Gravely 9000 trans/hydro fluid - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Unread 09-28-2019, 01:14 PM Thread Starter
I just picked up a gmt 9000 I read the manual about the fluid but most are no longer available and the ones that are still made i cannot get in my area. We have a tractor supply and that is about it. What do you all run in yours? will the Travelers universal work?
parlusk is offline
post #2 of 4 Unread 09-28-2019, 01:43 PM
PA RedRider's Avatar
Re: Gravely 9000 trans/hydro fluid
No first hand experience with this machine but I would probably start by trying to locate Pennzoil Hydratranz or one of these Shell Donax T-4 equivalents:
https://petroleumservicecompany.com/...oss-reference/
In any case, probably upwards of $80 to do a 10 gallon flush. Yikes.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #3 of 4 Unread 09-28-2019, 04:43 PM Thread Starter
Thanks for the reply. i have tried to find the recommended fluid locally without any luck. I only paid 300 for the tractor and it has been sitting for some time. I rebuild the carb, installed a new starter, coil and condenser and was able to get it running. The tractor has zero trans fluid in it and about half a quart of water. The water was clear so i am hoping for no damage to the trans. With that said i really don't want to drip $160 on fluid just to flush it and find out the transmission is shot.
parlusk is offline
post #4 of 4 Unread 09-29-2019, 11:51 AM
I just use the TSC universal stuff. I think the manual has a specification, that translates to JD 20 or equivalent. The TSC "Tractor Hydraulic Fluid" works fine.
I would be tempted to flush the trans a bit, before putting fluid in, and also change the filter.
HeyYou is offline
