16G Professional - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 38 Old 09-02-2019, 09:57 AM Thread Starter
16G Professional
Just picked up a 16G Professional and I'm having trouble determining the year it was built. There are 2 tags under the hood on the right and are stamped 45541 and the other s/n 00609079. The info I can find doesn't seem to go into the 1990s which I believe this is. I'm guessing around a 1992 based on service manuals I've looked at in the gravely manuals site.
Also the Kohler engine is a model M18S, spec no 24589, and serial no 1823502197.
Any assistance with this would be appreciated.
If I could figure out how to post some pics I'd attach some!
Bodjick L is offline
post #2 of 38 Old 09-02-2019, 04:01 PM
Re: 16G Professional
Several members have access to the GRAVELY factory database, if they see this they will likely look it up for you.
Or, if you have a dealer nearby, they should be able to look it up.
Understand, if you are new to GRAVELY, they did not go by model year. The tractor stayed the same until there was a reason for a change.
A few pictures would help, and you may be interested in this:
https://www.mytractorforum.com/24-gr...rovements.html
It is a long read, but it contains the history of a long list of improvements I made to my 16G.
Sheldon
ATLANTIC CENTRAL is offline
post #3 of 38 Old 09-04-2019, 09:50 PM Thread Starter
Well overall I'm pretty happy with my new to me 16G Professional. I did find out a couple things about 16Gs that I didn't know. I was surprised that a 16G Professional didn't have an hour meter, but I'm especially disappointed that it doesn't have an oil filter on the M18S engine. That seems so un-Gravely like. I don't know how many hours are on this engine etc. and it doesn't smoke so I think it's pretty good. But I hate to run it without an oil filter. I've even looked at a remote oil filter adapter (pricy) and wonder if it's worth it at this point. It looks like the place an oil filter would have gone is under one of the exhaust mufflers, but is just covered with a blank plate. Am I crazy to even be considering or thinking about it?
post #4 of 38 Old 09-04-2019, 10:42 PM
Inveterate Putterer
Mikey4's Avatar
The oil filter was an option on most 16Gs. Adding one is super simple. Finding the parts - not so much. A member here had a few of them and I bought two from him. He was selling them on eBay, too. I know his real name but can't recall his screen name, but he is active on the Facebook group. You might ask over there if he doesn't see this.
You just remove the blanking plate, put on the filter adapter plate, screw on the filter and you're done. Yes, it is behind the exhaust. It uses a squat filter that is commonly available that clears the exhaust. I'd have to go out to the shop to get the number.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
Mikey4 is online now
post #5 of 38 Old 09-04-2019, 10:56 PM Thread Starter
If I can do it that easily I'd probably do it. The adapter that I saw included hoses that you'd route to a remote location where you could mount the base for the screw on filter. Even that didn't look too bad really.
post #6 of 38 Old 09-04-2019, 11:37 PM
Inveterate Putterer
Mikey4's Avatar
I'd hold out for the stock Gravely adapter. FAR better and FAR neater.
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
post #7 of 38 Old 09-05-2019, 12:17 AM
Inveterate Putterer
Mikey4's Avatar
This is from a JD but I'm pretty sure it is the same adapter.
https://www.ebay.com/itm/John-Deere-...wAAOSwF8Bcnjd-
You can try to save the gasket under the blanking plate on your tractor but maybe consider a new gasket, like this.
https://www.ebay.com/itm/Kohler-oil-...sAAOxyYSdS~nVf
Challenge Met
Gravely 16G (1998)
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 816S (1976)
post #8 of 38 Old 09-05-2019, 07:23 AM
Sounds like you have the older dual exhaust version of the 16G. You can add the oil filter directly to the engine, but you will need to adjust the muffler position.
You will need to carefully "un bend" the U shaped pipe at the top to angle the muffler away from the oil filter.
My 16G came with the newer one piece exhaust but later installed the dual exhaust.
I purchased my tractor new, and added the oil filter the first week I owned the tractor.
Later 16G's did come with hour meters and many dealers installed them on older versions.
Your tractor is very early 90's I think.
Sheldon
post #9 of 38 Old 09-05-2019, 07:31 AM
Mikey, I don't think that is the right oil filter adapter. The correct Kohler number is 82-755-23S.
I don't have a picture handy, but it is not tall like this one you linked to.
No picture, but this is it:
https://www.ebay.com/itm/Genuine-Koh...ss!21078!US!-1
Sheldon
post #10 of 38 Old 09-05-2019, 10:19 AM Thread Starter
Of course it would the be more $ one!
If you're absolutely sure it's the one I'll buy it though.
post #11 of 38 Old 09-05-2019, 10:49 AM
Yes, I'm sure. I actually wrote two books on the improvements I made to my 16G, and I double checked that part number this morning when I posted that. I think it was over thirty dollars 24 years ago when I did mine.
Sheldon
post #12 of 38 Old 09-05-2019, 10:50 AM
They do show up used on Ebay from time to time, just none right now. Maybe someone on the forum has one and will see this.
Sheldon
post #13 of 38 Old 09-05-2019, 10:53 AM
Also, in case you don't already know, your engine is 18 hp. The only difference between your engine and the one on an 18G is the oil filter and the stickers. Every part that controls hp is the same, despite what some people will try to tell you.
Sheldon
post #14 of 38 Old 09-05-2019, 01:45 PM
yamato72's Avatar
I have a filter housing and (I believe) the gasket. You can have it for the cost of shipping, just PM me if interested.
yamato72 is online now
post #15 of 38 Old 09-05-2019, 10:25 PM Thread Starter
I did PM message you yamoto72.
I now also have experience taking the front axle off. I started bringing maintenance up to date. It looks like it hasn't been greased in a while. Anyway, the fitting on the top of the axle wouldn't take grease. Then when I pulled my grease gun end off the fitting broke off and came with it. So off comes the axle. I was able to start a left hand drill bit on what was left of the grease fitting and it screwed right out.
Then to find out why it wouldn't take grease. The old grease was like concrete! I was able to use a small drill bit to clean it out so grease could get down through the sleeve to the bolt. There was significant wear on the old bolt and the front hole in the frame. But a new 3/4" bolt, a couple washers, and lock nut tightened just right, then greased, and now the axle pivots just like it should!
One issue down.
