Trying to make an engine gaurd fit on my 8199kt tractor. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 10-21-2019, 09:05 AM Thread Starter
REDGRAVELY 8199KT's Avatar
Here is my problem guys, I am putting an engine gaurd on my gravely tractor , when I bought this machine used it did not have one on it , the 19hp Kohler had been replaced with a magnum 20 hp kohler engine. It has a hitch on the back for pulling a cart or attachments. The hitch is a factory part. But my problem is the gaurd will not fit on because the engine sticks out too far! has anyone else ran into this? Do I have to make an extension bracket or shim to make this work right? Any advice is appreciated, the simpler the better!
In it's day the six gun was as common as the cell phone and just as annoying when it went off in the theater!!! A Government strong enough to give you everything you need, is also strong enough to take everything you have!
REDGRAVELY 8199KT is offline
post #2 of 6 Old 10-21-2019, 09:39 AM
PA RedRider's Avatar
Re: Trying to make an engine gaurd fit on my 8199kt tractor.
I'm wondering if your current hitch extension arms were perhaps shortened to accommodate the rear tiller with a stock 50" male driveshaft and liftable hitch. Check the number of holes in the arms at the axle and their position.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #3 of 6 Old 10-22-2019, 12:22 AM
If I remember correctly, the older tractors had rear hitch arms that mounted in only one position, and the optional engine guard extended over and behind the hitch bracket.
But when the the G series came out with the black engine guard that bolts inside the hitch frame, a new two position hitch arm was introduced. This allowed the hitch frame to mount in the original forward position for mounting the rear tiller lift-able hitch, and for mounting the bagger/vacuum blower assembly.
But these tractors came with the hitch arms mounted in the rear position to allow the new style engine guard to clear the engine.
So look at your hitch arms and see if they have two holes where they mount to the axles , or three holes, with the middle hole being elongated.
If they have three holes, move the hitch arms to the holes that move the hitch back, and a new style engine guard should work.
Because I have the vacuum bagger, and did not want to remove the hitch arms or the drive pulley when the bagger/vacuum is off the tractor, I did this:
I had my metal guy make special extension brackets so the hitch frame could stay in the forward position for mounting the vacuum, and so that the engine guard would be far enough back to clear the pulley.
You need hitch arms like this:
https://www.ebay.com/itm/Gravely-Lat...gAAOSwLdBaHZPF
If you are trying to use an engine guard that looks like the one on my tractor, or like this:
https://www.ebay.com/itm/GRAVELY-G-S...EAAOSwWz1dPjw8
The new style hitch arm is #047529, new number 08780853
In this picture you can see the extra forward hole of the hitch frame in front of the axle.
Sheldon
post #4 of 6 Old 10-22-2019, 11:03 AM Thread Starter
Thanks for all the great info!!!!
post #5 of 6 Old 11-06-2019, 05:11 PM Thread Starter
ATLANTIC CENTRAL, Your pics gave me an idea and I used 4 inch long lengths of black pipe with long bolts running through them for extensions and mounted my hitch in the front! Worked real well and very sturdy and rigid so Thanks Again!
post #6 of 6 Old 11-08-2019, 07:30 AM
You're welcome, glad I could help.
Sheldon
