New Gravely owner - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 27 Old 10-04-2019, 04:20 AM Thread Starter
I found two markings.
10-628P1
JH58
Does this tell me the year of built?
swetom2011 is offline
post #17 of 27 Old 10-05-2019, 10:57 PM
no2498's Avatar
Re: New Gravely owner
i do not know
but will give you a bump
john
no2498 is online now
post #18 of 27 Old 10-06-2019, 07:53 AM
jrd
10-628P1
JH58
Not sure.
Gravely S/Ns follow a pattern. You can see a chart at Gravely Tractors - Links - StevenChalmers.com
The P1 is not part of the S/N, though I'm told that sometimes that got appended to it.
10-628 doesn't make sense. But if that hyphen were a digit, it would; that would be 1974, which would make sense for a C12
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
Too many attachments
jrd is offline
post #19 of 27 Old 10-06-2019, 09:39 AM Thread Starter
Thanks, I will check more carefully when I get the Gravely home and have cleaned it. Currently, I've "parked" the Gravely at my neighbor until I get a new battery (should get it tomorrow).
If I understand the motor marking correct (see a previous post from me), it's from 1975 so 1974 could be correct.
post #20 of 27 Old 10-06-2019, 09:53 AM Thread Starter
By the way, I tried to take some photos of the numbers I found, see below but as I said above, I will check more carefully tomorrow.
ID:	2399063   Click image for larger version
post #21 of 27 Old 10-06-2019, 09:57 AM
jrd
Ah. Neither of those are tractor S/N, those are part numbers for the castings.
You want to look on the left side of the advance casting, underneath the reinforcing rib. You should see a small (maybe 1" long by 1/4" tall) aluminum plate riveted to the casting, with a number stamped into it. It might be upside down, many were assembled that way.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is offline
post #22 of 27 Old 10-10-2019, 06:57 AM Thread Starter
I couldn't find anything on the left side of the advance casting. However, under the hood I could find a label, see picture.
Here I can read "Serial number 0020314". Does this make any sense?
The muffler is "home made" using a Fiat cast muffler. It's quite good in terms of noise suppression but, among others, the contact between the cylinder and the pipe is not very good (there is no flange, the pipe is just inserted in the hole). I would like to get a better/nicer one, any suggestions?
ID:	2399601   Click image for larger version
ID:	2399603   Click image for larger version
post #23 of 27 Old 10-15-2019, 09:10 AM
PA RedRider's Avatar
Simple solution is to run the spec number on the kohler engine. You have a 1970s era 500 series.
OMG, that muffler is a sight to behold. I'd have to replace that. I recommend you pickup a Cub Cadet style muffler. I have one on my 5000 series and like it.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #24 of 27 Old 10-15-2019, 09:45 AM
jrd
Ah. Sorry, I led you astray about the location of the S/N. I thought we were talking about a comm12, but that is in fact a 500 series.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
jrd is offline
post #25 of 27 Old 10-16-2019, 03:15 PM
Join the Gravely Tractor Club of America as it is international in membership. There are also gravely clubs at facebook, big memberships as well. The yahoo gravely tractor club has a extensive files section. Those three sources give useful contacts and the technical information you need.
edwardgoodridge is online now
post #26 of 27 Old 10-16-2019, 04:08 PM Thread Starter
Thanks a lot. I will do so.
post #27 of 27 Old 10-16-2019, 05:18 PM
tracktortag's Avatar
The "203" part of your serial number falls in with the tractors built in 1975, so I would say it is a 1975. Your serial number also appears to be one number short. It was likely on the part of the number tag that is missing.
tracktortag is offline
edwardgoodridge
