Inner Tube Recomendation - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 19 Old 07-27-2019, 08:57 PM Thread Starter
Hi I am looking for new inner tubes for my Gravely L8 size 4.00x8 . The problem is all the ones I have seen have the valve stem in the middle instead of offset to the side. Any one know where I can get inner tubes with the correct valve stem and are decent quality???
nate_o23 is offline
post #2 of 19 Old 07-27-2019, 09:26 PM
GravelyNM's Avatar
Re: Inner Tube Recomendation
Try tractor supply.
Sent from my XT1575 using Tapatalk
GravelyNM is offline
post #3 of 19 Old 07-28-2019, 08:15 PM
You may have to special order from TSC or Home Depot.
https://www.homedepot.com/p/Hi-Run-4...E&gclsrc=aw.ds
Roger,
Faux Pas are my forte
beaner2u is offline
post #4 of 19 Old 07-29-2019, 06:07 PM Thread Starter
I have already checked the local tsc and rural king. All they have is the wheelbarrow style tube that has the valve stem in the middle. I am looking for a tube with the stem offset to one side so it will fit the gravely rim better.
nate_o23 is offline
post #5 of 19 Old 07-29-2019, 06:32 PM
You should compare the cost of new tires to the inner tubes. I recently paid $17.50 ea for 15x6-6 Kenda's for my lawn trailer. Tubes would have been $10 to $12 each. Tires had a lot of cracking .
rayjay is offline
post #6 of 19 Old 07-29-2019, 06:32 PM
As for the tubes, I've never seen any with the valve stem offset. I redrill the holes in the rim and plug the old ones.
rayjay is offline
post #7 of 19 Old 07-29-2019, 06:51 PM
I second that. Just put a pair of 16x6.50-8 Carlisle Turf Saver tires on my Bunton for $55. New shorty valve stems are cheap too. One of the wheels had some rust inside the valve stem area because the PO used a tube. Tubes don't seal the inside of the wheel from the outside at the valve like real valve stems so water gets inside and corrodes the heck out of the wheels. I cleaned off the rust, welded the old hole closed, and drilled a new one 180 around the wheel for the new shorty valve stem. Spray on some paint and 24 hours later I had a pair of tubeless tires mounted and on the back of the mower.
My Horse I & Horse IV tillers run 4.80/4.00-8 tires. You can get that size Carlisle Power Trac AG/Bar treads for $38 each and the Carlisle Stud tread for $32 on Amazon with Prime shipping. They'll probably outlast you. My Horse I tillers first set of tires lasted from the 70's till a few weeks ago.
hatzie is online now
Old 07-29-2019, 07:18 PM
mopar65pa
This message has been deleted by mopar65pa.
post #8 of 19 Old 07-29-2019, 08:34 PM Thread Starter
not sure a tire would seal on a gravely L split rim without a tube in it. All the air would leak out between the split
nate_o23 is offline
post #9 of 19 Old 07-29-2019, 08:57 PM
Googled gravely tire tubes.
This was the first hit... Looks like the valve exits somewhat to the side.
https://chalmersind.com/products/135...8aAs3dEALw_wcB
If the tires are cracked I'd still consider a new pair of Carlisles to go with the tubes.
post #10 of 19 Old 07-29-2019, 09:51 PM Thread Starter
That does look right, I will give chalmers a try
nate_o23 is offline
post #11 of 19 Old 07-30-2019, 09:19 AM
PA RedRider's Avatar
I second this.
Try Richard's L&G, Berlin Gravely or gravely_tractor_museum on Ebay for the tubes.
Thanks.
Looking for a home for:
Looking for:
- Onan-powered rider
- 14# wheel weights
PA RedRider is offline
post #12 of 19 Old 07-30-2019, 09:30 AM
jrd
Miller Tire sells 4.00-8 tubes. The web site doesn't say whether they have offset stems, but the last batch of tubes I bought from them did.
'41 L (not running)
'43 L
'44 L
'50 L
'52 L (not running)
'58 LI (not running)
'59 LI
'61 LS
'61 LS
Mutt LS
'62 LI (not running)
'63 L8
'66 L8
'66 C8
'67 C8
'74 Comm 12
'75 C8
'73 812
'74 816
UFT Mountaineer 88E
3 parts/project tractors
jrd is online now
post #13 of 19 Old 07-30-2019, 06:41 PM Thread Starter
thanks guys for the help!
nate_o23 is offline
post #14 of 19 Old 07-31-2019, 10:14 AM
I had no problems getting a set of 16-4.8/4.00-8 tubes with the Slime product pre-installed in them from TSC locally in stock. Stem was offset and fit rims just right.
nhgravely is online now
post #15 of 19 Old 07-31-2019, 02:21 PM
Worn out tires with new tubes does work in my experience but does make you more vulnerable to flats. Maybe best for a bunch of L's just those not run much.
edwardgoodridge is offline
