Question(s) on MA208 Snowblower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 10-16-2019, 09:18 PM Thread Starter
Hello,
I recently acquired a 28" MA208 snowblower for my 1972 L8 walk behind and the following two questions.
The snow shoot deflector goes all the to the left and up the top dead center, but not to the right. Is there a simple adjustment for that?
I'm not sure, but it seems like my auger is potentially installed backward. I say that because when I turn the pto, the 'sharp end' of the auger blade does not turn forward, but the section with the scope does? I loaded a few pictures that might explain that better.
thanks,
Pete
ID:	2401111   Click image for larger version
pete3046 is offline
post #2 of 10 Old 10-16-2019, 09:34 PM
Re: Question(s) on MA208 Snowblower
The augers should feed the snow towards the middle of the machine where the impeller catches it and shoots it out. One of the augers is installed backwards.
To adjust the orientation of the outlet chute, you rotate the control arm until the cable is in the middle of its adjustment,you can then loosen the bolt on the chute rim that holds the cable nd move the chuts until it is pointing forward.
m
miro is offline
post #3 of 10 Old 10-16-2019, 09:34 PM
jrd
Yes, that auger is in backwards. It won't work well like that, the auger will push the snow away from the impeller, rather than into it.
What happens when you keep turning the chute to the right? It jams up? I'd try loosening the wear strips top and bottom, and wiggling the impeller housing. It's easy for dirt and rust to get in there and gum it up.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is online now
post #4 of 10 Old 10-16-2019, 09:44 PM Thread Starter
Thanks guys! Which auger is installed backwards? The left or right looking from the front? My head just spins when I look at them!
pete3046 is offline
post #5 of 10 Old 10-16-2019, 10:23 PM
jrd
Both are backwards
It's relatively easy to fix. Unbolt the bearing mounts from the sides of the housing. Disconnect the worm gear box at the driveshaft. It will either be a splined coupling or a u-joint pinned to the shaft. Remove the auger halves from the hex shaft. Swap them, keeping inside-to-inside, and outside-to-outside. Button everything back up.
While you're at it check/set the torque on the big nuts which hold the auger sections on. Those nuts control the pressure on the clutches which drive the auger. It's important to get that right, so as not to damage the worm gear, if a branch or rock gets in there.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #6 of 10 Old 10-24-2019, 04:33 PM Thread Starter
Guys thanks for the input, it was very helpful. Since I had the auger off I decided to refresh the bearings and seals in the worm drive gear box as it was leaking. In addition to one of the needle bearings falling apart, I noticed the worm gear to be relatively worn. I know it is a weak spot in the drive train and was wondering if there is a good source for new or used worm gears? Also, is there an easing way to get the needle bearing out of the end cap casting?
Thanks again,
Pete
pete3046 is offline
post #7 of 10 Old 10-24-2019, 10:28 PM Thread Starter
Here are a few pictures of my worm gear - how does it look?
pete3046 is offline
post #8 of 10 Old 10-25-2019, 10:54 AM
jrd
That's showing some wear, but I think is still serviceable.
I'd turn it around and keep running it.
Used worm gears do show up on for instance ebay every once in a while. It's been a few years since I've seen an NOS one. That one is in my parts stash You can also ask Richard's; they've often got all kinds of things squirreled away.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #9 of 10 Old 10-25-2019, 11:24 AM Thread Starter
Thanks jrd,
To turn the worm gear around, Iím assuming it can be tapped or pressed off the shaft to turn it around? Is only a shear key which holds the position of worm gear on the shaft?
Thank you,
Pete
pete3046 is offline
post #10 of 10 Old 10-25-2019, 11:52 AM
jrd
Originally Posted by pete3046 View Post
Thanks jrd,
Thank you,
Pete
The gear just slides on. There's a key (woodruff, IIRC) but that's it. Slide it off, turn it over, slide it back on. When assembled, the gear is located on the shaft by some big shims/washers.
I can't remember the dimensions of the shaft w/r/t the gear. It might be that you can turn the whole shaft and gear assembly around. I *think* the gear is offset on the shaft for some reason. If my memory is correct, you might be able to just slide the gear over a bit and then turn the whole assembly around.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
