-   Gravely (https://www.mytractorforum.com/24-gravely/)
-   -   Question about 50 inch deck (https://www.mytractorforum.com/24-gravely/1333639-question-about-50-inch-deck.html)
JD316Fan 08-07-2019 07:27 PM
So I have a rather derelict Gravely 450 in my possession, and I was thinking about buying a 8123, but he wants too much for it with the deck. They both have a 50 inch deck. Would I be able to take the deck off of the 450 and install it on the 8123 with little to no modifications?
gravely1964 08-07-2019 09:26 PM
Re: Question about 50 inch deck
Well yes but you need the drive shaft for 800 or 8000 short frame tractors
JD316Fan 08-07-2019 10:27 PM
14 Attachment(s)
Is this all I would need to to? Would you happen to have a part number this item(s)? I know I may seem dumb but I'm just getting into Gravelys and I dont know much about them.
yamato72 08-08-2019 09:04 AM
The 8123 and 450 are both short-frame tractors, so the driveshaft length is not a concern. What you do have to be careful of is the number of splines, early attachments had 13-spline drives. It's not insurmountable as you could potentially use the rear half of a 15-spline prop shaft with the front half of a 13-spline. If you encounter that. I don't know for sure that all the early rider attachments were 13-spline.
EDIT: Realized my goof. 8123 is long frame. Carry on!
JD316Fan 08-08-2019 05:42 PM
14 Attachment(s)
I thought they were both short frames? I can see that the gas cap to the front of the hood is the same distance away. I thought that's how your were able to tell. If I have to buy one half of the driveshaft with 15 splines that doesnt bother me.
gravely1964 08-08-2019 10:53 PM
3 Attachment(s)
Well if you say so. But 400 shaft lower and 800 shaft upper. There different lengths since they have 2 totally different transmissions. Even though wheel bases are pretty close
Attachment 2390189
Attachment 2390187 400, 16G and 818-T. Long frame is 6 inches longer basically
JD316Fan 08-08-2019 10:59 PM
14 Attachment(s)
Ok I understand. The 400s have the Swiftamatic transmission with the Hi/Lo and 2 speed PTO. I'd need the 15 spline male end of the driveshaft of the longer length. Thanks for the help.
yamato72 08-11-2019 09:05 PM
I’m rusty on the designations, sorry. 8000s ending in a “2” are short frame, manual lift. Ending in a “3” is a short frame, hydraulic lift. Long frame tractors end in a “9.” I honestly don’t remember if there is a designation for a long frame, manual lift 8000.
JD316Fan 08-12-2019 01:20 PM
1 Attachment(s)
It's alright. We all make our mistakes. I'm just new to Gravelys and I am trying to learn the basics. I also came across an interesting Gravely for sale and it gas an interesting set of decals and I am wondering if anybody would know what model it is. The model number on the hood has disappeared over time.
gravely1964 08-12-2019 06:07 PM
Heres the pdf list of gravely
models riders and walk behinds, they'll tell you long short frame, motors, lifts ect http://rich.homeunix.com/gravely/Cus...88_89_1188.pdf
Scroll down to rider section
Mikey4 08-12-2019 10:39 PM
None of the decals are standard.
The tractor is most likely an 8000 series. Just a pure guess, but maybe an 8123
8 = 8000 series
12 = 12HP
3 = hydraulic lift
the 12 could be 14 or 16 just as easily, but the 12 is the most common in that series.
JD316Fan 08-12-2019 11:59 PM
15 Attachment(s)
Like I said I'm buying an 8123. It ran last year, but he can't get it started this year. It's in pretty good shape. Is $475 a good deal? It got him down on the price, and that is included with a 50" deck. It was either 350 without deck and I buy a driveshaft, or it was 475 with the deck, and I think with deck is a better option. That way when I sell the 450 I make more because it has a deck.
yamato72 08-13-2019 11:42 AM
Can't argue with the logic. Go for it.
JD316Fan 08-16-2019 09:47 PM
EDIT: I got the 450 running yesterday. Looks like I will be able to sell it for more than I expected.
WH401 08-20-2019 03:23 PM
For a non-runner in the mid-atlantic area I'd say that's a bit to high. I have a hard time going over $250 on a non-runner, depending on condition. Who knows what it will take to get it going again. If it was at least running and just needed some maintenance items, than $475 is a decent deal.
The other tractor you showed has been for sale for the last 8+ months. It's a repaint of some sorts, thought I haven't had a good look at the tractor in a while to determine the exact model.
Rick
