L-Series Gas dripping - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 08-11-2019, 09:53 PM Thread Starter
So I have gas slowly dripping out of the bottom of the tank.
A few questions
  1. what can I "wrap" around the threads of the nipple gong to the tank
  2. what can I use or where can I get a gasket for the top of the glass bowl?
  3. If it is the stopcock, is that fixable, and how?
Thanks
sad_story is online now
post #2 of 8 Old 08-12-2019, 08:53 AM
Lnk
A few questions
    You can use Teflon tape, they make a special pipe dope for gasoline,"gasoila" is the brand I am familiar with. But Teflon tape should do it.
    If you have any gasket material, you can make one with an exacto knife, it is just a ring, otherwise a new sediment bowl can be gotten at tractor supply.
    Leaking around the stopcock? Should be a gland nut you may be able to tighten. I have used an o-ring under the gland nut, or you can use Teflon for that too. They have Teflon rope or string for faucet repair so that might work for you.
Thanks
Sorry I didn't know how to bold my answers.
Lnk is offline
post #3 of 8 Old 08-12-2019, 09:22 AM
Re: L-Series Gas dripping
I have used rubber from tire patch kits or inner tubes to make sediment bowl gaskets..
Cork works well also..
Tractor-Holic is online now
post #4 of 8 Old 08-12-2019, 09:48 AM
GT Parts has gaskets for the glass bowels.
Are the threads NG in the tank? If still good just use good pipe dope on the nipple and screw it in tight. If NG, then use epoxy (best you can find that is fuel proof) and install new nipple.
GT also has new filter bowels w/ valves.
Also check TSC.
nhgravely is offline
post #5 of 8 Old 08-13-2019, 03:48 PM Thread Starter
Also check TSC.
thank you all, that should get me through the job!
post #6 of 8 Old 08-14-2019, 02:26 PM
The needle shut off on my sediment bowl was leaking around the nut. Tightening did no good. It still dripped even though I couldn't turn the T handle.
I backed the nut off and put 4 or 5 wraps around the needle shaft with Teflon tape then tightened the nut back up. Just tightened until I could just turn the T handle in and out. The leak was gone. It's been that way for a couple months and several uses now with no drips at all.
Bodjick L is offline
post #7 of 8 Old 09-03-2019, 09:14 PM Thread Starter
thanks all.. teflon tape and anew gasket from gt parts.. all sorted now
L-8 (6.6hp)
post #8 of 8 Old 09-03-2019, 10:02 PM
The glass bowl filter/petcocks are nice for a restoration. But they are a PINA if you really want to work your tractor. Replace it with a 1/8 NPT x 1/4" angle style petcock and add an inline large clear plastic 1/4" filter. The Fram # is GF1 OR GF2
Toddnails is offline
