38" snowblower gear,,, how's it look? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 27 Old 10-08-2019, 07:31 AM Thread Starter
HollyOnan's Avatar
Hi guys, please take a look at the close up of the blower's gearbox, with the fill plug removed. I believe that's the infamous worm gear I see in there. Is it supposed to be on an angle like that? I suspect it is, curiosity got the better of me and I had to engage the PTO, for about 10-15 seconds, it rotated quiet and smooth enough, but I can see the gear oil needs topped off.
This is my $250 find, only 15 minutes from home, got it last year, just getting it rolling regularly now, cant' wait for the snow. Ugh can't believe I just said that, ....Gravely's
This is my first blower set up, so any pointers, any known issues that you guys have experienced ? I'd appreciate any "heads up", thanks in advance
-Mike
Name:	812 on 10_7_19 a resized.jpg
ID:	2399347   Click image for larger version
Name:	812 on 10_7_19 resized.jpg
ID:	2399349   Click image for larger version
Name:	snowblower gear box 10_7_19 resized.jpg
ID:	2399351   Click image for larger version
Name:	snowblower gear box close up 10_7_19 resized.jpg
HollyOnan is offline
post #2 of 27 Old 10-08-2019, 08:03 AM
jrd
Re: 38" snowblower gear,,, how's it look?
Yes, that's the worm drive gear. From that pic, it's showing some wear, but not too bad. Looks servicable. Yes, the teeth are supposed to be angled; it's a worm gear.
I recommend you don't top it off, but completely change the oil in the gearbox. Make sure to use GL0 or GL1 (no sulfur). That will maximize the life of that gear.
In terms of other things to set up the blower, make sure the auger clutches are adjusted. You do that with a big crescent wrench on the nuts on either end of the auger. You want it snug, but not super tight, so that when you ingest a rock, the auger will just stop instead of stressing the gearbox. Set the skids to the height you want. On pavement that's pretty much all the way up. I blow on rough ground and gravel, so I keep mine down an inch, to keep from picking up too much crap. Make sure the rotation mechanism is smooth. You will probably want to stick some grease or heavy oil in the part where the drum rides on the housing. You may need to adjust the top and bottom stops (whatever those things are called) to be sort of snug against the edge of the drum, without binding.
Basically, just go over it all and make sure it looks like the moving parts are freed up and working correctly. Like most things gravely, it's a pretty simple design.
A running 812 with a 38" blower for 250 is a great grab! Have fun blowing, and
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is online now
post #3 of 27 Old 10-08-2019, 01:26 PM
yamato72's Avatar
Um
JRD,
Everyone on here knows that you should set the skids a bit lower on pavement, to leave a little bit of snow on the ground, which you then get out your other tractor and snowdozer to clean up.
c'mon
yamato72 is offline
post #4 of 27 Old 10-08-2019, 02:07 PM
jrd
Originally Posted by yamato72 View Post
Um
JRD,
c'mon
yes, I said that awkwardly. Skids as high as they will go puts the blower edge on the pavement. Skids down lifts the blower edge up, to keep the rocks out, most of the time.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #5 of 27 Old 10-08-2019, 02:14 PM Thread Starter
HollyOnan's Avatar
Thanks JRD, appreciate the advice. I really lucked out,,, it came with a 50" deck too, and the shell is awful,,, but as the saying should go,,, don't judge a tractor by it's appearance, because the rest of the deck, is great! mows really well, I thought I'd disassemble it and save the parts for spares, and chuck the deck, but now I'm going to keep the whole thing.
ohhh 'm feeling GAS-ey. Pics to come,, especially if I get the rust cleaned up and get a protective coat of paint.
Honestly, we might not even see enough snow to warrant the blower, but that wont really stop me from using it!
post #6 of 27 Old 10-08-2019, 09:21 PM
Deck shells can be replaced.....
I have a 48" blower and two snow blades for my 18-GLX, I don't even consider putting the blower on unless we get more than a foot of snow.
Bottom picture 7000 sq feet cleared with the blade in about 1 hour, took two hours to clear just a few inches more with the blower in the top picture.
I only have the one tractor, so there is no double teaming the snow with both methods......there is just switching to the blower if its really deep.....
Sheldon
post #7 of 27 Old 10-09-2019, 01:51 AM
Maybe see if there is someone nearby with G.A.S. that you can hug?
dave_r is online now
post #8 of 27 Old 10-09-2019, 06:53 AM
If this comment is directed to me, I must say I don't get the reference?
I'm pretty serious about my GRAVELY, I bought it new in 1996 and have written two booklets on the long list of improvements I have engineered for it.
If you are not familiar with me or my tractor, you can read about it here:
https://www.mytractorforum.com/24-gr...rovements.html
But I don't need more than one tractor, and given the average snowfall here in Maryland, a blade is my first choice for snow removal as it is much faster for snows in the 8-10 inch range.
The heavy snow falls shown in my pictures are typically a once every 3-5 years event around here.
My GRAVELY is a lot of fun, and I enjoy my "one tractor" version of the GRAVELY hobby. But I own a GRAVELY to save time and effort, not think up ways to spend more time on those tasks.
But in contrast to most people on here, I bought my tractor new, giving me a slightly different perspective on collecting additional machines.
Sheldon
post #9 of 27 Old 10-09-2019, 09:26 AM
tracktortag's Avatar
Um
JRD,
c'mon
Yes, a minimum of 2 tractors are needed in order to clear a driveway correctly. Steve (gravely1964) would say that even many more are needed.
Dave
tracktortag is offline
post #10 of 27 Old 10-09-2019, 09:40 AM
If I bought a second tractor, it would have to be another late mode G like I have now, it would need to be in very clean, original condition, OR, it would be a total restoration before being put into service.
As soon as we are well settled in our new home, the 18-GLX will get a good cosmetic touch up and going over, as well as few more improvements I have in the works.
And possibly even a repower..........we will see.
And still considering a wing mower.
Sheldon
post #11 of 27 Old 10-09-2019, 10:03 AM
jrd
Yes. I often use 3: Rider with 38" cannon, walker with 26" cannon, and walker with plow.
This year I have a new driveway to clear, to a different building, so I may be deploying a separate walker with cannon.
I have a 44" cannon which needs restoration, and a partially rebuilt 800 series tractor, sounds like I ought to get on the stick on those
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #12 of 27 Old 10-09-2019, 10:24 AM
You really should, just as a backup for the other three.
Dave
post #13 of 27 Old 10-09-2019, 10:44 AM
jrd
Enabler!
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #14 of 27 Old 10-09-2019, 10:45 AM
Mike, congratulations! That was a great find at $250, and only 15 minutes away! As John mentioned the blower's friction clutches need to be checked, and adjusted. Sometimes the plates rust together, so I would loosen the big adjustment nuts at the ends of the auger to be sure that it auger can freewheel. Then tighten them back up. I believe that the recommended torque setting is something like 85 lbs., so you can gauge it accordingly.
The bronze gear in one of my blowers (the gear in your pic) instantly turned itself into a paperweight after a buried tree limb got caught in the auger, and the clutches, which I hadn't checked, didn't release. Lesson learned on my part.
Hope you get lots of snow, and we get lots of pics this winter!
Dave
post #15 of 27 Old 10-09-2019, 10:48 AM
Enabler!
Just trying to help..
Dave
