon.
1982 - 8123 Fred's Tractor an adoptee
1974 - 812 which is donating.
1970 - 450 w/CCKA Old Yellow
1968? - 424 - shared toy w/Grandson
1974 - C10A - for sale
1961 Ford Industrial 4000 w/Bkhoe-FEL
Canary Al is offline
post #7 of 15 Old 05-18-2015, 10:44 PM
Inveterate Putterer
Mikey4's Avatar
Thanks Al,
The sheet stock (high, medium, and low friction) is available in 1/8, 3/16 and on up to 1" The woven and non-metallic start at 3/16 and go up only a little higher.
Why do you think thinner might be better?
Also, was removing the old material easy? If not, any tricks or advice?
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
post #8 of 15 Old 05-18-2015, 10:59 PM
Canary Al's Avatar
Removal was easy on mine because all of them have been pretty worn out. I used my dremel to clean up the metal band.
There has been some discussion on other threads after this authoritive layout Jason made for us all. You can probably find them easy enough. Some have noted on many there is not much room for non-engagement right after installation.
I just let the liner wear and all has been fine, but I might have tried the next thickness down in retrospect. It wasn't $4 a foot when i first did one, and I knw I had a couple to do and wanted to be prepared if i messed up and had to start over. No worries tho this was a real easy task.
post #9 of 15 Old 05-18-2015, 11:49 PM
Gravelyyard.com
arcam8123's Avatar
Send a message via Yahoo to arcam8123
I know some people have complained in the past about the MC stuff being too thick and rubbing. I think if you follow Jason's prep procedure, you should be OK. My 8199KY needs a new band, so I'm going this route unless somebody comes up with something better.
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #10 of 15 Old 05-19-2015, 12:49 AM
Inveterate Putterer
Mikey4's Avatar
If the thickness is marginally acceptable, I can see why Jason's attention to material prep makes such good sense. I'll follow that method and see where it gets me.
In extreme, I could just take a belt sander to the installed material and shave it by a 32nd or so.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
post #11 of 15 Old 07-01-2015, 08:36 AM
Inveterate Putterer
Mikey4's Avatar
I'm getting ready to reline the band on one of my tractors. To start, I pulled the band from my 812/8120 parts tractor and cleaned that up. It turns out it has a lot of lining left, so I will probably pull the band from the tractor for which this is intended.
In any case, the first thing I am trying to do is "train" the lining material. This is the thinnest woven stuff from McMaster Carr. It is 3/16". I rolled it as tightly as possible and have it in a vise where I will leave it for a few days.
The bushing and clamp are to keep that inside end rounded. It wanted to stay straight.
By the way, wear gloves when handling this stuff. It has very fine brass wire woven into it and the ends of the wire strands will get into your finger tips in a not very nice way.
Hopefully by the end of this coming weekend I can install this into the 16G band and get it on the tractor and working.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
post #12 of 15 Old 07-01-2015, 08:46 AM
BEWARE...I'm a Cranker!
tiretrx's Avatar
Good stuff. I need to do this on the Custom.
Apparently, Krislu was taking it for a spin down that hill to the motorcycle show at the Mow-In. Somebody cut him off and as he put it, the brakes didn't work as well as he'd have liked them to
.....just call me Ellis
Folks say I'm lazy, drunk and stupid. Well, I got news for them......they're only 2/3 right.
tiretrx is offline
post #13 of 15 Old 07-01-2015, 10:35 AM
Canary Al's Avatar
You are always 'athinking Mikey. That should make it easier to work with.
post #14 of 15 Old 07-02-2015, 10:55 PM
Inveterate Putterer
Mikey4's Avatar
I pulled the well worn brake band off the 16G. There was still remaining friction material all the way around, but it was thin beyond the adjustment's ability to close. Each end of it flaked off easily. The rest of the material was tenacious. I ultimately settled on an old Four-In-Hand file with a very coarse curved rasp section.
It took about 15 minutes to get all the material off. When you consider these were never meant to be relined, and when you consider that the friction material has been there for 20, 30, maybe 40 years, a 15 minute time investment seems pretty cheap!
Now I just have to wait for the lining material to stay curved as I am training it. Maybe another day for that.
Is JB Weld the best stickum-tight for this?
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
post #15 of 15 Old 07-02-2015, 11:12 PM
Canary Al's Avatar
I've done 3 with JB Weld.
