Should I buy a Gravely 816T? - Page 6 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #76 of 88 Old 10-06-2019, 12:56 PM
tracktortag's Avatar
Re: Should I buy a Gravely 816T?
LOL! No, I think we all left that part out. Too late now.
Dave
tracktortag is offline
post #77 of 88 Old 10-06-2019, 05:43 PM
Originally Posted by jrd View Post
Has anybody warned him about G.A.S. ? Too late now . . .
kyavion,I guess it's time you knew, G.A.S., or GAS stands for Gravely Acquisition Syndrome. We all have it, and there is no known cure. You will catch it too, if you haven't already.
It's good that you have already found a plow. Now you'll be all set this winter, especially since you already have the chains. That plow is the improved version too, with it's cross frame reinforcements.
Dave
post #78 of 88 Old 10-06-2019, 06:12 PM
jrd
Right.
When you have multiple gravelys, they form breeding pairs and you're doomed. You can hold it off for a while by only acquiring one, but sooner or later another will follow you home.
The classic symptoms:
Well, there was this great package deal; I only wanted that attachment, but it came with another tractor.
It takes time and effort to swap attachments around. So much easier to have one set up for task A, and a separate one for task B.
And the worst of all: I have to buy this one, because it's a great parts machine! But, it really looks pretty good; maybe I could make a runner out of it. I know! Here's another one which would make a great source of parts for the last one!
Ask us how we know . . . .
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is online now
post #79 of 88 Old 10-06-2019, 09:39 PM Thread Starter
Originally Posted by tracktortag View Post
I just took another good look at the pic you included with this post. The rubber hose in your pic is your fuel line. The breather hose *does* connect at the baseplate of the air cleaner. If you remove the air cleaner cover, and air filter, you will see the hole (and maybe the other half of the breather hose) in the air filter housing's baseplate to the side of the carb air intake. Sorry about the confusion.
I popped the air filter and I don’t see it. I think the original connection point you mentioned may have been correct. Or should I just drill a hole in the base of the air filter housing for the tube?
Some more pics of the breather hose and air filter housing are attached.
ID:	2399155   Click image for larger version
ID:	2399157   Click image for larger version
kyavion is offline
post #80 of 88 Old 10-06-2019, 09:45 PM Thread Starter
Like you all said, this G.A.S. happens fast. First I just wanted the tractor. Now a plow pops up and of course it’d be handy to have. Then I see a front PTO with adapter kit, and that sure would be nice to have too. Then I could get a brush cutter and really do some damage. But wait, the cost of that front PTO and brush cutter might be the same or more than just buying a walk behind with a brush cutter. Plus I wouldn’t have to mess with swapping stuff around if I also had a walk behind. But that front PTO seems too good to pass up. What to do, what to do. All I wanted was something to mow with. That was it.
kyavion is offline
post #81 of 88 Old 10-07-2019, 05:49 AM
jrd
Yep. G.A.S.
BTW you want that front adapter for other things. A walker is better for brush hogging anyway, but with that front kit, you can get a small deck into the tight places you can't reach with a belly deck. To really go hog wild, you could get a gang reel mower to mount on either the front of the walker, or the adapter on the rider. Of course, you'd need the gang mower. Better start looking. . . . .
Did we mention that we're all enablers?
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #82 of 88 Old 10-07-2019, 09:19 PM
Your post made a lot of sense to me, John. But then it would, wouldn't it?
Dave
post #83 of 88 Old 10-07-2019, 09:28 PM
kyavion, I checked the air filter baseplate on my '72 816 today. Guess what, no hole just like yours. I can't say where it should go either since the tractor (a non running $200 special) is sitting like it was when I picked it up, and there is no breather hose at all. The breather hose on the '75 816 *does* press fit into a hole on the underside of the baseplate.
Maybe someone with a 72-73 816 can take a look and let you know where their breather hose winds up.
Dave
post #84 of 88 Old 10-08-2019, 05:54 AM
jrd
The breather hose on my '74 is like Dave's. I suspect somebody swapped parts around.
For the short term, I wouldn't worry about it. You can run it with that hose disconnected. You could stuff a bit of fiberglass or something in the end of the hose to keep crud from getting in there.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is online now
post #85 of 88 Old 10-08-2019, 07:37 AM
WH401's Avatar
With a serial of 15896A that would mean the tractor does have an LSD axle. LSD's were no longer installed mid-way through the 73' MY, around the 18xxx serial.
On the axle hubs, the one set screw doesn't look to be a set screw, instead it appears to have been replaced by a common bolt. You'll want to replace that bolt witha proper set screw as bolt don't have the necessary properties to function as a set screw. Verify that both set screws are tight down on their axle keys, otherwise you'll wear out the key ways in the hubs. The in/out play of the rear axles is normal, and I wouldn't be concerned the separate play of the wheel in all directions. The bearings on the axles are very robust and bathed in oil.
Rick
1960's-70's IH 340
1974 Gravely 816
1977 Gravely 817 (2)
1989 Gravely 20-G
199x Gravely 16-G
2000 Gravely Pro-14
2017 JD X758
WH401 is offline
post #86 of 88 Old 10-08-2019, 10:37 AM
I don't have time to read every thing in this thread at the moment. I did read your concerns about the 30 Bush hog deck taking longer to cut what you need to cut. I think you might be surprised . The walking tractors are nible to use the 30 inch deck will get places you can't get to with bigger decks. I have about 1/2 acre of yard that it cut up with garden fire pit trees etc. I can cut it with my professional 12 and a 40 inch deck in about 2/3rds the time it takes with a 46 inch deck on a rider . My professional 12 walking tractor has steering brakes and is nearly as maneuverable as a zero turn
Every breath I take as a Free man was paid for with the blood of an American Soldier
From Concord and Valley Forge to the sands of Iraq
and mountians of afghanistan American soldiers have
paid the ultimate price For our Freedom.I am ever mindful
and for ever greatful for their sacrifice
My heros have always been American Soldiers
plumberroy is online now
post #87 of 88 Old 10-08-2019, 11:49 AM Thread Starter
Thanks for the info about the walk behinds. I may have to look into getting one down the road.
I picked up that snow blade yesterday. I stopped by Richard’s in WV since I was close by, and he said it looked looked like all the blade parts were there and it looked good to go. I showed him a pic of the breather hose, and he didn’t have much to say about it. He said he had only seen a couple Onan’s before. Another person there said it was just a vent for combustion gases, and that they probably starting attaching the hose to the air filter for emission regulations. He recommended just getting a vented cap for it.
I guess I lucked out with getting the LSD. Thanks for the info for that.
As far as the set screw, how would the end be different from a bolt? Is it something I can shape with a grinder?
Now how about these wheel weights? They sure are pricey. Do 15lb weights really make that much of a difference? What about just added weight on top of the blade, or just attaching weight to a rod that goes through the front PTO hole?
kyavion is offline
post #88 of 88 Old 10-08-2019, 12:29 PM
It's not so much weight on the blade that you need, but weight for the front end of the tractor so the steering wheels do not lift off the ground as readily. Rather than wheel weights, you can look for a front mount weight rack and then you can be creative with what you use for the weight (still $$$, probably). I think there is clearance for the plow with the rack installed (perhaps others can confirm).
jj94tt is offline
