Zenith idle jets - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 08-31-2019, 08:49 PM Thread Starter
Dirt Digger
chzuck's Avatar
Zenith idle jets
Anyone on here have a source for purchasing the idle jet used in the Zenith 68 carburetor? Looking for the two that are smaller than the stock #12 jet.
Charlie H Zuck
www.zucksrototillers.com
There is only one ROTOTILLER.
My YouTube Channel
chzuck is offline
post #2 of 13 Old 09-01-2019, 08:26 AM
Longboardr's Avatar
Re: Zenith idle jets
I don't have a source, but I'll pass on a tip I got from someone who couldn't locate jets for a piece of equipment they had. They'd melt lead and pour it into the jet, then drill it to size with something like this http://www.amazon.com/TG888-Micro-Tw.../dp/B07HXVBV9K
Longboardr is offline
post #3 of 13 Old 09-01-2019, 02:50 PM Thread Starter
Dirt Digger
chzuck's Avatar
That would be quite a task. The jet is about an inch long.
Charlie H Zuck
My YouTube Channel
chzuck is offline
post #4 of 13 Old 09-01-2019, 06:58 PM
Longboardr's Avatar
How long is the smallest diameter hole in the jet? He was just pouring enough lead to cover the hole then drilling through it.
post #5 of 13 Old 09-01-2019, 08:43 PM
Strange as is sounds, the jet is the component with a specific diameter hole in it, the needle which works with the jet is often mistakenly called a jet.
That said, there is no 'idle' jet in a Zenith carb, there is an air idle needle. There is a well vent jet, which you do not want to mess with, a discharge jet, and the main jet which controls the run fuel/air mix. That is the one at the bottom of the carb.
Check here to see if they have what you are looking for. Parts for Aluminum Zenith Carburetors
Roger,
Faux Pas are my forte
beaner2u is offline
post #6 of 13 Old 09-01-2019, 10:04 PM Thread Starter
Dirt Digger
chzuck's Avatar
Roger,
I beg to differ. Item 9 idle jet C55-6-12. That air idle needle affects the amount of fuel drawn through the idle jet. I can turn that needle out 5 turns and there is not effect on the idle quality. Now remember I am using this carb on a Frazer Rototiller that is a two stroke.
Charlie H Zuck
My YouTube Channel
chzuck is offline
post #7 of 13 Old 09-01-2019, 10:09 PM Thread Starter
Dirt Digger
chzuck's Avatar
The jet is 1/2" long. Too small for my old eyes to try and modify. Surely someone out there has jets. I was in touch with Zenith so maybe I will go back and see if they will sell me some directly.
Charlie H Zuck
My YouTube Channel
chzuck is offline
post #8 of 13 Old 09-04-2019, 05:32 PM
OK, I apologize Charlie,
You plulled one of the three "don't touch that" jets, 9,14, 23. The main jet is often cruded so badly in place that it cannot be removed, and the other two are often correded into place also, best to just clean them in place with welders tip cleaning tools. The discharge jet, 22, can be removed, 9mm deep socket, and makes cleaning the others much easier.
Amazing how crudy the discharge jet itself gets.
I think GT Gravelyparts can help you, Parts for Aluminum Zenith Carburetors
Roger,
beaner2u is offline
post #9 of 13 Old 09-04-2019, 08:40 PM Thread Starter
Dirt Digger
chzuck's Avatar
Well you cannot install a smaller jet if you don't take the old one out. I can see there would be no real reason to remove it on a regular rebuild. I am going to lower the fuel level and see if that helps in setting idle. I turned the idle screw out 5 turns with no notable changes in idle. This carburetor is on a two-stroke Frazer Rototiller and was the factory replacement for a Tillotson YC9A.
So far I have emailed Gravelyparts twice and they have not answered. Guess they don't want to sell me parts.
Charlie H Zuck
My YouTube Channel
chzuck is offline
post #10 of 13 Old 09-04-2019, 10:08 PM
You could try rototillerparts.com or Zucks rototillers. It's been awhile. But if I remember correctly turning the idle needle in richens the mixture and turning it out leans it on this carburetor. It seems to me you might have worn throttle shaft / bushings, plate or bore.
Toddnails is offline
post #11 of 13 Old 09-04-2019, 10:18 PM Thread Starter
Dirt Digger
chzuck's Avatar
Well I have been in touch with a Zenith tech and he is the one who ask me to remove the idle jet to verify the #. If the throttle shaft was worn, I would be lean. In fact I am trying to purchase the jets from Zenith directly since no other parts place wants to answer my emails.
By the way, I am the owner of Zucks Rototillers and I do not have Zenith parts.
Charlie H Zuck
My YouTube Channel
chzuck is offline
post #12 of 13 Old 09-05-2019, 08:53 AM
McDonald Carb Parts, search the interweb.
They have all kinds of jets, screws, floats, gaskets, etc. for the Zenith carbs.
Worth the look.
If you have the carb number (round disk riveted on top) it is a big help.
And they don't gouge you with the shipping (free if you order enough parts).
nhgravely is offline
post #13 of 13 Old 09-05-2019, 10:43 AM Thread Starter
Dirt Digger
chzuck's Avatar
Worth the look.
Thanks, I just emailed them this morning and already heard back from them and they have the jets I want. Great!
Charlie H Zuck
My YouTube Channel
chzuck is offline
